RTEMS 6.3
This directory contains for the "file system" library. All supported file systems live under this tree.
Currently the supported file systems in this library are:
IMFS or In Memory File System
This is the only root file system on RTEMS at the moment. It supports files, directories, device nodes and mount points. It can also be configured to be the miniIMFS.
–Chris Johns and Joel Sherrill 17 Feb 2010
