RTEMS 6.3
RTEMS File Systems Link Routines. More...
#include <inttypes.h>#include <string.h>#include <rtems/rfs/rtems-rfs-block.h>#include <rtems/rfs/rtems-rfs-buffer.h>#include <rtems/rfs/rtems-rfs-file-system.h>#include <rtems/rfs/rtems-rfs-trace.h>#include <rtems/rfs/rtems-rfs-dir.h>#include <rtems/rfs/rtems-rfs-dir-hash.h>#include <rtems/rfs/rtems-rfs-link.h>Functions | |
| int | rtems_rfs_link (rtems_rfs_file_system *fs, const char *name, int length, rtems_rfs_ino parent, rtems_rfs_ino target, bool link_dir) |
| int | rtems_rfs_unlink (rtems_rfs_file_system *fs, rtems_rfs_ino parent, rtems_rfs_ino target, uint32_t doff, rtems_rfs_unlink_dir dir_mode) |
| int | rtems_rfs_symlink (rtems_rfs_file_system *fs, const char *name, int length, const char *link, int link_length, uid_t uid, gid_t gid, rtems_rfs_ino parent) |
| int | rtems_rfs_symlink_read (rtems_rfs_file_system *fs, rtems_rfs_ino link, char *path, size_t size, size_t *length) |
These functions manage links. A link is the addition of a directory entry in a parent directory and incrementing the links count in the inode.
| int rtems_rfs_link | ( | rtems_rfs_file_system * | fs, |
| const char * | name, | ||
| int | length, | ||
| rtems_rfs_ino | parent, | ||
| rtems_rfs_ino | target, | ||
| bool | link_dir ) |
Create a link. Do not link directories unless renaming or you will create loops in the file system.
| [in] | fs | is the file system. |
| [in] | name | is a pointer to the name of the link. |
| [in] | length | is the length of the name. |
| [in] | parent | is the inode number of the parent directory. |
| [in] | target | is the inode of the target. |
| [in] | link_dir | If true directories can be linked. Useful when renaming. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_symlink | ( | rtems_rfs_file_system * | fs, |
| int | length, | ||
| const char * | link, | ||
| int | link_length, | ||
| uid_t | uid, | ||
| gid_t | gid, | ||
| rtems_rfs_ino | parent ) |
Symbolic link is an inode that has a path attached.
| [in] | fs | is the file system data. |
| [in] | name | is a pointer to the name of the node. |
| [in] | length | is the length of the name of the node. |
| [in] | link | is a pointer to the link path attached to the symlink inode. |
| [in] | link_length | is the length of the link path. |
| [in] | parent | is the parent inode number. |
| int rtems_rfs_symlink_read | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | link, | ||
| char * | path, | ||
| size_t | size, | ||
| size_t * | length ) |
Read a symbolic link into the provided buffer returning the link of link name.
| [in] | link | is the link inode number to read. |
| [in] | path | is a pointer to the buffer to write the link path into. |
| [in] | size | is the size of the buffer. |
| [out] | length | will contain the length of the link path. |
| int rtems_rfs_unlink | ( | rtems_rfs_file_system * | fs, |
| uint32_t | doff, | ||
| rtems_rfs_unlink_dir | dir_mode ) |
Unlink the node from the parent directory. A directory offset for the target entry is required because links cause a number of inode numbers to appear in a single directory so scanning does not work.
| [in] | doff | is the parent directory entry offset for the target entry. |
| [in] | dir_mode | is the directory unlink mode. |
