RTEMS
6.3
Toggle main menu visibility
libdebugger
rtems-debugger-smp.h
1
2
* Copyright (c) 2025 Chris Johns <chrisj@rtems.org>.
3
* All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
14
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24
* SUCH DAMAGE.
25
26
27
28
* Debugger for RTEMS.
29
30
31
#ifndef _RTEMS_DEBUGGER_SMP_h
32
#define _RTEMS_DEBUGGER_SMP_h
33
34
#ifdef __cplusplus
35
extern
"C"
36
#endif
/* __cplusplus */
37
38
39
* The function used to run a provided function with arbitrary argument across
40
* all cores registered to the current scheduler. This is similar to the Linux
41
* kernel's on_each_cpu() call and always waits for the task to complete before
42
* returning.
43
44
rtems_status_code
rtems_debugger_cpu_run_all(
45
rtems_task_entry
task_entry,
rtems_task_argument
arg);
46
47
#ifdef __cplusplus
48
49
#endif
/* __cplusplus */
50
51
#endif
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems_task_entry
rtems_task(*) rtems_task_entry(rtems_task_argument)
This type defines the task entry point of an RTEMS task.
Definition
tasks.h:239
rtems_task_argument
CPU_Uint32ptr rtems_task_argument
This integer type represents task argument values.
Definition
tasks.h:100
