RTEMS 6.3
reg_sys2.h
2
10
11/* The header file is generated by make_header.py from SYS2.json */
12/* Current script's version can be found at: */
13/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15/*
16 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17 *
18 * Czech Technical University in Prague
19 * Zikova 1903/4
20 * 166 36 Praha 6
21 * Czech Republic
22 *
23 * All rights reserved.
24 *
25 * Redistribution and use in source and binary forms, with or without
26 * modification, are permitted provided that the following conditions are met:
27 *
28 * 1. Redistributions of source code must retain the above copyright notice, this
29 * list of conditions and the following disclaimer.
30 * 2. Redistributions in binary form must reproduce the above copyright notice,
31 * this list of conditions and the following disclaimer in the documentation
32 * and/or other materials provided with the distribution.
33 *
34 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44 *
45 * The views and conclusions contained in the software and documentation are those
46 * of the authors and should not be interpreted as representing official policies,
47 * either expressed or implied, of the FreeBSD Project.
48*/
49#ifndef LIBBSP_ARM_TMS570_SYS2
50#define LIBBSP_ARM_TMS570_SYS2
51
52#include <bsp/utility.h>
53
54typedef struct{
55 uint32_t PLLCTL3; /*PLL Control Register 3*/
56 uint8_t reserved1 [4];
57 uint32_t STCCLKDIV; /*CPU Logic BIST Clock Divider*/
58 uint8_t reserved2 [24];
59 uint32_t ECPCNTL; /*ECP Control Register*/
60 uint8_t reserved3 [20];
61 uint32_t CLK2CNTRL; /*Clock 2 Control Register*/
62 uint32_t VCLKACON1; /*Peripheral Asynchronous Clock Configuration 1 Register*/
63 uint8_t reserved4 [16];
64 uint32_t HCLKCNTL; /* 0x0054 */
65 uint8_t reserved5 [24];
66 uint32_t CLKSLIP; /*Clock Slip Register*/
67 uint8_t reserved6 [120];
68 uint32_t EFC_CTLREG; /*EFUSE Controller Control Register*/
69 uint32_t DIEDL_REG0; /*Die Identification Register*/
70 uint32_t DIEDH_REG1; /*Die Identification Register*/
71 uint32_t DIEDL_REG2; /*Die Identification Register*/
72 uint32_t DIEDH_REG3; /*Die Identification Register*/
74
75
76/*--------------------TMS570_SYS2_PLLCTL3--------------------*/
77/* field: ODPLL2 - Internal PLL Output Divider */
78#define TMS570_SYS2_PLLCTL3_ODPLL2(val) BSP_FLD32(val,29, 31)
79#define TMS570_SYS2_PLLCTL3_ODPLL2_GET(reg) BSP_FLD32GET(reg,29, 31)
80#define TMS570_SYS2_PLLCTL3_ODPLL2_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
81
82/* field: PLLDIV2 - PLL2 Output Clock Divider */
83#define TMS570_SYS2_PLLCTL3_PLLDIV2(val) BSP_FLD32(val,24, 28)
84#define TMS570_SYS2_PLLCTL3_PLLDIV2_GET(reg) BSP_FLD32GET(reg,24, 28)
85#define TMS570_SYS2_PLLCTL3_PLLDIV2_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
86
87/* field: REFCLKDIV2 - REFCLKDIV2 */
88#define TMS570_SYS2_PLLCTL3_REFCLKDIV2(val) BSP_FLD32(val,16, 21)
89#define TMS570_SYS2_PLLCTL3_REFCLKDIV2_GET(reg) BSP_FLD32GET(reg,16, 21)
90#define TMS570_SYS2_PLLCTL3_REFCLKDIV2_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
91
92/* field: PLLMUL2 - PLL2 Multiplication Factor */
93#define TMS570_SYS2_PLLCTL3_PLLMUL2(val) BSP_FLD32(val,0, 15)
94#define TMS570_SYS2_PLLCTL3_PLLMUL2_GET(reg) BSP_FLD32GET(reg,0, 15)
95#define TMS570_SYS2_PLLCTL3_PLLMUL2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
96
97
98/*-------------------TMS570_SYS2_STCCLKDIV-------------------*/
99/* field: CLKDIV - Clock divider/prescaler for CPU clock during logic BIST */
100#define TMS570_SYS2_STCCLKDIV_CLKDIV(val) BSP_FLD32(val,24, 26)
101#define TMS570_SYS2_STCCLKDIV_CLKDIV_GET(reg) BSP_FLD32GET(reg,24, 26)
102#define TMS570_SYS2_STCCLKDIV_CLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
103
104
105/*--------------------TMS570_SYS2_ECPCNTL--------------------*/
106/* field: ECPSSEL - This bit allows the selection between VCLK and OSCIN as the clock source for ECLK. */
107#define TMS570_SYS2_ECPCNTL_ECPSSEL BSP_BIT32(24)
108
109/* field: ECPCOS - ECP continue on suspend. */
110#define TMS570_SYS2_ECPCNTL_ECPCOS BSP_BIT32(23)
111
112/* field: ECPINSEL - Select ECP input clock source. */
113#define TMS570_SYS2_ECPCNTL_ECPINSEL(val) BSP_FLD32(val,6, 17)
114#define TMS570_SYS2_ECPCNTL_ECPINSEL_GET(reg) BSP_FLD32GET(reg,6, 17)
115#define TMS570_SYS2_ECPCNTL_ECPINSEL_SET(reg,val) BSP_FLD32SET(reg, val,6, 17)
116
117/* field: ECPDIV - ECP divider value. */
118#define TMS570_SYS2_ECPCNTL_ECPDIV(val) BSP_FLD32(val,0, 15)
119#define TMS570_SYS2_ECPCNTL_ECPDIV_GET(reg) BSP_FLD32GET(reg,0, 15)
120#define TMS570_SYS2_ECPCNTL_ECPDIV_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
121
122
123/*-------------------TMS570_SYS2_CLK2CNTRL-------------------*/
124/* field: VCLK3R - VBUS clock3 ratio. */
125#define TMS570_SYS2_CLK2CNTRL_VCLK3R(val) BSP_FLD32(val,0, 3)
126#define TMS570_SYS2_CLK2CNTRL_VCLK3R_GET(reg) BSP_FLD32GET(reg,0, 3)
127#define TMS570_SYS2_CLK2CNTRL_VCLK3R_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
128
129
130/*-------------------TMS570_SYS2_VCLKACON1-------------------*/
131/* field: VCLKA4R - Clock divider for the VCLKA4 source. Output will be present on VCLKA4_DIVR. */
132#define TMS570_SYS2_VCLKACON1_VCLKA4R(val) BSP_FLD32(val,24, 26)
133#define TMS570_SYS2_VCLKACON1_VCLKA4R_GET(reg) BSP_FLD32GET(reg,24, 26)
134#define TMS570_SYS2_VCLKACON1_VCLKA4R_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
135
136/* field: VCLKA4_DIV_CDDIS - Disable the VCLKA4 divider output. */
137#define TMS570_SYS2_VCLKACON1_VCLKA4_DIV_CDDIS BSP_BIT32(20)
138
139/* field: VCLKA4S - Peripheral asynchronous clock4 source. */
140#define TMS570_SYS2_VCLKACON1_VCLKA4S(val) BSP_FLD32(val,16, 19)
141#define TMS570_SYS2_VCLKACON1_VCLKA4S_GET(reg) BSP_FLD32GET(reg,16, 19)
142#define TMS570_SYS2_VCLKACON1_VCLKA4S_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
143
144/* field: VCLKA3R - Clock divider for the VCLKA3 source. Output will be present on VCLKA3_DIVR. */
145#define TMS570_SYS2_VCLKACON1_VCLKA3R(val) BSP_FLD32(val,8, 10)
146#define TMS570_SYS2_VCLKACON1_VCLKA3R_GET(reg) BSP_FLD32GET(reg,8, 10)
147#define TMS570_SYS2_VCLKACON1_VCLKA3R_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
148
149/* field: VCLKA3_DIV_CDDIS - Disable the VCLKA3 divider output. */
150#define TMS570_SYS2_VCLKACON1_VCLKA3_DIV_CDDIS BSP_BIT32(4)
151
152/* field: VCLKA3S - Peripheral asynchronous clock3 source. */
153#define TMS570_SYS2_VCLKACON1_VCLKA3S(val) BSP_FLD32(val,0, 3)
154#define TMS570_SYS2_VCLKACON1_VCLKA3S_GET(reg) BSP_FLD32GET(reg,0, 3)
155#define TMS570_SYS2_VCLKACON1_VCLKA3S_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
156
157
158/*--------------------TMS570_SYS2_CLKSLIP--------------------*/
159/* field: PLL1_SLIP_FILTER_COUNT - Configure the count for the filtered PLL slip. Count is on 10M clock. */
160#define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT(val) BSP_FLD32(val,8, 13)
161#define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT_GET(reg) BSP_FLD32GET(reg,8, 13)
162#define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT_SET(reg,val) BSP_FLD32SET(reg, val,8, 13)
163
164/* field: PLL1_SLIP_FILTER_KEY - Enable the PLL filtering. */
165#define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY(val) BSP_FLD32(val,0, 3)
166#define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
167#define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
168
169
170/*-------------------TMS570_SYS2_EFC_CTLREG-------------------*/
171/* field: EFC_INSTR_WEN - Enable user write of 4 EFUSE controller instructions. */
172#define TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN(val) BSP_FLD32(val,0, 3)
173#define TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN_GET(reg) BSP_FLD32GET(reg,0, 3)
174#define TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
175
176
177/*-----------------------TMS570_SYS2_x-----------------------*/
178/* field: DIE - This read-only register contains the lower/upper word (31:0) of the die ID information. */
179/* Whole 32 bits */
180
181
182#endif /* LIBBSP_ARM_TMS570_SYS2 */
This header file provides utility macros for BSPs.
Definition reg_sys2.h:54
