RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
ti_herc
reg_pmm.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
/* The header file is generated by make_header.py from PMM.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_PMM
50
#define LIBBSP_ARM_TMS570_PMM
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t LOGICPDPWRCTRL0;
/*Logic Power Domain Control Register 0*/
56
uint8_t reserved1 [12];
57
uint32_t MEMPDPWRCTRL0;
/*Memory Power Domain Control Register 0*/
58
uint8_t reserved2 [12];
59
uint32_t PDCLKDISREG;
/*Power Domain Clock Disable Register*/
60
uint32_t PDCLKDISSETREG;
/*Power Domain Clock Disable Set Register*/
61
uint32_t PDCLKDISCLRREG;
/*Power Domain Clock Disable Clear Register*/
62
uint8_t reserved3 [20];
63
uint32_t LOGICPDPWRSTAT[4];
/*Logic Power Domain PD2 Power Status Registers*/
64
uint8_t reserved4 [48];
65
uint32_t MEMPDPWRSTAT[3];
/*Memory Power Domain RAM_PD1 Power Status Registers*/
66
uint8_t reserved5 [20];
67
uint32_t GLOBALCTRL1;
/*Global Control Register 1*/
68
uint8_t reserved6 [4];
69
uint32_t GLOBALSTAT;
/*Global Status Register*/
70
uint32_t PRCKEYREG;
/*PSCON Diagnostic Compare Key Register*/
71
uint32_t LPDDCSTAT1;
/*LogicPD PSCON Diagnostic Compare Status Register 1*/
72
uint32_t LPDDCSTAT2;
/*LogicPD PSCON Diagnostic Compare Status Register 2*/
73
uint32_t MPDDCSTAT1;
/*Memory PD PSCON Diagnostic Compare Status Register 1*/
74
uint32_t MPDDCSTAT2;
/*Memory PD PSCON Diagnostic Compare Status Register 2*/
75
uint32_t ISODIAGSTAT;
/*Isolation Diagnostic Status Register*/
76
tms570_pmm_t
77
78
79
/*-----------------TMS570_PMM_LOGICPDPWRCTRL0-----------------*/
80
/* field: LOGICPDON0 - Read in User and Privileged Mode. Write in Privileged Mode only. */
81
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON0(val) BSP_FLD32(val,24, 27)
82
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON0_GET(reg) BSP_FLD32GET(reg,24, 27)
83
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON0_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
84
85
/* field: LOGICPDON1 - Read in User and Privileged Mode. Write in Privileged Mode only. */
86
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON1(val) BSP_FLD32(val,16, 19)
87
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON1_GET(reg) BSP_FLD32GET(reg,16, 19)
88
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON1_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
89
90
/* field: LOGICPDON2 - Read in User and Privileged Mode. Write in Privileged Mode only. */
91
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON2(val) BSP_FLD32(val,8, 11)
92
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON2_GET(reg) BSP_FLD32GET(reg,8, 11)
93
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON2_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
94
95
/* field: LOGICPDON3 - Read in User and Privileged Mode. Write in Privileged Mode only. */
96
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON3(val) BSP_FLD32(val,0, 3)
97
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON3_GET(reg) BSP_FLD32GET(reg,0, 3)
98
#define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON3_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
99
100
101
/*------------------TMS570_PMM_MEMPDPWRCTRL0------------------*/
102
/* field: MEMPDON0 - Read in User and Privileged Mode. Write in Privileged Mode only. */
103
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON0(val) BSP_FLD32(val,24, 27)
104
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON0_GET(reg) BSP_FLD32GET(reg,24, 27)
105
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON0_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
106
107
/* field: MEMPDON1 - Read in User and Privileged Mode. Write in Privileged Mode only. */
108
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON1(val) BSP_FLD32(val,16, 19)
109
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON1_GET(reg) BSP_FLD32GET(reg,16, 19)
110
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON1_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
111
112
/* field: MEMPDON2 - Read in User and Privileged Mode. Write in Privileged Mode only. */
113
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON2(val) BSP_FLD32(val,8, 11)
114
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON2_GET(reg) BSP_FLD32GET(reg,8, 11)
115
#define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON2_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
116
117
118
/*-------------------TMS570_PMM_PDCLKDISREG-------------------*/
119
/* field: PDCLK_DIS_3 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[3]. */
120
#define TMS570_PMM_PDCLKDISREG_PDCLK_DIS_3 BSP_BIT32(3)
121
122
/* field: PDCLK_DIS_2 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[2]. */
123
#define TMS570_PMM_PDCLKDISREG_PDCLK_DIS_2 BSP_BIT32(2)
124
125
/* field: PDCLK_DIS_1 - ead in User and Privileged Mode returns the current value of PDCLK_DIS[1]. */
126
#define TMS570_PMM_PDCLKDISREG_PDCLK_DIS_1 BSP_BIT32(1)
127
128
/* field: PDCLK_DIS_0 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[0]. */
129
#define TMS570_PMM_PDCLKDISREG_PDCLK_DIS_0 BSP_BIT32(0)
130
131
132
/*-----------------TMS570_PMM_PDCLKDISSETREG-----------------*/
133
/* field: PDCLK_DISSET_3 - Read in User and Privileged Mode returns the current value of PDCLK_DISSET[3]. */
134
#define TMS570_PMM_PDCLKDISSETREG_PDCLK_DISSET_3 BSP_BIT32(3)
135
136
/* field: PDCLK_DISSET_2 - Privileged Mode only. */
137
#define TMS570_PMM_PDCLKDISSETREG_PDCLK_DISSET_2 BSP_BIT32(2)
138
139
/* field: PDCLK_DISSET_1 - Read in User and Privileged Mode returns the current value of PDCLK_DISSET[1]. */
140
#define TMS570_PMM_PDCLKDISSETREG_PDCLK_DISSET_1 BSP_BIT32(1)
141
142
/* field: PDCLK_DISSET_0 - Read in User and Privileged Mode returns the current value of PDCLK_DISSET[0]. */
143
#define TMS570_PMM_PDCLKDISSETREG_PDCLK_DISSET_0 BSP_BIT32(0)
144
145
146
/*-----------------TMS570_PMM_PDCLKDISCLRREG-----------------*/
147
/* field: PDCLK_DISCLR_3 - PDCLK_DISCLR[3] */
148
#define TMS570_PMM_PDCLKDISCLRREG_PDCLK_DISCLR_3 BSP_BIT32(3)
149
150
/* field: PDCLK_DISCLR_2 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[2]. */
151
#define TMS570_PMM_PDCLKDISCLRREG_PDCLK_DISCLR_2 BSP_BIT32(2)
152
153
/* field: PDCLK_DISCLR_1 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[1]. */
154
#define TMS570_PMM_PDCLKDISCLRREG_PDCLK_DISCLR_1 BSP_BIT32(1)
155
156
/* field: PDCLK_DISCLR_0 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[0]. */
157
#define TMS570_PMM_PDCLKDISCLRREG_PDCLK_DISCLR_0 BSP_BIT32(0)
158
159
160
/*-----------------TMS570_PMM_LOGICPDPWRSTAT-----------------*/
161
/* field: LOGIC_IN_TRANS0 - Logic in transition status for power domain PD2. */
162
#define TMS570_PMM_LOGICPDPWRSTAT_LOGIC_IN_TRANS0 BSP_BIT32(24)
163
164
/* field: MEM_IN_TRANS0 - Memory in transition status for power domain PD2. */
165
#define TMS570_PMM_LOGICPDPWRSTAT_MEM_IN_TRANS0 BSP_BIT32(16)
166
167
/* field: DOMAIN_ON0 - Current state of power domain PD2. */
168
#define TMS570_PMM_LOGICPDPWRSTAT_DOMAIN_ON0 BSP_BIT32(8)
169
170
/* field: LOGICPDPWR_STAT0 - Logic power domain PD2 power state. */
171
#define TMS570_PMM_LOGICPDPWRSTAT_LOGICPDPWR_STAT0(val) BSP_FLD32(val,0, 1)
172
#define TMS570_PMM_LOGICPDPWRSTAT_LOGICPDPWR_STAT0_GET(reg) BSP_FLD32GET(reg,0, 1)
173
#define TMS570_PMM_LOGICPDPWRSTAT_LOGICPDPWR_STAT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
174
175
176
/*------------------TMS570_PMM_MEMPDPWRSTAT------------------*/
177
/* field: LOGIC_IN_TRANS0 - Logic in transition status for power domain RAM_PD1. */
178
#define TMS570_PMM_MEMPDPWRSTAT_LOGIC_IN_TRANS0 BSP_BIT32(24)
179
180
/* field: MEM_IN_TRANS0 - Memory in transition status for power domain RAM_PD1. */
181
#define TMS570_PMM_MEMPDPWRSTAT_MEM_IN_TRANS0 BSP_BIT32(16)
182
183
/* field: DOMAIN_ON0 - Current state of power domain RAM_PD1. */
184
#define TMS570_PMM_MEMPDPWRSTAT_DOMAIN_ON0 BSP_BIT32(8)
185
186
/* field: MEMPDPWR_STAT0 - Memory power domain RAM_PD1 power state. */
187
#define TMS570_PMM_MEMPDPWRSTAT_MEMPDPWR_STAT0(val) BSP_FLD32(val,0, 1)
188
#define TMS570_PMM_MEMPDPWRSTAT_MEMPDPWR_STAT0_GET(reg) BSP_FLD32GET(reg,0, 1)
189
#define TMS570_PMM_MEMPDPWRSTAT_MEMPDPWR_STAT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
190
191
192
/*-------------------TMS570_PMM_GLOBALCTRL1-------------------*/
193
/* field: PMCTRL_PWRDN - PMC/PSCON Power Down */
194
#define TMS570_PMM_GLOBALCTRL1_PMCTRL_PWRDN BSP_BIT32(8)
195
196
/* field: AUTO_CLK_WAKE_ENA - Automatic Clock Enable on Wake Up */
197
#define TMS570_PMM_GLOBALCTRL1_AUTO_CLK_WAKE_ENA BSP_BIT32(0)
198
199
200
/*-------------------TMS570_PMM_GLOBALSTAT-------------------*/
201
/* field: PMCTRL_IDLE - State of PMC and all PSCONs. */
202
#define TMS570_PMM_GLOBALSTAT_PMCTRL_IDLE BSP_BIT32(0)
203
204
205
/*--------------------TMS570_PMM_PRCKEYREG--------------------*/
206
/* field: MKEY - Diagnostic PSCON Mode Key. The mode key is applied to all individual PSCON compare units. */
207
#define TMS570_PMM_PRCKEYREG_MKEY(val) BSP_FLD32(val,0, 3)
208
#define TMS570_PMM_PRCKEYREG_MKEY_GET(reg) BSP_FLD32GET(reg,0, 3)
209
#define TMS570_PMM_PRCKEYREG_MKEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
210
211
212
/*-------------------TMS570_PMM_LPDDCSTAT1-------------------*/
213
/* field: LCMPE - Logic Power Domain Compare Error */
214
#define TMS570_PMM_LPDDCSTAT1_LCMPE(val) BSP_FLD32(val,16, 19)
215
#define TMS570_PMM_LPDDCSTAT1_LCMPE_GET(reg) BSP_FLD32GET(reg,16, 19)
216
#define TMS570_PMM_LPDDCSTAT1_LCMPE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
217
218
/* field: LSTC - Logic Power Domain Self-test Complete */
219
#define TMS570_PMM_LPDDCSTAT1_LSTC(val) BSP_FLD32(val,0, 3)
220
#define TMS570_PMM_LPDDCSTAT1_LSTC_GET(reg) BSP_FLD32GET(reg,0, 3)
221
#define TMS570_PMM_LPDDCSTAT1_LSTC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
222
223
224
/*-------------------TMS570_PMM_LPDDCSTAT2-------------------*/
225
/* field: LSTET - Logic Power Domain Self-test Error Type */
226
#define TMS570_PMM_LPDDCSTAT2_LSTET(val) BSP_FLD32(val,16, 19)
227
#define TMS570_PMM_LPDDCSTAT2_LSTET_GET(reg) BSP_FLD32GET(reg,16, 19)
228
#define TMS570_PMM_LPDDCSTAT2_LSTET_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
229
230
/* field: LSTE - Logic Power Domain Self-test Error */
231
#define TMS570_PMM_LPDDCSTAT2_LSTE(val) BSP_FLD32(val,0, 3)
232
#define TMS570_PMM_LPDDCSTAT2_LSTE_GET(reg) BSP_FLD32GET(reg,0, 3)
233
#define TMS570_PMM_LPDDCSTAT2_LSTE_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
234
235
236
/*-------------------TMS570_PMM_MPDDCSTAT1-------------------*/
237
/* field: MCMPE - Memory Power Domain Compare Error */
238
#define TMS570_PMM_MPDDCSTAT1_MCMPE(val) BSP_FLD32(val,16, 18)
239
#define TMS570_PMM_MPDDCSTAT1_MCMPE_GET(reg) BSP_FLD32GET(reg,16, 18)
240
#define TMS570_PMM_MPDDCSTAT1_MCMPE_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
241
242
/* field: MSTC - Memory Power Domain Self-test Complete */
243
#define TMS570_PMM_MPDDCSTAT1_MSTC(val) BSP_FLD32(val,0, 2)
244
#define TMS570_PMM_MPDDCSTAT1_MSTC_GET(reg) BSP_FLD32GET(reg,0, 2)
245
#define TMS570_PMM_MPDDCSTAT1_MSTC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
246
247
248
/*-------------------TMS570_PMM_MPDDCSTAT2-------------------*/
249
/* field: MSTET - Memory Power Domain Self-test Error Type */
250
#define TMS570_PMM_MPDDCSTAT2_MSTET(val) BSP_FLD32(val,16, 18)
251
#define TMS570_PMM_MPDDCSTAT2_MSTET_GET(reg) BSP_FLD32GET(reg,16, 18)
252
#define TMS570_PMM_MPDDCSTAT2_MSTET_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
253
254
/* field: MSTE - Memory Power Domain Self-test Error */
255
#define TMS570_PMM_MPDDCSTAT2_MSTE(val) BSP_FLD32(val,0, 2)
256
#define TMS570_PMM_MPDDCSTAT2_MSTE_GET(reg) BSP_FLD32GET(reg,0, 2)
257
#define TMS570_PMM_MPDDCSTAT2_MSTE_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
258
259
260
/*-------------------TMS570_PMM_ISODIAGSTAT-------------------*/
261
/* field: ISO_DIAG - Isolation Diagnostic */
262
#define TMS570_PMM_ISODIAGSTAT_ISO_DIAG(val) BSP_FLD32(val,0, 3)
263
#define TMS570_PMM_ISODIAGSTAT_ISO_DIAG_GET(reg) BSP_FLD32GET(reg,0, 3)
264
#define TMS570_PMM_ISODIAGSTAT_ISO_DIAG_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
265
266
267
268
#endif
/* LIBBSP_ARM_TMS570_PMM */
utility.h
This header file provides utility macros for BSPs.
tms570_pmm_t
Definition
reg_pmm.h:54
