RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
ti_herc
reg_mdio.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
/* The header file is generated by make_header.py from MDIO.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_MDIO
50
#define LIBBSP_ARM_TMS570_MDIO
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t REVID;
/*MDIO Revision ID Register*/
56
uint32_t CONTROL;
/*MDIO Control Register*/
57
uint32_t ALIVE;
/*PHY Alive Status register*/
58
uint32_t LINK;
/*PHY Link Status Register*/
59
uint32_t LINKINTRAW;
/*MDIO Link Status Change Interrupt (Unmasked) Register*/
60
uint32_t LINKINTMASKED;
/*MDIO Link Status Change Interrupt (Masked) Register*/
61
uint8_t reserved1 [8];
62
uint32_t USERINTRAW;
/*MDIO User Command Complete Interrupt (Unmasked) Register*/
63
uint32_t USERINTMASKED;
/*MDIO User Command Complete Interrupt (Masked) Register*/
64
uint32_t USERINTMASKSET;
/*MDIO User Command Complete Interrupt Mask Set Register*/
65
uint32_t USERINTMASKCLEAR;
/*MDIO User Command Complete Interrupt Mask Clear Register*/
66
uint8_t reserved2 [80];
67
uint32_t USERACCESS0;
/*MDIO User Access Register 0*/
68
uint32_t USERPHYSEL0;
/*MDIO User PHY Select Register 0*/
69
uint32_t USERACCESS1;
/*MDIO User Access Register 1*/
70
uint32_t USERPHYSEL1;
/*MDIO User PHY Select Register 1*/
71
tms570_mdio_t
72
73
74
/*---------------------TMS570_MDIO_REVID---------------------*/
75
/* field: REV - Identifies the MDIO Module revision. */
76
/* Whole 32 bits */
77
78
/*--------------------TMS570_MDIO_CONTROL--------------------*/
79
/* field: IDLE - State machine IDLE status bit. */
80
#define TMS570_MDIO_CONTROL_IDLE BSP_BIT32(31)
81
82
/* field: ENABLE - State machine enable control bit. */
83
#define TMS570_MDIO_CONTROL_ENABLE BSP_BIT32(30)
84
85
/* field: HIGHEST_USER_CHANNEL - Highest user channel that is available in the module. It is currently set to 1. */
86
#define TMS570_MDIO_CONTROL_HIGHEST_USER_CHANNEL(val) BSP_FLD32(val,24, 28)
87
#define TMS570_MDIO_CONTROL_HIGHEST_USER_CHANNEL_GET(reg) BSP_FLD32GET(reg,24, 28)
88
#define TMS570_MDIO_CONTROL_HIGHEST_USER_CHANNEL_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
89
90
/* field: PREAMBLE - Preamble disable */
91
#define TMS570_MDIO_CONTROL_PREAMBLE BSP_BIT32(20)
92
93
/* field: FAULT - Fault indicator. */
94
#define TMS570_MDIO_CONTROL_FAULT BSP_BIT32(19)
95
96
/* field: FAULTENB - Fault detect enable. */
97
#define TMS570_MDIO_CONTROL_FAULTENB BSP_BIT32(18)
98
99
/* field: CLKDIV - Clock Divider bits. */
100
#define TMS570_MDIO_CONTROL_CLKDIV(val) BSP_FLD32(val,0, 15)
101
#define TMS570_MDIO_CONTROL_CLKDIV_GET(reg) BSP_FLD32GET(reg,0, 15)
102
#define TMS570_MDIO_CONTROL_CLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
103
104
105
/*---------------------TMS570_MDIO_ALIVE---------------------*/
106
/* field: ALIVE - MDIO Alive bits. */
107
/* Whole 32 bits */
108
109
/*----------------------TMS570_MDIO_LINK----------------------*/
110
/* field: LINK - MDIO Link state bits. This register is updated after a read of the generic status register of a PHY. */
111
/* Whole 32 bits */
112
113
/*-------------------TMS570_MDIO_LINKINTRAW-------------------*/
114
/* field: USERPHY1 - MDIO Link change event, raw value. */
115
#define TMS570_MDIO_LINKINTRAW_USERPHY1 BSP_BIT32(1)
116
117
/* field: USERPHY0 - MDIO Link change event, raw value. */
118
#define TMS570_MDIO_LINKINTRAW_USERPHY0 BSP_BIT32(0)
119
120
121
/*-----------------TMS570_MDIO_LINKINTMASKED-----------------*/
122
/* field: USERPHY1 - MDIO Link change interrupt, masked value. */
123
#define TMS570_MDIO_LINKINTMASKED_USERPHY1 BSP_BIT32(1)
124
125
/* field: USERPHY0 - MDIO Link change interrupt, masked value. */
126
#define TMS570_MDIO_LINKINTMASKED_USERPHY0 BSP_BIT32(0)
127
128
129
/*-------------------TMS570_MDIO_USERINTRAW-------------------*/
130
/* field: USERACCESS1 - MDIO User command complete event bit. */
131
#define TMS570_MDIO_USERINTRAW_USERACCESS1 BSP_BIT32(1)
132
133
/* field: USERACCESS0 - MDIO User command complete event bit. */
134
#define TMS570_MDIO_USERINTRAW_USERACCESS0 BSP_BIT32(0)
135
136
137
/*-----------------TMS570_MDIO_USERINTMASKED-----------------*/
138
/* field: USERACCESS1 - Masked value of MDIO User command complete interrupt. */
139
#define TMS570_MDIO_USERINTMASKED_USERACCESS1 BSP_BIT32(1)
140
141
/* field: USERACCESS0 - Masked value of MDIO User command complete interrupt. */
142
#define TMS570_MDIO_USERINTMASKED_USERACCESS0 BSP_BIT32(0)
143
144
145
/*-----------------TMS570_MDIO_USERINTMASKSET-----------------*/
146
/* field: USERACCESS1 - MDIO user interrupt mask set for USERINTMASKED[1]. */
147
#define TMS570_MDIO_USERINTMASKSET_USERACCESS1 BSP_BIT32(1)
148
149
/* field: USERACCESS0 - MDIO user interrupt mask set for USERINTMASKED[0]. */
150
#define TMS570_MDIO_USERINTMASKSET_USERACCESS0 BSP_BIT32(0)
151
152
153
/*----------------TMS570_MDIO_USERINTMASKCLEAR----------------*/
154
/* field: USERACCESS1 - MDIO user command complete interrupt mask clear for USERINTMASKED[1]. */
155
#define TMS570_MDIO_USERINTMASKCLEAR_USERACCESS1 BSP_BIT32(1)
156
157
/* field: USERACCESS0 - MDIO user command complete interrupt mask clear for USERINTMASKED[0]. */
158
#define TMS570_MDIO_USERINTMASKCLEAR_USERACCESS0 BSP_BIT32(0)
159
160
161
/*------------------TMS570_MDIO_USERACCESS0------------------*/
162
/* field: GO - Go bit. */
163
#define TMS570_MDIO_USERACCESS0_GO BSP_BIT32(31)
164
165
/* field: WRITE - Write enable bit. */
166
#define TMS570_MDIO_USERACCESS0_WRITE BSP_BIT32(30)
167
168
/* field: ACK - Acknowledge bit. This bit is set if the PHY acknowledged the read transaction. */
169
#define TMS570_MDIO_USERACCESS0_ACK BSP_BIT32(29)
170
171
/* field: REGADR - Register address bits. */
172
#define TMS570_MDIO_USERACCESS0_REGADR(val) BSP_FLD32(val,21, 25)
173
#define TMS570_MDIO_USERACCESS0_REGADR_GET(reg) BSP_FLD32GET(reg,21, 25)
174
#define TMS570_MDIO_USERACCESS0_REGADR_SET(reg,val) BSP_FLD32SET(reg, val,21, 25)
175
176
/* field: PHYADR - PHY address bits. This field specifies the PHY to be accessed for this transaction. */
177
#define TMS570_MDIO_USERACCESS0_PHYADR(val) BSP_FLD32(val,16, 20)
178
#define TMS570_MDIO_USERACCESS0_PHYADR_GET(reg) BSP_FLD32GET(reg,16, 20)
179
#define TMS570_MDIO_USERACCESS0_PHYADR_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
180
181
/* field: DATA - User data bits. */
182
#define TMS570_MDIO_USERACCESS0_DATA(val) BSP_FLD32(val,0, 15)
183
#define TMS570_MDIO_USERACCESS0_DATA_GET(reg) BSP_FLD32GET(reg,0, 15)
184
#define TMS570_MDIO_USERACCESS0_DATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
185
186
187
/*------------------TMS570_MDIO_USERPHYSEL0------------------*/
188
/* field: LINKSEL - Link status determination select bit. */
189
#define TMS570_MDIO_USERPHYSEL0_LINKSEL BSP_BIT32(7)
190
191
/* field: LINKINTENB - Link change interrupt enable. */
192
#define TMS570_MDIO_USERPHYSEL0_LINKINTENB BSP_BIT32(6)
193
194
/* field: PHYADRMON - PHY address whose link status is to be monitored. */
195
#define TMS570_MDIO_USERPHYSEL0_PHYADRMON(val) BSP_FLD32(val,0, 4)
196
#define TMS570_MDIO_USERPHYSEL0_PHYADRMON_GET(reg) BSP_FLD32GET(reg,0, 4)
197
#define TMS570_MDIO_USERPHYSEL0_PHYADRMON_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
198
199
200
/*------------------TMS570_MDIO_USERACCESS1------------------*/
201
202
#define TMS570_MDIO_USERACCESS1_GO BSP_BIT32(31)
203
204
205
#define TMS570_MDIO_USERACCESS1_WRITE BSP_BIT32(30)
206
207
208
#define TMS570_MDIO_USERACCESS1_ACK BSP_BIT32(29)
209
210
211
#define TMS570_MDIO_USERACCESS1_REGADR(val) BSP_FLD32(val,21, 25)
212
#define TMS570_MDIO_USERACCESS1_REGADR_GET(reg) BSP_FLD32GET(reg,21, 25)
213
#define TMS570_MDIO_USERACCESS1_REGADR_SET(reg,val) BSP_FLD32SET(reg, val,21, 25)
214
215
216
#define TMS570_MDIO_USERACCESS1_PHYADR(val) BSP_FLD32(val,16, 20)
217
#define TMS570_MDIO_USERACCESS1_PHYADR_GET(reg) BSP_FLD32GET(reg,16, 20)
218
#define TMS570_MDIO_USERACCESS1_PHYADR_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
219
220
221
#define TMS570_MDIO_USERACCESS1_DATA(val) BSP_FLD32(val,0, 15)
222
#define TMS570_MDIO_USERACCESS1_DATA_GET(reg) BSP_FLD32GET(reg,0, 15)
223
#define TMS570_MDIO_USERACCESS1_DATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
224
225
226
/*------------------TMS570_MDIO_USERPHYSEL1------------------*/
227
228
#define TMS570_MDIO_USERPHYSEL1_LINKSEL BSP_BIT32(7)
229
230
231
#define TMS570_MDIO_USERPHYSEL1_LINKINTENB BSP_BIT32(6)
232
233
234
#define TMS570_MDIO_USERPHYSEL1_PHYADRMON(val) BSP_FLD32(val,0, 4)
235
#define TMS570_MDIO_USERPHYSEL1_PHYADRMON_GET(reg) BSP_FLD32GET(reg,0, 4)
236
#define TMS570_MDIO_USERPHYSEL1_PHYADRMON_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
237
238
239
240
#endif
/* LIBBSP_ARM_TMS570_MDIO */
utility.h
This header file provides utility macros for BSPs.
tms570_mdio_t
Definition
reg_mdio.h:54
