RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
ti_herc
reg_emacm.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
/* The header file is generated by make_header.py from EMACM.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_EMACM
50
#define LIBBSP_ARM_TMS570_EMACM
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t TXREVID;
/*Transmit Revision ID Register*/
56
uint32_t TXCONTROL;
/*Transmit Control Register*/
57
uint32_t TXTEARDOWN;
/*Transmit Teardown Register*/
58
uint8_t reserved1 [4];
59
uint32_t RXREVID;
/*Receive Revision ID Register*/
60
uint32_t RXCONTROL;
/*Receive Control Register*/
61
uint32_t RXTEARDOWN;
/*Receive Teardown Register*/
62
uint8_t reserved2 [100];
63
uint32_t TXINTSTATRAW;
/*Transmit Interrupt Status (Unmasked) Register*/
64
uint32_t TXINTSTATMASKED;
/*Transmit Interrupt Status (Masked) Register*/
65
uint32_t TXINTMASKSET;
/*Transmit Interrupt Mask Set Register*/
66
uint32_t TXINTMASKCLEAR;
/*Transmit Interrupt Clear Register*/
67
uint32_t MACINVECTOR;
/*MAC Input Vector Register*/
68
uint32_t MACEOIVECTOR;
/*MAC End Of Interrupt Vector Register*/
69
uint8_t reserved3 [8];
70
uint32_t RXINTSTATRAW;
/*Receive Interrupt Status (Unmasked) Register*/
71
uint32_t RXINTSTATMASKED;
/*Receive Interrupt Status (Masked) Register*/
72
uint32_t RXINTMASKSET;
/*Receive Interrupt Mask Set Register*/
73
uint32_t RXINTMASKCLEAR;
/*Receive Interrupt Mask Clear Register*/
74
uint32_t MACINTSTATRAW;
/*MAC Interrupt Status (Unmasked) Register*/
75
uint32_t MACINTSTATMASKED;
/*MAC Interrupt Status (Masked) Register*/
76
uint32_t MACINTMASKSET;
/*MAC Interrupt Mask Set Register*/
77
uint32_t MACINTMASKCLEAR;
/*MAC Interrupt Mask Clear Register*/
78
uint8_t reserved4 [64];
79
uint32_t RXMBPENABLE;
/*Receive Multicast/Broadcast/Promiscuous Channel Enable*/
80
uint32_t RXUNICASTSET;
/*Receive Unicast Enable Set Register*/
81
uint32_t RXUNICASTCLEAR;
/*Receive Unicast Clear Register*/
82
uint32_t RXMAXLEN;
/*Receive Maximum Length Register*/
83
uint32_t RXBUFFEROFFSET;
/*Receive Buffer Offset Register*/
84
uint32_t RXFILTERLOWTHRESH;
/*Receive Filter Low Priority Frame Threshold Register*/
85
uint8_t reserved5 [8];
86
uint32_t RXFLOWTHRESH[8];
/*Receive Channel Flow Control Threshold Register*/
87
uint32_t RXFREEBUFFER[8];
/*Receive Channel Free Buffer Count Register*/
88
uint32_t MACCONTROL;
/*MAC Control Register*/
89
uint32_t MACSTATUS;
/*MAC Status Register*/
90
uint32_t EMCONTROL;
/*Emulation Control Register*/
91
uint32_t FIFOCONTROL;
/*FIFO Control Register*/
92
uint32_t MACCONFIG;
/*MAC Configuration Register*/
93
uint32_t SOFTRESET;
/*Soft Reset Register*/
94
uint8_t reserved6 [88];
95
uint32_t MACSRCADDRLO;
/*MAC Source Address Low Bytes Register*/
96
uint32_t MACSRCADDRHI;
/*MAC Source Address High Bytes Register*/
97
uint32_t MACHASH1;
/*MAC Hash Address Register 1*/
98
uint32_t MACHASH2;
/*MAC Hash Address Register 2*/
99
uint32_t BOFFTEST;
/*Back Off Test Register*/
100
uint32_t TPACETEST;
/*Transmit Pacing Algorithm Test Register*/
101
uint32_t RXPAUSE;
/*Receive Pause Timer Register*/
102
uint32_t TXPAUSE;
/*Transmit Pause Timer Register*/
103
uint8_t reserved7 [784];
104
uint32_t MACADDRLO;
/*MAC Address Low Bytes Register*/
105
uint32_t MACADDRHI;
/*MAC Address High Bytes Register*/
106
uint32_t MACINDEX;
/*MAC Index Register*/
107
uint8_t reserved8 [244];
108
uint32_t TXHDP[8];
/*Transmit Channel DMA Head Descriptor Pointer Register*/
109
uint32_t RXHDP[8];
/*Receive Channel DMA Head Descriptor Pointer Register*/
110
uint32_t TXCP[8];
/*Transmit Channel Completion Pointer Register*/
111
uint32_t RXCP[8];
/*Receive Channel Completion Pointer Register*/
112
tms570_emacm_t
113
114
115
/*--------------------TMS570_EMACM_TXREVID--------------------*/
116
/* field: TXREV - Transmit module revision */
117
/* Whole 32 bits */
118
119
/*-------------------TMS570_EMACM_TXCONTROL-------------------*/
120
/* field: TXEN - Transmit enable */
121
#define TMS570_EMACM_TXCONTROL_TXEN BSP_BIT32(0)
122
123
124
/*------------------TMS570_EMACM_TXTEARDOWN------------------*/
125
/* field: TXTDNCH - Transmit teardown channel. */
126
#define TMS570_EMACM_TXTEARDOWN_TXTDNCH(val) BSP_FLD32(val,0, 2)
127
#define TMS570_EMACM_TXTEARDOWN_TXTDNCH_GET(reg) BSP_FLD32GET(reg,0, 2)
128
#define TMS570_EMACM_TXTEARDOWN_TXTDNCH_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
129
130
131
/*--------------------TMS570_EMACM_RXREVID--------------------*/
132
/* field: RXREV - Receive module revision */
133
/* Whole 32 bits */
134
135
/*-------------------TMS570_EMACM_RXCONTROL-------------------*/
136
/* field: RXEN - Receive enable */
137
#define TMS570_EMACM_RXCONTROL_RXEN BSP_BIT32(0)
138
139
140
/*------------------TMS570_EMACM_RXTEARDOWN------------------*/
141
/* field: RXTDNCH - Receive teardown channel. */
142
#define TMS570_EMACM_RXTEARDOWN_RXTDNCH(val) BSP_FLD32(val,0, 2)
143
#define TMS570_EMACM_RXTEARDOWN_RXTDNCH_GET(reg) BSP_FLD32GET(reg,0, 2)
144
#define TMS570_EMACM_RXTEARDOWN_RXTDNCH_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
145
146
147
/*-----------------TMS570_EMACM_TXINTSTATRAW-----------------*/
148
/* field: TX7PEND - TX7PEND raw interrupt read (before mask) */
149
#define TMS570_EMACM_TXINTSTATRAW_TX7PEND BSP_BIT32(7)
150
151
/* field: TX6PEND - TX6PEND raw interrupt read (before mask) */
152
#define TMS570_EMACM_TXINTSTATRAW_TX6PEND BSP_BIT32(6)
153
154
/* field: TX5PEND - TX5PEND raw interrupt read (before mask) */
155
#define TMS570_EMACM_TXINTSTATRAW_TX5PEND BSP_BIT32(5)
156
157
/* field: TX4PEND - X4PEND raw interrupt read (before mask) */
158
#define TMS570_EMACM_TXINTSTATRAW_TX4PEND BSP_BIT32(4)
159
160
/* field: TX3PEND - TX3PEND raw interrupt read (before mask) */
161
#define TMS570_EMACM_TXINTSTATRAW_TX3PEND BSP_BIT32(3)
162
163
/* field: TX2PEND - TX2PEND raw interrupt read (before mask) */
164
#define TMS570_EMACM_TXINTSTATRAW_TX2PEND BSP_BIT32(2)
165
166
/* field: TX1PEND - TX1PEND raw interrupt read (before mask) */
167
#define TMS570_EMACM_TXINTSTATRAW_TX1PEND BSP_BIT32(1)
168
169
/* field: TX0PEND - TX0PEND raw interrupt read (before mask) */
170
#define TMS570_EMACM_TXINTSTATRAW_TX0PEND BSP_BIT32(0)
171
172
173
/*----------------TMS570_EMACM_TXINTSTATMASKED----------------*/
174
/* field: TX7PEND - TX7PEND masked interrupt read */
175
#define TMS570_EMACM_TXINTSTATMASKED_TX7PEND BSP_BIT32(7)
176
177
/* field: TX6PEND - TX6PEND masked interrupt read */
178
#define TMS570_EMACM_TXINTSTATMASKED_TX6PEND BSP_BIT32(6)
179
180
/* field: TX5PEND - TX5PEND masked interrupt read */
181
#define TMS570_EMACM_TXINTSTATMASKED_TX5PEND BSP_BIT32(5)
182
183
/* field: TX4PEND - TX4PEND masked interrupt read */
184
#define TMS570_EMACM_TXINTSTATMASKED_TX4PEND BSP_BIT32(4)
185
186
/* field: TX3PEND - TX3PEND masked interrupt read */
187
#define TMS570_EMACM_TXINTSTATMASKED_TX3PEND BSP_BIT32(3)
188
189
/* field: TX2PEND - TX2PEND masked interrupt read */
190
#define TMS570_EMACM_TXINTSTATMASKED_TX2PEND BSP_BIT32(2)
191
192
/* field: TX1PEND - TX1PEND masked interrupt read */
193
#define TMS570_EMACM_TXINTSTATMASKED_TX1PEND BSP_BIT32(1)
194
195
/* field: TX0PEND - TX0PEND masked interrupt read */
196
#define TMS570_EMACM_TXINTSTATMASKED_TX0PEND BSP_BIT32(0)
197
198
199
/*-----------------TMS570_EMACM_TXINTMASKSET-----------------*/
200
/* field: TX7MASK - Transmit channel 7 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
201
#define TMS570_EMACM_TXINTMASKSET_TX7MASK BSP_BIT32(7)
202
203
/* field: TX6MASK - Transmit channel 6 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
204
#define TMS570_EMACM_TXINTMASKSET_TX6MASK BSP_BIT32(6)
205
206
/* field: TX5MASK - Transmit channel 5 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
207
#define TMS570_EMACM_TXINTMASKSET_TX5MASK BSP_BIT32(5)
208
209
/* field: TX4MASK - Transmit channel 4 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
210
#define TMS570_EMACM_TXINTMASKSET_TX4MASK BSP_BIT32(4)
211
212
/* field: TX3MASK - Transmit channel 3 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
213
#define TMS570_EMACM_TXINTMASKSET_TX3MASK BSP_BIT32(3)
214
215
/* field: TX2MASK - Transmit channel 2 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
216
#define TMS570_EMACM_TXINTMASKSET_TX2MASK BSP_BIT32(2)
217
218
/* field: TX1MASK - Transmit channel 1 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
219
#define TMS570_EMACM_TXINTMASKSET_TX1MASK BSP_BIT32(1)
220
221
/* field: TX0MASK - Transmit channel 0 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
222
#define TMS570_EMACM_TXINTMASKSET_TX0MASK BSP_BIT32(0)
223
224
225
/*----------------TMS570_EMACM_TXINTMASKCLEAR----------------*/
226
/* field: TX7MASK - Transmit channel 7 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
227
#define TMS570_EMACM_TXINTMASKCLEAR_TX7MASK BSP_BIT32(7)
228
229
/* field: TX6MASK - Transmit channel 6 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
230
#define TMS570_EMACM_TXINTMASKCLEAR_TX6MASK BSP_BIT32(6)
231
232
/* field: TX5MASK - Transmit channel 5 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
233
#define TMS570_EMACM_TXINTMASKCLEAR_TX5MASK BSP_BIT32(5)
234
235
/* field: TX4MASK - Transmit channel 4 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
236
#define TMS570_EMACM_TXINTMASKCLEAR_TX4MASK BSP_BIT32(4)
237
238
/* field: TX3MASK - Transmit channel 3 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
239
#define TMS570_EMACM_TXINTMASKCLEAR_TX3MASK BSP_BIT32(3)
240
241
/* field: TX2MASK - Transmit channel 2 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
242
#define TMS570_EMACM_TXINTMASKCLEAR_TX2MASK BSP_BIT32(2)
243
244
/* field: TX1MASK - Transmit channel 1 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
245
#define TMS570_EMACM_TXINTMASKCLEAR_TX1MASK BSP_BIT32(1)
246
247
/* field: TX0MASK - Transmit channel 0 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
248
#define TMS570_EMACM_TXINTMASKCLEAR_TX0MASK BSP_BIT32(0)
249
250
251
/*------------------TMS570_EMACM_MACINVECTOR------------------*/
252
/* field: STATPEND - EMAC module statistics interrupt (STATPEND) pending status bit */
253
#define TMS570_EMACM_MACINVECTOR_STATPEND BSP_BIT32(27)
254
255
/* field: HOSTPEND - EMAC module host error interrupt (HOSTPEND) pending status bit */
256
#define TMS570_EMACM_MACINVECTOR_HOSTPEND BSP_BIT32(26)
257
258
/* field: LINKINT0 - MDIO module USERPHYSEL0 (LINKINT0) status bit */
259
#define TMS570_EMACM_MACINVECTOR_LINKINT0 BSP_BIT32(25)
260
261
/* field: USERINT0 - MDIO module USERACCESS0 (USERINT0) status bit */
262
#define TMS570_EMACM_MACINVECTOR_USERINT0 BSP_BIT32(24)
263
264
/* field: TXPEND - Transmit channels 0-7 interrupt (TXnPEND) pending status. Bit 16 is TX0PEND. */
265
#define TMS570_EMACM_MACINVECTOR_TXPEND(val) BSP_FLD32(val,16, 23)
266
#define TMS570_EMACM_MACINVECTOR_TXPEND_GET(reg) BSP_FLD32GET(reg,16, 23)
267
#define TMS570_EMACM_MACINVECTOR_TXPEND_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
268
269
/* field: RXTHRESHPEND - Receive channels 0-7 interrupt (RXnTHRESHPEND) pending status. */
270
#define TMS570_EMACM_MACINVECTOR_RXTHRESHPEND(val) BSP_FLD32(val,8, 15)
271
#define TMS570_EMACM_MACINVECTOR_RXTHRESHPEND_GET(reg) BSP_FLD32GET(reg,8, 15)
272
#define TMS570_EMACM_MACINVECTOR_RXTHRESHPEND_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
273
274
/* field: RXPEND - Receive channels 0-7 interrupt (RXnPEND) pending status bit. Bit 0 is RX0PEND. */
275
#define TMS570_EMACM_MACINVECTOR_RXPEND(val) BSP_FLD32(val,0, 7)
276
#define TMS570_EMACM_MACINVECTOR_RXPEND_GET(reg) BSP_FLD32GET(reg,0, 7)
277
#define TMS570_EMACM_MACINVECTOR_RXPEND_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
278
279
280
/*-----------------TMS570_EMACM_MACEOIVECTOR-----------------*/
281
/* field: INTVECT - Acknowledge EMAC Control Module Interrupts */
282
#define TMS570_EMACM_MACEOIVECTOR_INTVECT(val) BSP_FLD32(val,0, 4)
283
#define TMS570_EMACM_MACEOIVECTOR_INTVECT_GET(reg) BSP_FLD32GET(reg,0, 4)
284
#define TMS570_EMACM_MACEOIVECTOR_INTVECT_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
285
286
287
/*-----------------TMS570_EMACM_RXINTSTATRAW-----------------*/
288
/* field: RX7THRESHPEND - RX7THRESHPEND raw interrupt read (before mask) */
289
#define TMS570_EMACM_RXINTSTATRAW_RX7THRESHPEND BSP_BIT32(15)
290
291
/* field: RX6THRESHPEND - RX6THRESHPEND raw interrupt read (before mask) */
292
#define TMS570_EMACM_RXINTSTATRAW_RX6THRESHPEND BSP_BIT32(14)
293
294
/* field: RX5THRESHPEND - RX5THRESHPEND raw interrupt read (before mask) */
295
#define TMS570_EMACM_RXINTSTATRAW_RX5THRESHPEND BSP_BIT32(13)
296
297
/* field: RX4THRESHPEND - RX4THRESHPEND raw interrupt read (before mask) */
298
#define TMS570_EMACM_RXINTSTATRAW_RX4THRESHPEND BSP_BIT32(12)
299
300
/* field: RX3THRESHPEND - RX3THRESHPEND raw interrupt read (before mask) */
301
#define TMS570_EMACM_RXINTSTATRAW_RX3THRESHPEND BSP_BIT32(11)
302
303
/* field: RX2THRESHPEND - RX2THRESHPEND raw interrupt read (before mask) */
304
#define TMS570_EMACM_RXINTSTATRAW_RX2THRESHPEND BSP_BIT32(10)
305
306
/* field: RX1THRESHPEND - RX1THRESHPEND raw interrupt read (before mask) */
307
#define TMS570_EMACM_RXINTSTATRAW_RX1THRESHPEND BSP_BIT32(9)
308
309
/* field: RX0THRESHPEND - RX0THRESHPEND raw interrupt read (before mask) */
310
#define TMS570_EMACM_RXINTSTATRAW_RX0THRESHPEND BSP_BIT32(8)
311
312
/* field: RX7PEND - RX7PEND raw interrupt read (before mask) */
313
#define TMS570_EMACM_RXINTSTATRAW_RX7PEND BSP_BIT32(7)
314
315
/* field: RX6PEND - RX6PEND raw interrupt read (before mask) */
316
#define TMS570_EMACM_RXINTSTATRAW_RX6PEND BSP_BIT32(6)
317
318
/* field: RX5PEND - RX5PEND raw interrupt read (before mask) */
319
#define TMS570_EMACM_RXINTSTATRAW_RX5PEND BSP_BIT32(5)
320
321
/* field: RX4PEND - RX4PEND raw interrupt read (before mask) */
322
#define TMS570_EMACM_RXINTSTATRAW_RX4PEND BSP_BIT32(4)
323
324
/* field: RX3PEND - RX3PEND raw interrupt read (before mask) */
325
#define TMS570_EMACM_RXINTSTATRAW_RX3PEND BSP_BIT32(3)
326
327
/* field: RX2PEND - RX2PEND raw interrupt read (before mask) */
328
#define TMS570_EMACM_RXINTSTATRAW_RX2PEND BSP_BIT32(2)
329
330
/* field: RX1PEND - RX1PEND raw interrupt read (before mask) */
331
#define TMS570_EMACM_RXINTSTATRAW_RX1PEND BSP_BIT32(1)
332
333
/* field: RX0PEND - RX0PEND raw interrupt read (before mask) */
334
#define TMS570_EMACM_RXINTSTATRAW_RX0PEND BSP_BIT32(0)
335
336
337
/*----------------TMS570_EMACM_RXINTSTATMASKED----------------*/
338
/* field: RX7THRESHPEND - RX7THRESHPEND masked interrupt read */
339
#define TMS570_EMACM_RXINTSTATMASKED_RX7THRESHPEND BSP_BIT32(15)
340
341
/* field: RX6THRESHPEND - RX6THRESHPEND masked interrupt read */
342
#define TMS570_EMACM_RXINTSTATMASKED_RX6THRESHPEND BSP_BIT32(14)
343
344
/* field: RX5THRESHPEND - RX5THRESHPEND masked interrupt read */
345
#define TMS570_EMACM_RXINTSTATMASKED_RX5THRESHPEND BSP_BIT32(13)
346
347
/* field: RX4THRESHPEND - RX4THRESHPEND masked interrupt read */
348
#define TMS570_EMACM_RXINTSTATMASKED_RX4THRESHPEND BSP_BIT32(12)
349
350
/* field: RX3THRESHPEND - RX3THRESHPEND masked interrupt read */
351
#define TMS570_EMACM_RXINTSTATMASKED_RX3THRESHPEND BSP_BIT32(11)
352
353
/* field: RX2THRESHPEND - RX2THRESHPEND masked interrupt read */
354
#define TMS570_EMACM_RXINTSTATMASKED_RX2THRESHPEND BSP_BIT32(10)
355
356
/* field: RX1THRESHPEND - RX1THRESHPEND masked interrupt read */
357
#define TMS570_EMACM_RXINTSTATMASKED_RX1THRESHPEND BSP_BIT32(9)
358
359
/* field: RX0THRESHPEND - RX0THRESHPEND masked interrupt read */
360
#define TMS570_EMACM_RXINTSTATMASKED_RX0THRESHPEND BSP_BIT32(8)
361
362
/* field: RX7PEND - RX7PEND masked interrupt read */
363
#define TMS570_EMACM_RXINTSTATMASKED_RX7PEND BSP_BIT32(7)
364
365
/* field: RX6PEND - RX6PEND masked interrupt read */
366
#define TMS570_EMACM_RXINTSTATMASKED_RX6PEND BSP_BIT32(6)
367
368
/* field: RX5PEND - RX5PEND masked interrupt read */
369
#define TMS570_EMACM_RXINTSTATMASKED_RX5PEND BSP_BIT32(5)
370
371
/* field: RX4PEND - RX4PEND masked interrupt read */
372
#define TMS570_EMACM_RXINTSTATMASKED_RX4PEND BSP_BIT32(4)
373
374
/* field: RX3PEND - RX3PEND masked interrupt read */
375
#define TMS570_EMACM_RXINTSTATMASKED_RX3PEND BSP_BIT32(3)
376
377
/* field: RX2PEND - RX2PEND masked interrupt read */
378
#define TMS570_EMACM_RXINTSTATMASKED_RX2PEND BSP_BIT32(2)
379
380
/* field: RX1PEND - RX1PEND masked interrupt read */
381
#define TMS570_EMACM_RXINTSTATMASKED_RX1PEND BSP_BIT32(1)
382
383
/* field: RX0PEND - RX0PEND masked interrupt read */
384
#define TMS570_EMACM_RXINTSTATMASKED_RX0PEND BSP_BIT32(0)
385
386
387
/*-----------------TMS570_EMACM_RXINTMASKSET-----------------*/
388
/* field: RX7THRESHMASK - Receive channel 7 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
389
#define TMS570_EMACM_RXINTMASKSET_RX7THRESHMASK BSP_BIT32(15)
390
391
/* field: RX6THRESHMASK - Receive channel 6 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
392
#define TMS570_EMACM_RXINTMASKSET_RX6THRESHMASK BSP_BIT32(14)
393
394
/* field: RX5THRESHMASK - Receive channel 5 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
395
#define TMS570_EMACM_RXINTMASKSET_RX5THRESHMASK BSP_BIT32(13)
396
397
/* field: RX4THRESHMASK - Receive channel 4 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
398
#define TMS570_EMACM_RXINTMASKSET_RX4THRESHMASK BSP_BIT32(12)
399
400
/* field: RX3THRESHMASK - Receive channel 3 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
401
#define TMS570_EMACM_RXINTMASKSET_RX3THRESHMASK BSP_BIT32(11)
402
403
/* field: RX2THRESHMASK - Receive channel 2 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
404
#define TMS570_EMACM_RXINTMASKSET_RX2THRESHMASK BSP_BIT32(10)
405
406
/* field: RX1THRESHMASK - Receive channel 1 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
407
#define TMS570_EMACM_RXINTMASKSET_RX1THRESHMASK BSP_BIT32(9)
408
409
/* field: RX0THRESHMASK - Receive channel 0 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
410
#define TMS570_EMACM_RXINTMASKSET_RX0THRESHMASK BSP_BIT32(8)
411
412
/* field: RX7MASK - Receive channel 7 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
413
#define TMS570_EMACM_RXINTMASKSET_RX7MASK BSP_BIT32(7)
414
415
/* field: RX6MASK - Receive channel 6 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
416
#define TMS570_EMACM_RXINTMASKSET_RX6MASK BSP_BIT32(6)
417
418
/* field: RX5MASK - Receive channel 5 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
419
#define TMS570_EMACM_RXINTMASKSET_RX5MASK BSP_BIT32(5)
420
421
/* field: RX4MASK - Receive channel 4 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
422
#define TMS570_EMACM_RXINTMASKSET_RX4MASK BSP_BIT32(4)
423
424
/* field: RX3MASK - Receive channel 3 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
425
#define TMS570_EMACM_RXINTMASKSET_RX3MASK BSP_BIT32(3)
426
427
/* field: RX2MASK - Receive channel 2 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
428
#define TMS570_EMACM_RXINTMASKSET_RX2MASK BSP_BIT32(2)
429
430
/* field: RX1MASK - Receive channel 1 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
431
#define TMS570_EMACM_RXINTMASKSET_RX1MASK BSP_BIT32(1)
432
433
/* field: RX0MASK - Receive channel 0 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
434
#define TMS570_EMACM_RXINTMASKSET_RX0MASK BSP_BIT32(0)
435
436
437
/*----------------TMS570_EMACM_RXINTMASKCLEAR----------------*/
438
/* field: RX7THRESHMASK - Receive channel 7 threshold mask clear bit. */
439
#define TMS570_EMACM_RXINTMASKCLEAR_RX7THRESHMASK BSP_BIT32(15)
440
441
/* field: RX6THRESHMASK - Receive channel 6 threshold mask clear bit. */
442
#define TMS570_EMACM_RXINTMASKCLEAR_RX6THRESHMASK BSP_BIT32(14)
443
444
/* field: RX5THRESHMASK - Receive channel 5 threshold mask clear bit. */
445
#define TMS570_EMACM_RXINTMASKCLEAR_RX5THRESHMASK BSP_BIT32(13)
446
447
/* field: RX4THRESHMASK - Receive channel 4 threshold mask clear bit. */
448
#define TMS570_EMACM_RXINTMASKCLEAR_RX4THRESHMASK BSP_BIT32(12)
449
450
/* field: RX3THRESHMASK - Receive channel 3 threshold mask clear bit. */
451
#define TMS570_EMACM_RXINTMASKCLEAR_RX3THRESHMASK BSP_BIT32(11)
452
453
/* field: RX2THRESHMASK - Receive channel 2 threshold mask clear bit. */
454
#define TMS570_EMACM_RXINTMASKCLEAR_RX2THRESHMASK BSP_BIT32(10)
455
456
/* field: RX1THRESHMASK - Receive channel 1 threshold mask clear bit. */
457
#define TMS570_EMACM_RXINTMASKCLEAR_RX1THRESHMASK BSP_BIT32(9)
458
459
/* field: RX0THRESHMASK - Receive channel 0 threshold mask clear bit. */
460
#define TMS570_EMACM_RXINTMASKCLEAR_RX0THRESHMASK BSP_BIT32(8)
461
462
/* field: RX7MASK - Receive channel 7 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
463
#define TMS570_EMACM_RXINTMASKCLEAR_RX7MASK BSP_BIT32(7)
464
465
/* field: RX6MASK - Receive channel 6 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
466
#define TMS570_EMACM_RXINTMASKCLEAR_RX6MASK BSP_BIT32(6)
467
468
/* field: RX5MASK - Receive channel 5 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
469
#define TMS570_EMACM_RXINTMASKCLEAR_RX5MASK BSP_BIT32(5)
470
471
/* field: RX4MASK - Receive channel 4 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
472
#define TMS570_EMACM_RXINTMASKCLEAR_RX4MASK BSP_BIT32(4)
473
474
/* field: RX3MASK - Receive channel 3 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
475
#define TMS570_EMACM_RXINTMASKCLEAR_RX3MASK BSP_BIT32(3)
476
477
/* field: RX2MASK - Receive channel 2 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
478
#define TMS570_EMACM_RXINTMASKCLEAR_RX2MASK BSP_BIT32(2)
479
480
/* field: RX1MASK - Receive channel 1 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
481
#define TMS570_EMACM_RXINTMASKCLEAR_RX1MASK BSP_BIT32(1)
482
483
/* field: RX0MASK - Receive channel 0 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
484
#define TMS570_EMACM_RXINTMASKCLEAR_RX0MASK BSP_BIT32(0)
485
486
487
/*-----------------TMS570_EMACM_MACINTSTATRAW-----------------*/
488
/* field: HOSTPEND - Host pending interrupt (HOSTPEND); raw interrupt read (before mask). */
489
#define TMS570_EMACM_MACINTSTATRAW_HOSTPEND BSP_BIT32(1)
490
491
/* field: STATPEND - Statistics pending interrupt (STATPEND); raw interrupt read (before mask). */
492
#define TMS570_EMACM_MACINTSTATRAW_STATPEND BSP_BIT32(0)
493
494
495
/*---------------TMS570_EMACM_MACINTSTATMASKED---------------*/
496
/* field: HOSTPEND - Host pending interrupt (HOSTPEND); masked interrupt read. */
497
#define TMS570_EMACM_MACINTSTATMASKED_HOSTPEND BSP_BIT32(1)
498
499
/* field: STATPEND - Statistics pending interrupt (STATPEND); masked interrupt read. */
500
#define TMS570_EMACM_MACINTSTATMASKED_STATPEND BSP_BIT32(0)
501
502
503
/*-----------------TMS570_EMACM_MACINTMASKSET-----------------*/
504
/* field: HOSTMASK - Host error interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
505
#define TMS570_EMACM_MACINTMASKSET_HOSTMASK BSP_BIT32(1)
506
507
/* field: STATMASK - Statistics interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
508
#define TMS570_EMACM_MACINTMASKSET_STATMASK BSP_BIT32(0)
509
510
511
/*----------------TMS570_EMACM_MACINTMASKCLEAR----------------*/
512
/* field: HOSTMASK - Host error interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
513
#define TMS570_EMACM_MACINTMASKCLEAR_HOSTMASK BSP_BIT32(1)
514
515
/* field: STATMASK - Statistics interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
516
#define TMS570_EMACM_MACINTMASKCLEAR_STATMASK BSP_BIT32(0)
517
518
519
/*------------------TMS570_EMACM_RXMBPENABLE------------------*/
520
/* field: RXPASSCRC - Pass receive CRC enable bit */
521
#define TMS570_EMACM_RXMBPENABLE_RXPASSCRC BSP_BIT32(30)
522
523
/* field: RXQOSEN - Receive quality of service enable bit */
524
#define TMS570_EMACM_RXMBPENABLE_RXQOSEN BSP_BIT32(29)
525
526
/* field: RXNOCHAIN - Receive no buffer chaining bit */
527
#define TMS570_EMACM_RXMBPENABLE_RXNOCHAIN BSP_BIT32(28)
528
529
/* field: RXCMFEN - Receive copy MAC control frames enable bit. */
530
#define TMS570_EMACM_RXMBPENABLE_RXCMFEN BSP_BIT32(24)
531
532
/* field: RXCSFEN - Receive copy short frames enable bit. */
533
#define TMS570_EMACM_RXMBPENABLE_RXCSFEN BSP_BIT32(23)
534
535
/* field: RXCEFEN - Receive copy error frames enable bit. */
536
#define TMS570_EMACM_RXMBPENABLE_RXCEFEN BSP_BIT32(22)
537
538
/* field: RXCAFEN - Receive copy all frames enable bit. */
539
#define TMS570_EMACM_RXMBPENABLE_RXCAFEN BSP_BIT32(21)
540
541
/* field: RXPROMCH - Receive promiscuous channel select */
542
#define TMS570_EMACM_RXMBPENABLE_RXPROMCH(val) BSP_FLD32(val,16, 18)
543
#define TMS570_EMACM_RXMBPENABLE_RXPROMCH_GET(reg) BSP_FLD32GET(reg,16, 18)
544
#define TMS570_EMACM_RXMBPENABLE_RXPROMCH_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
545
546
/* field: RXBROADEN - Receive broadcast enable. */
547
#define TMS570_EMACM_RXMBPENABLE_RXBROADEN BSP_BIT32(13)
548
549
/* field: RXBROADCH - Receive broadcast channel select */
550
#define TMS570_EMACM_RXMBPENABLE_RXBROADCH(val) BSP_FLD32(val,8, 10)
551
#define TMS570_EMACM_RXMBPENABLE_RXBROADCH_GET(reg) BSP_FLD32GET(reg,8, 10)
552
#define TMS570_EMACM_RXMBPENABLE_RXBROADCH_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
553
554
/* field: RXMULTEN - RX multicast enable. */
555
#define TMS570_EMACM_RXMBPENABLE_RXMULTEN BSP_BIT32(5)
556
557
558
/*-----------------TMS570_EMACM_RXUNICASTSET-----------------*/
559
/* field: RXCH7EN - Receive channel 7 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
560
#define TMS570_EMACM_RXUNICASTSET_RXCH7EN BSP_BIT32(7)
561
562
/* field: RXCH6EN - Receive channel 6 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
563
#define TMS570_EMACM_RXUNICASTSET_RXCH6EN BSP_BIT32(6)
564
565
/* field: RXCH5EN - Receive channel 5 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
566
#define TMS570_EMACM_RXUNICASTSET_RXCH5EN BSP_BIT32(5)
567
568
/* field: RXCH4EN - Receive channel 4 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
569
#define TMS570_EMACM_RXUNICASTSET_RXCH4EN BSP_BIT32(4)
570
571
/* field: RXCH3EN - Receive channel 3 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
572
#define TMS570_EMACM_RXUNICASTSET_RXCH3EN BSP_BIT32(3)
573
574
/* field: RXCH2EN - Receive channel 2 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
575
#define TMS570_EMACM_RXUNICASTSET_RXCH2EN BSP_BIT32(2)
576
577
/* field: RXCH1EN - Receive channel 1 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
578
#define TMS570_EMACM_RXUNICASTSET_RXCH1EN BSP_BIT32(1)
579
580
/* field: RXCH0EN - Receive channel 0 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
581
#define TMS570_EMACM_RXUNICASTSET_RXCH0EN BSP_BIT32(0)
582
583
584
/*----------------TMS570_EMACM_RXUNICASTCLEAR----------------*/
585
/* field: RXCH7EN - Receive channel 7 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
586
#define TMS570_EMACM_RXUNICASTCLEAR_RXCH7EN BSP_BIT32(7)
587
588
/* field: RXCH6EN - Receive channel 6 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
589
#define TMS570_EMACM_RXUNICASTCLEAR_RXCH6EN BSP_BIT32(6)
590
591
/* field: RXCH5EN - Receive channel 5 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
592
#define TMS570_EMACM_RXUNICASTCLEAR_RXCH5EN BSP_BIT32(5)
593
594
/* field: RXCH4EN - Receive channel 4 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
595
#define TMS570_EMACM_RXUNICASTCLEAR_RXCH4EN BSP_BIT32(4)
596
597
/* field: RXCH3EN - Receive channel 3 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
598
#define TMS570_EMACM_RXUNICASTCLEAR_RXCH3EN BSP_BIT32(3)
599
600
/* field: RXCH2EN - Receive channel 2 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
601
#define TMS570_EMACM_RXUNICASTCLEAR_RXCH2EN BSP_BIT32(2)
602
603
/* field: RXCH1EN - Receive channel 1 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
604
#define TMS570_EMACM_RXUNICASTCLEAR_RXCH1EN BSP_BIT32(1)
605
606
/* field: RXCH0EN - Receive channel 0 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
607
#define TMS570_EMACM_RXUNICASTCLEAR_RXCH0EN BSP_BIT32(0)
608
609
610
/*-------------------TMS570_EMACM_RXMAXLEN-------------------*/
611
/* field: RXMAXLEN - Receive maximum frame length. These bits determine the maximum length of a received frame. */
612
#define TMS570_EMACM_RXMAXLEN_RXMAXLEN(val) BSP_FLD32(val,0, 15)
613
#define TMS570_EMACM_RXMAXLEN_RXMAXLEN_GET(reg) BSP_FLD32GET(reg,0, 15)
614
#define TMS570_EMACM_RXMAXLEN_RXMAXLEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
615
616
617
/*----------------TMS570_EMACM_RXBUFFEROFFSET----------------*/
618
/* field: RXBUFFEROFFSET - Receive buffer offset value. */
619
#define TMS570_EMACM_RXBUFFEROFFSET_RXBUFFEROFFSET(val) BSP_FLD32(val,0, 15)
620
#define TMS570_EMACM_RXBUFFEROFFSET_RXBUFFEROFFSET_GET(reg) BSP_FLD32GET(reg,0, 15)
621
#define TMS570_EMACM_RXBUFFEROFFSET_RXBUFFEROFFSET_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
622
623
624
/*---------------TMS570_EMACM_RXFILTERLOWTHRESH---------------*/
625
/* field: RXFILTERTHRESH - Receive filter low threshold. */
626
#define TMS570_EMACM_RXFILTERLOWTHRESH_RXFILTERTHRESH(val) BSP_FLD32(val,0, 7)
627
#define TMS570_EMACM_RXFILTERLOWTHRESH_RXFILTERTHRESH_GET(reg) BSP_FLD32GET(reg,0, 7)
628
#define TMS570_EMACM_RXFILTERLOWTHRESH_RXFILTERTHRESH_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
629
630
631
/*-----------------TMS570_EMACM_RXFLOWTHRESH-----------------*/
632
/* field: RXnFLOWTHRESH - Receive flow threshold. */
633
#define TMS570_EMACM_RXFLOWTHRESH_RXnFLOWTHRESH(val) BSP_FLD32(val,0, 7)
634
#define TMS570_EMACM_RXFLOWTHRESH_RXnFLOWTHRESH_GET(reg) BSP_FLD32GET(reg,0, 7)
635
#define TMS570_EMACM_RXFLOWTHRESH_RXnFLOWTHRESH_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
636
637
638
/*-----------------TMS570_EMACM_RXFREEBUFFER-----------------*/
639
/* field: RXnFREEBUF - Receive free buffer count. These bits contain the count of free buffers available. */
640
#define TMS570_EMACM_RXFREEBUFFER_RXnFREEBUF(val) BSP_FLD32(val,0, 15)
641
#define TMS570_EMACM_RXFREEBUFFER_RXnFREEBUF_GET(reg) BSP_FLD32GET(reg,0, 15)
642
#define TMS570_EMACM_RXFREEBUFFER_RXnFREEBUF_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
643
644
645
/*------------------TMS570_EMACM_MACCONTROL------------------*/
646
/* field: RMIISPEED - RMII interface transmit and receive speed select. */
647
#define TMS570_EMACM_MACCONTROL_RMIISPEED BSP_BIT32(15)
648
649
/* field: RXOFFLENBLOCK - Receive offset / length word write block. */
650
#define TMS570_EMACM_MACCONTROL_RXOFFLENBLOCK BSP_BIT32(14)
651
652
/* field: RXOWNERSHIP - Receive ownership write bit value. */
653
#define TMS570_EMACM_MACCONTROL_RXOWNERSHIP BSP_BIT32(13)
654
655
/* field: CMDIDLE - Command Idle bit */
656
#define TMS570_EMACM_MACCONTROL_CMDIDLE BSP_BIT32(11)
657
658
/* field: TXSHORTGAPEN - Transmit Short Gap Enable */
659
#define TMS570_EMACM_MACCONTROL_TXSHORTGAPEN BSP_BIT32(10)
660
661
/* field: TXPTYPE - Transmit queue priority type */
662
#define TMS570_EMACM_MACCONTROL_TXPTYPE BSP_BIT32(9)
663
664
/* field: TXPACE - Transmit pacing enable bit */
665
#define TMS570_EMACM_MACCONTROL_TXPACE BSP_BIT32(6)
666
667
/* field: GMIIEN - GMII enable bit */
668
#define TMS570_EMACM_MACCONTROL_GMIIEN BSP_BIT32(5)
669
670
/* field: TXFLOWEN - Transmit flow control enable bit. */
671
#define TMS570_EMACM_MACCONTROL_TXFLOWEN BSP_BIT32(4)
672
673
/* field: RXBUFFERFLOWEN - Receive buffer flow control enable bit */
674
#define TMS570_EMACM_MACCONTROL_RXBUFFERFLOWEN BSP_BIT32(3)
675
676
/* field: LOOPBACK - Loopback mode. The loopback mode forces internal full-duplex mode regardless of the FULLDUPLEX bit. */
677
#define TMS570_EMACM_MACCONTROL_LOOPBACK BSP_BIT32(1)
678
679
/* field: FULLDUPLEX - Full duplex mode. */
680
#define TMS570_EMACM_MACCONTROL_FULLDUPLEX BSP_BIT32(0)
681
682
683
/*-------------------TMS570_EMACM_MACSTATUS-------------------*/
684
/* field: IDLE - EMAC idle bit. This bit is cleared to 0 at reset; one clock after reset, it goes to 1. */
685
#define TMS570_EMACM_MACSTATUS_IDLE BSP_BIT32(31)
686
687
/* field: TXERRCODE - Transmit host error code. These bits indicate that EMAC detected transmit DMA related host errors. */
688
#define TMS570_EMACM_MACSTATUS_TXERRCODE(val) BSP_FLD32(val,20, 23)
689
#define TMS570_EMACM_MACSTATUS_TXERRCODE_GET(reg) BSP_FLD32GET(reg,20, 23)
690
#define TMS570_EMACM_MACSTATUS_TXERRCODE_SET(reg,val) BSP_FLD32SET(reg, val,20, 23)
691
692
/* field: TXERRCH - Transmit host error channel. These bits indicate which transmit channel the host error occurred on. */
693
#define TMS570_EMACM_MACSTATUS_TXERRCH(val) BSP_FLD32(val,16, 18)
694
#define TMS570_EMACM_MACSTATUS_TXERRCH_GET(reg) BSP_FLD32GET(reg,16, 18)
695
#define TMS570_EMACM_MACSTATUS_TXERRCH_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
696
697
/* field: RXERRCODE - Receive host error code. These bits indicate that EMAC detected receive DMA related host errors. */
698
#define TMS570_EMACM_MACSTATUS_RXERRCODE(val) BSP_FLD32(val,12, 15)
699
#define TMS570_EMACM_MACSTATUS_RXERRCODE_GET(reg) BSP_FLD32GET(reg,12, 15)
700
#define TMS570_EMACM_MACSTATUS_RXERRCODE_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
701
702
/* field: RXERRCH - Receive host error channel. These bits indicate which receive channel the host error occurred on. */
703
#define TMS570_EMACM_MACSTATUS_RXERRCH(val) BSP_FLD32(val,8, 10)
704
#define TMS570_EMACM_MACSTATUS_RXERRCH_GET(reg) BSP_FLD32GET(reg,8, 10)
705
#define TMS570_EMACM_MACSTATUS_RXERRCH_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
706
707
/* field: RXQOSACT - Receive Quality of Service (QOS) active bit. */
708
#define TMS570_EMACM_MACSTATUS_RXQOSACT BSP_BIT32(2)
709
710
/* field: RXFLOWACT - Receive flow control active bit. */
711
#define TMS570_EMACM_MACSTATUS_RXFLOWACT BSP_BIT32(1)
712
713
/* field: TXFLOWACT - Transmit flow control active bit. */
714
#define TMS570_EMACM_MACSTATUS_TXFLOWACT BSP_BIT32(0)
715
716
717
/*-------------------TMS570_EMACM_EMCONTROL-------------------*/
718
/* field: SOFT - Emulation soft bit. */
719
#define TMS570_EMACM_EMCONTROL_SOFT BSP_BIT32(1)
720
721
/* field: FREE - Emulation free bit. */
722
#define TMS570_EMACM_EMCONTROL_FREE BSP_BIT32(0)
723
724
725
/*------------------TMS570_EMACM_FIFOCONTROL------------------*/
726
/* field: TXCELLTHRESH - Transmit FIFO cell threshold. */
727
#define TMS570_EMACM_FIFOCONTROL_TXCELLTHRESH(val) BSP_FLD32(val,0, 1)
728
#define TMS570_EMACM_FIFOCONTROL_TXCELLTHRESH_GET(reg) BSP_FLD32GET(reg,0, 1)
729
#define TMS570_EMACM_FIFOCONTROL_TXCELLTHRESH_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
730
731
732
/*-------------------TMS570_EMACM_MACCONFIG-------------------*/
733
/* field: TXCELLDEPTH - Transmit cell depth. These bits indicate the number of cells in the transmit FIFO. */
734
#define TMS570_EMACM_MACCONFIG_TXCELLDEPTH(val) BSP_FLD32(val,24, 31)
735
#define TMS570_EMACM_MACCONFIG_TXCELLDEPTH_GET(reg) BSP_FLD32GET(reg,24, 31)
736
#define TMS570_EMACM_MACCONFIG_TXCELLDEPTH_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
737
738
/* field: RXCELLDEPTH - Receive cell depth. These bits indicate the number of cells in the receive FIFO. */
739
#define TMS570_EMACM_MACCONFIG_RXCELLDEPTH(val) BSP_FLD32(val,16, 23)
740
#define TMS570_EMACM_MACCONFIG_RXCELLDEPTH_GET(reg) BSP_FLD32GET(reg,16, 23)
741
#define TMS570_EMACM_MACCONFIG_RXCELLDEPTH_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
742
743
/* field: ADDRESSTYPE - Address type */
744
#define TMS570_EMACM_MACCONFIG_ADDRESSTYPE(val) BSP_FLD32(val,8, 15)
745
#define TMS570_EMACM_MACCONFIG_ADDRESSTYPE_GET(reg) BSP_FLD32GET(reg,8, 15)
746
#define TMS570_EMACM_MACCONFIG_ADDRESSTYPE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
747
748
/* field: MACCFIG - MAC configuration value */
749
#define TMS570_EMACM_MACCONFIG_MACCFIG(val) BSP_FLD32(val,0, 7)
750
#define TMS570_EMACM_MACCONFIG_MACCFIG_GET(reg) BSP_FLD32GET(reg,0, 7)
751
#define TMS570_EMACM_MACCONFIG_MACCFIG_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
752
753
754
/*-------------------TMS570_EMACM_SOFTRESET-------------------*/
755
/* field: SOFTRESET - Software reset. Writing a 1 to this bit causes the EMAC logic to be reset. */
756
#define TMS570_EMACM_SOFTRESET_SOFTRESET BSP_BIT32(0)
757
758
759
/*-----------------TMS570_EMACM_MACSRCADDRLO-----------------*/
760
/* field: MACSRCADDR0 - MAC source address lower 8-0 bits (byte 0) */
761
#define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR0(val) BSP_FLD32(val,8, 15)
762
#define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR0_GET(reg) BSP_FLD32GET(reg,8, 15)
763
#define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR0_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
764
765
/* field: MACSRCADDR1 - MAC source address bits 15-8 (byte 1) */
766
#define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR1(val) BSP_FLD32(val,0, 7)
767
#define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR1_GET(reg) BSP_FLD32GET(reg,0, 7)
768
#define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR1_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
769
770
771
/*-----------------TMS570_EMACM_MACSRCADDRHI-----------------*/
772
/* field: MACSRCADDR2 - MAC source address bits 23-16 (byte 2) */
773
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR2(val) BSP_FLD32(val,24, 31)
774
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR2_GET(reg) BSP_FLD32GET(reg,24, 31)
775
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR2_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
776
777
/* field: MACSRCADDR3 - MAC source address bits 31-24 (byte 3) */
778
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR3(val) BSP_FLD32(val,16, 23)
779
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR3_GET(reg) BSP_FLD32GET(reg,16, 23)
780
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR3_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
781
782
/* field: MACSRCADDR4 - MAC source address bits 39-32 (byte 4) */
783
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR4(val) BSP_FLD32(val,8, 15)
784
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR4_GET(reg) BSP_FLD32GET(reg,8, 15)
785
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR4_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
786
787
/* field: MACSRCADDR5 - MAC source address bits 47-40 (byte 5) */
788
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR5(val) BSP_FLD32(val,0, 7)
789
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR5_GET(reg) BSP_FLD32GET(reg,0, 7)
790
#define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR5_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
791
792
793
/*-------------------TMS570_EMACM_MACHASH1-------------------*/
794
/* field: MACHASH1 - Least-significant 32 bits of the hash table corresponding to hash values 0 to 31. */
795
/* Whole 32 bits */
796
797
/*-------------------TMS570_EMACM_MACHASH2-------------------*/
798
/* field: MACHASH2 - Most-significant 32 bits of the hash table corresponding to hash values 32 to 63. */
799
/* Whole 32 bits */
800
801
/*-------------------TMS570_EMACM_BOFFTEST-------------------*/
802
/* field: RNDNUM - Backoff random number generator. */
803
#define TMS570_EMACM_BOFFTEST_RNDNUM(val) BSP_FLD32(val,16, 25)
804
#define TMS570_EMACM_BOFFTEST_RNDNUM_GET(reg) BSP_FLD32GET(reg,16, 25)
805
#define TMS570_EMACM_BOFFTEST_RNDNUM_SET(reg,val) BSP_FLD32SET(reg, val,16, 25)
806
807
/* field: COLLCOUNT - Collision count. These bits indicate the number of collisions the current frame has experienced. */
808
#define TMS570_EMACM_BOFFTEST_COLLCOUNT(val) BSP_FLD32(val,12, 15)
809
#define TMS570_EMACM_BOFFTEST_COLLCOUNT_GET(reg) BSP_FLD32GET(reg,12, 15)
810
#define TMS570_EMACM_BOFFTEST_COLLCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
811
812
/* field: TXBACKOFF - Backoff count. */
813
#define TMS570_EMACM_BOFFTEST_TXBACKOFF(val) BSP_FLD32(val,0, 9)
814
#define TMS570_EMACM_BOFFTEST_TXBACKOFF_GET(reg) BSP_FLD32GET(reg,0, 9)
815
#define TMS570_EMACM_BOFFTEST_TXBACKOFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
816
817
818
/*-------------------TMS570_EMACM_TPACETEST-------------------*/
819
/* field: PACEVAL - Pacing register current value. A nonzero value in this field indicates that transmit pacing is active. */
820
#define TMS570_EMACM_TPACETEST_PACEVAL(val) BSP_FLD32(val,0, 4)
821
#define TMS570_EMACM_TPACETEST_PACEVAL_GET(reg) BSP_FLD32GET(reg,0, 4)
822
#define TMS570_EMACM_TPACETEST_PACEVAL_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
823
824
825
/*--------------------TMS570_EMACM_RXPAUSE--------------------*/
826
/* field: PAUSETIMER - Receive pause timer value. */
827
#define TMS570_EMACM_RXPAUSE_PAUSETIMER(val) BSP_FLD32(val,0, 15)
828
#define TMS570_EMACM_RXPAUSE_PAUSETIMER_GET(reg) BSP_FLD32GET(reg,0, 15)
829
#define TMS570_EMACM_RXPAUSE_PAUSETIMER_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
830
831
832
/*--------------------TMS570_EMACM_TXPAUSE--------------------*/
833
/* field: PAUSETIMER - Transmit pause timer value. */
834
#define TMS570_EMACM_TXPAUSE_PAUSETIMER(val) BSP_FLD32(val,0, 15)
835
#define TMS570_EMACM_TXPAUSE_PAUSETIMER_GET(reg) BSP_FLD32GET(reg,0, 15)
836
#define TMS570_EMACM_TXPAUSE_PAUSETIMER_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
837
838
839
/*-------------------TMS570_EMACM_MACADDRLO-------------------*/
840
/* field: VALID - Address valid bit. */
841
#define TMS570_EMACM_MACADDRLO_VALID BSP_BIT32(20)
842
843
/* field: MATCHFILT - Match or filter bit */
844
#define TMS570_EMACM_MACADDRLO_MATCHFILT BSP_BIT32(19)
845
846
/* field: CHANNEL - Channel select. Determines which receive channel a valid address match will be transferred to. */
847
#define TMS570_EMACM_MACADDRLO_CHANNEL(val) BSP_FLD32(val,16, 18)
848
#define TMS570_EMACM_MACADDRLO_CHANNEL_GET(reg) BSP_FLD32GET(reg,16, 18)
849
#define TMS570_EMACM_MACADDRLO_CHANNEL_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
850
851
/* field: MACADDR0 - MAC address lower 8-0 bits (byte 0) */
852
#define TMS570_EMACM_MACADDRLO_MACADDR0(val) BSP_FLD32(val,8, 15)
853
#define TMS570_EMACM_MACADDRLO_MACADDR0_GET(reg) BSP_FLD32GET(reg,8, 15)
854
#define TMS570_EMACM_MACADDRLO_MACADDR0_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
855
856
/* field: MACADDR1 - MAC address bits 15-8 (byte 1) */
857
#define TMS570_EMACM_MACADDRLO_MACADDR1(val) BSP_FLD32(val,0, 7)
858
#define TMS570_EMACM_MACADDRLO_MACADDR1_GET(reg) BSP_FLD32GET(reg,0, 7)
859
#define TMS570_EMACM_MACADDRLO_MACADDR1_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
860
861
862
/*-------------------TMS570_EMACM_MACADDRHI-------------------*/
863
/* field: MACADDR2 - MAC source address bits 23-16 (byte 2) */
864
#define TMS570_EMACM_MACADDRHI_MACADDR2(val) BSP_FLD32(val,24, 31)
865
#define TMS570_EMACM_MACADDRHI_MACADDR2_GET(reg) BSP_FLD32GET(reg,24, 31)
866
#define TMS570_EMACM_MACADDRHI_MACADDR2_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
867
868
/* field: MACADDR3 - MAC source address bits 31-24 (byte 3) */
869
#define TMS570_EMACM_MACADDRHI_MACADDR3(val) BSP_FLD32(val,16, 23)
870
#define TMS570_EMACM_MACADDRHI_MACADDR3_GET(reg) BSP_FLD32GET(reg,16, 23)
871
#define TMS570_EMACM_MACADDRHI_MACADDR3_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
872
873
/* field: MACADDR4 - MAC source address bits 39-32 (byte 4) */
874
#define TMS570_EMACM_MACADDRHI_MACADDR4(val) BSP_FLD32(val,8, 15)
875
#define TMS570_EMACM_MACADDRHI_MACADDR4_GET(reg) BSP_FLD32GET(reg,8, 15)
876
#define TMS570_EMACM_MACADDRHI_MACADDR4_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
877
878
/* field: MACADDR5 - MAC source address bits 47-40 (byte 5). Bit 40 is the group bit. It is forced to 0 and read as 0. */
879
#define TMS570_EMACM_MACADDRHI_MACADDR5(val) BSP_FLD32(val,0, 7)
880
#define TMS570_EMACM_MACADDRHI_MACADDR5_GET(reg) BSP_FLD32GET(reg,0, 7)
881
#define TMS570_EMACM_MACADDRHI_MACADDR5_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
882
883
884
/*-------------------TMS570_EMACM_MACINDEX-------------------*/
885
/* field: MACINDEX - MAC address index. All eight addresses share the upper 40 bits. */
886
#define TMS570_EMACM_MACINDEX_MACINDEX(val) BSP_FLD32(val,0, 2)
887
#define TMS570_EMACM_MACINDEX_MACINDEX_GET(reg) BSP_FLD32GET(reg,0, 2)
888
#define TMS570_EMACM_MACINDEX_MACINDEX_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
889
890
891
/*---------------------TMS570_EMACM_TXHDP---------------------*/
892
/* field: TXnHDP - Transmit channel n DMA Head Descriptor pointer. */
893
/* Whole 32 bits */
894
895
/*---------------------TMS570_EMACM_RXHDP---------------------*/
896
/* field: RXnHDP - Receive channel n DMA Head Descriptor pointer. */
897
/* Whole 32 bits */
898
899
/*---------------------TMS570_EMACM_TXCP---------------------*/
900
/* field: TXnCP - Transmit channel n completion pointer register is written by the host with the buffer descriptor */
901
/* Whole 32 bits */
902
903
/*---------------------TMS570_EMACM_RXCP---------------------*/
904
/* field: RXnCP - Receive channel n completion pointer register is written by the host with the buffer descriptor */
905
/* Whole 32 bits */
906
907
908
#endif
/* LIBBSP_ARM_TMS570_EMACM */
utility.h
This header file provides utility macros for BSPs.
tms570_emacm_t
Definition
reg_emacm.h:54
