RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
ti_herc
reg_emacc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
/* The header file is generated by make_header.py from EMACC.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_EMACC
50
#define LIBBSP_ARM_TMS570_EMACC
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t REVID;
/*EMAC Control Module Revision ID Register*/
56
uint32_t SOFTRESET;
/*EMAC Control Module Software Reset Register*/
57
uint8_t reserved1 [4];
58
uint32_t INTCONTROL;
/*EMAC Control Module Interrupt Control Register*/
59
uint32_t C0RXTHRESHEN;
/*EMAC Control Module Receive Threshold Interrupt Enable Register*/
60
uint32_t C0RXEN;
/*EMAC Control Module Receive Interrupt Enable Register*/
61
uint32_t C0TXEN;
/*EMAC Control Module Transmit Interrupt Enable Register*/
62
uint32_t C0MISCEN;
/*EMAC Control Module Miscellaneous Interrupt Enable Register*/
63
uint8_t reserved2 [32];
64
uint32_t C0RXTHRESHSTAT;
/*EMAC Control Module Receive Threshold Interrupt Status Register*/
65
uint32_t C0RXSTAT;
/*EMAC Control Module Receive Interrupt Status Register*/
66
uint32_t C0TXSTAT;
/*EMAC Control Module Transmit Interrupt Status Register*/
67
uint32_t C0MISCSTAT;
/*EMAC Control Module Miscellaneous Interrupt Status Register*/
68
uint8_t reserved3 [32];
69
uint32_t C0RXIMAX;
/*EMAC Control Module Receive Interrupts Per Millisecond Register*/
70
uint32_t C0TXIMAX;
/*EMAC Control Module Transmit Interrupts Per Millisecond Register*/
71
tms570_emacc_t
72
73
74
/*---------------------TMS570_EMACC_REVID---------------------*/
75
/* field: REV - Identifies the EMAC Control Module revision. */
76
/* Whole 32 bits */
77
78
/*-------------------TMS570_EMACC_SOFTRESET-------------------*/
79
/* field: RESET - Software reset bit for the EMAC Control Module. */
80
#define TMS570_EMACC_SOFTRESET_RESET BSP_BIT32(0)
81
82
83
/*------------------TMS570_EMACC_INTCONTROL------------------*/
84
/* field: C0TXPACEEN - Enable pacing for TX interrupt pulse generation */
85
#define TMS570_EMACC_INTCONTROL_C0TXPACEEN BSP_BIT32(17)
86
87
/* field: C0RXPACEEN - Enable pacing for RX interrupt pulse generation */
88
#define TMS570_EMACC_INTCONTROL_C0RXPACEEN BSP_BIT32(16)
89
90
/* field: INTPRESCALE - Number of internal EMAC module reference clock periods within a 4 us time window (see */
91
#define TMS570_EMACC_INTCONTROL_INTPRESCALE(val) BSP_FLD32(val,0, 11)
92
#define TMS570_EMACC_INTCONTROL_INTPRESCALE_GET(reg) BSP_FLD32GET(reg,0, 11)
93
#define TMS570_EMACC_INTCONTROL_INTPRESCALE_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
94
95
96
/*-----------------TMS570_EMACC_C0RXTHRESHEN-----------------*/
97
/* field: RXCH7THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 7 */
98
#define TMS570_EMACC_C0RXTHRESHEN_RXCH7THRESHEN BSP_BIT32(7)
99
100
/* field: RXCH6THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 6 */
101
#define TMS570_EMACC_C0RXTHRESHEN_RXCH6THRESHEN BSP_BIT32(6)
102
103
/* field: RXCH5THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 5 */
104
#define TMS570_EMACC_C0RXTHRESHEN_RXCH5THRESHEN BSP_BIT32(5)
105
106
/* field: RXCH4THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 4 */
107
#define TMS570_EMACC_C0RXTHRESHEN_RXCH4THRESHEN BSP_BIT32(4)
108
109
/* field: RXCH3THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 3 */
110
#define TMS570_EMACC_C0RXTHRESHEN_RXCH3THRESHEN BSP_BIT32(3)
111
112
/* field: RXCH2THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 2 */
113
#define TMS570_EMACC_C0RXTHRESHEN_RXCH2THRESHEN BSP_BIT32(2)
114
115
/* field: RXCH1THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 1 */
116
#define TMS570_EMACC_C0RXTHRESHEN_RXCH1THRESHEN BSP_BIT32(1)
117
118
/* field: RXCH0THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 0 */
119
#define TMS570_EMACC_C0RXTHRESHEN_RXCH0THRESHEN BSP_BIT32(0)
120
121
122
/*--------------------TMS570_EMACC_C0RXEN--------------------*/
123
/* field: RXCH7EN - Enable C0RXPULSE interrupt generation for RX Channel 7 */
124
#define TMS570_EMACC_C0RXEN_RXCH7EN BSP_BIT32(7)
125
126
/* field: RXCH6EN - Enable C0RXPULSE interrupt generation for RX Channel 6 */
127
#define TMS570_EMACC_C0RXEN_RXCH6EN BSP_BIT32(6)
128
129
/* field: RXCH5EN - Enable C0RXPULSE interrupt generation for RX Channel 5 */
130
#define TMS570_EMACC_C0RXEN_RXCH5EN BSP_BIT32(5)
131
132
/* field: RXCH4EN - Enable C0RXPULSE interrupt generation for RX Channel 4 */
133
#define TMS570_EMACC_C0RXEN_RXCH4EN BSP_BIT32(4)
134
135
/* field: RXCH3EN - Enable C0RXPULSE interrupt generation for RX Channel 3 */
136
#define TMS570_EMACC_C0RXEN_RXCH3EN BSP_BIT32(3)
137
138
/* field: RXCH2EN - Enable C0RXPULSE interrupt generation for RX Channel 2 */
139
#define TMS570_EMACC_C0RXEN_RXCH2EN BSP_BIT32(2)
140
141
/* field: RXCH1EN - Enable C0RXPULSE interrupt generation for RX Channel 1 */
142
#define TMS570_EMACC_C0RXEN_RXCH1EN BSP_BIT32(1)
143
144
/* field: RXCH0EN - Enable C0RXPULSE interrupt generation for RX Channel 0 */
145
#define TMS570_EMACC_C0RXEN_RXCH0EN BSP_BIT32(0)
146
147
148
/*--------------------TMS570_EMACC_C0TXEN--------------------*/
149
/* field: TXCH7EN - Enable C0TXPULSE interrupt generation for TX Channel 7 */
150
#define TMS570_EMACC_C0TXEN_TXCH7EN BSP_BIT32(7)
151
152
/* field: TXCH6EN - TXCH6EN */
153
#define TMS570_EMACC_C0TXEN_TXCH6EN BSP_BIT32(6)
154
155
/* field: TXCH5EN - Enable C0TXPULSE interrupt generation for TX Channel 5 */
156
#define TMS570_EMACC_C0TXEN_TXCH5EN BSP_BIT32(5)
157
158
/* field: TXCH4EN - Enable C0TXPULSE interrupt generation for TX Channel 4 */
159
#define TMS570_EMACC_C0TXEN_TXCH4EN BSP_BIT32(4)
160
161
/* field: TXCH3EN - Enable C0TXPULSE interrupt generation for TX Channel 3 */
162
#define TMS570_EMACC_C0TXEN_TXCH3EN BSP_BIT32(3)
163
164
/* field: TXCH2EN - Enable C0TXPULSE interrupt generation for TX Channel 2 */
165
#define TMS570_EMACC_C0TXEN_TXCH2EN BSP_BIT32(2)
166
167
/* field: TXCH1EN - Enable C0TXPULSE interrupt generation for TX Channel 1 */
168
#define TMS570_EMACC_C0TXEN_TXCH1EN BSP_BIT32(1)
169
170
/* field: TXCH0EN - Enable C0TXPULSE interrupt generation for TX Channel 0 */
171
#define TMS570_EMACC_C0TXEN_TXCH0EN BSP_BIT32(0)
172
173
174
/*-------------------TMS570_EMACC_C0MISCEN-------------------*/
175
/* field: STATPENDEN - Enable C0MISCPULSE interrupt generation when EMAC statistics interrupts are generated */
176
#define TMS570_EMACC_C0MISCEN_STATPENDEN BSP_BIT32(3)
177
178
/* field: HOSTPENDEN - HOSTPENDEN */
179
#define TMS570_EMACC_C0MISCEN_HOSTPENDEN BSP_BIT32(2)
180
181
/* field: LINKINT0EN - Enable C0MISCPULSE interrupt generation when MDIO LINKINT0 interrupts (corresponding to */
182
#define TMS570_EMACC_C0MISCEN_LINKINT0EN BSP_BIT32(1)
183
184
/* field: USERINT0EN - Enable C0MISCPULSE interrupt generation when MDIO USERINT0 interrupts (corresponding */
185
#define TMS570_EMACC_C0MISCEN_USERINT0EN BSP_BIT32(0)
186
187
188
/*----------------TMS570_EMACC_C0RXTHRESHSTAT----------------*/
189
/* field: RXCH7THRESHSTAT - Interrupt status for RX Channel 7 masked by the C0RXTHRESHEN register */
190
#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH7THRESHSTAT BSP_BIT32(7)
191
192
/* field: RXCH6THRESHSTAT - Interrupt status for RX Channel 6 masked by the C0RXTHRESHEN register */
193
#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH6THRESHSTAT BSP_BIT32(6)
194
195
/* field: RXCH5THRESHSTAT - Interrupt status for RX Channel 5 masked by the C0RXTHRESHEN register */
196
#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH5THRESHSTAT BSP_BIT32(5)
197
198
/* field: RXCH4THRESHSTAT - Interrupt status for RX Channel 4 masked by the C0RXTHRESHEN register */
199
#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH4THRESHSTAT BSP_BIT32(4)
200
201
/* field: RXCH3THRESHSTAT - Interrupt status for RX Channel 3 masked by the C0RXTHRESHEN register */
202
#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH3THRESHSTAT BSP_BIT32(3)
203
204
/* field: RXCH2THRESHSTAT - Interrupt status for RX Channel 2 masked by the C0RXTHRESHEN register */
205
#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH2THRESHSTAT BSP_BIT32(2)
206
207
/* field: RXCH1THRESHSTAT - Interrupt status for RX Channel 1 masked by the C0RXTHRESHEN register */
208
#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH1THRESHSTAT BSP_BIT32(1)
209
210
/* field: RXCH0THRESHSTAT - Interrupt status for RX Channel 0 masked by the C0RXTHRESHEN register */
211
#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH0THRESHSTAT BSP_BIT32(0)
212
213
214
/*-------------------TMS570_EMACC_C0RXSTAT-------------------*/
215
/* field: RXCH7STAT - RXCH7STAT */
216
#define TMS570_EMACC_C0RXSTAT_RXCH7STAT BSP_BIT32(7)
217
218
/* field: RXCH6STAT - Interrupt status for RX Channel 6 masked by the C0RXEN register */
219
#define TMS570_EMACC_C0RXSTAT_RXCH6STAT BSP_BIT32(6)
220
221
/* field: RXCH5STAT - Interrupt status for RX Channel 5 masked by the C0RXEN register */
222
#define TMS570_EMACC_C0RXSTAT_RXCH5STAT BSP_BIT32(5)
223
224
/* field: RXCH4STAT - Interrupt status for RX Channel 4 masked by the C0RXEN register */
225
#define TMS570_EMACC_C0RXSTAT_RXCH4STAT BSP_BIT32(4)
226
227
/* field: RXCH3STAT - Interrupt status for RX Channel 3 masked by the C0RXEN register */
228
#define TMS570_EMACC_C0RXSTAT_RXCH3STAT BSP_BIT32(3)
229
230
/* field: RXCH2STAT - H2STAT Interrupt status for RX Channel 2 masked by the C0RXEN register */
231
#define TMS570_EMACC_C0RXSTAT_RXCH2STAT BSP_BIT32(2)
232
233
/* field: RXCH1STAT - Interrupt status for RX Channel 1 masked by the C0RXEN register */
234
#define TMS570_EMACC_C0RXSTAT_RXCH1STAT BSP_BIT32(1)
235
236
/* field: RXCH0STAT - Interrupt status for RX Channel 0 masked by the C0RXEN register */
237
#define TMS570_EMACC_C0RXSTAT_RXCH0STAT BSP_BIT32(0)
238
239
240
/*-------------------TMS570_EMACC_C0TXSTAT-------------------*/
241
/* field: TXCH7STAT - Interrupt status for TX Channel 7 masked by the C0TXEN register */
242
#define TMS570_EMACC_C0TXSTAT_TXCH7STAT BSP_BIT32(7)
243
244
/* field: TXCH6STAT - TXCH6STAT */
245
#define TMS570_EMACC_C0TXSTAT_TXCH6STAT BSP_BIT32(6)
246
247
/* field: TXCH5STAT - Interrupt status for TX Channel 5 masked by the C0TXEN register */
248
#define TMS570_EMACC_C0TXSTAT_TXCH5STAT BSP_BIT32(5)
249
250
/* field: TXCH4STAT - Interrupt status for TX Channel 4 masked by the C0TXEN register */
251
#define TMS570_EMACC_C0TXSTAT_TXCH4STAT BSP_BIT32(4)
252
253
/* field: TXCH3STAT - Interrupt status for TX Channel 3 masked by the C0TXEN register */
254
#define TMS570_EMACC_C0TXSTAT_TXCH3STAT BSP_BIT32(3)
255
256
/* field: TXCH2STAT - Interrupt status for TX Channel 2 masked by the C0TXEN register */
257
#define TMS570_EMACC_C0TXSTAT_TXCH2STAT BSP_BIT32(2)
258
259
/* field: TXCH1STAT - Interrupt status for TX Channel 1 masked by the C0TXEN register */
260
#define TMS570_EMACC_C0TXSTAT_TXCH1STAT BSP_BIT32(1)
261
262
/* field: TXCH0STAT - Interrupt status for TX Channel 0 masked by the C0TXEN register */
263
#define TMS570_EMACC_C0TXSTAT_TXCH0STAT BSP_BIT32(0)
264
265
266
/*------------------TMS570_EMACC_C0MISCSTAT------------------*/
267
/* field: STATPENDSTAT - Interrupt status for EMAC STATPEND masked by the C0MISCEN register */
268
#define TMS570_EMACC_C0MISCSTAT_STATPENDSTAT BSP_BIT32(3)
269
270
/* field: HOSTPENDSTAT - Interrupt status for EMAC HOSTPEND masked by the C0MISCEN register */
271
#define TMS570_EMACC_C0MISCSTAT_HOSTPENDSTAT BSP_BIT32(2)
272
273
/* field: LINKINT0STAT - Interrupt status for MDIO LINKINT0 masked by the C0MISCEN register */
274
#define TMS570_EMACC_C0MISCSTAT_LINKINT0STAT BSP_BIT32(1)
275
276
/* field: USERINT0STAT - Interrupt status for MDIO USERINT0 masked by the C0MISCEN register */
277
#define TMS570_EMACC_C0MISCSTAT_USERINT0STAT BSP_BIT32(0)
278
279
280
/*-------------------TMS570_EMACC_C0RXIMAX-------------------*/
281
/* field: RXIMAX - RXIMAX is the desired number of C0RXPULSE interrupts generated per millisecond when */
282
#define TMS570_EMACC_C0RXIMAX_RXIMAX(val) BSP_FLD32(val,0, 5)
283
#define TMS570_EMACC_C0RXIMAX_RXIMAX_GET(reg) BSP_FLD32GET(reg,0, 5)
284
#define TMS570_EMACC_C0RXIMAX_RXIMAX_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
285
286
287
/*-------------------TMS570_EMACC_C0TXIMAX-------------------*/
288
/* field: TXIMAX - TXIMAX is the desired number of C0TXPULSE interrupts generated per millisecond when */
289
#define TMS570_EMACC_C0TXIMAX_TXIMAX(val) BSP_FLD32(val,0, 5)
290
#define TMS570_EMACC_C0TXIMAX_TXIMAX_GET(reg) BSP_FLD32GET(reg,0, 5)
291
#define TMS570_EMACC_C0TXIMAX_TXIMAX_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
292
293
294
295
#endif
/* LIBBSP_ARM_TMS570_EMACC */
utility.h
This header file provides utility macros for BSPs.
tms570_emacc_t
Definition
reg_emacc.h:54
