RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
ti_herc
reg_efuse.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
/* The header file is generated by make_header.py from EFUSE.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_EFUSE
50
#define LIBBSP_ARM_TMS570_EFUSE
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t EFCBOUND;
/*EFC Boundary Control Register*/
56
uint8_t reserved1 [12];
57
uint32_t EFCPINS;
/*EFC Pins Register*/
58
uint8_t reserved2 [12];
59
uint32_t EFC_ERR_STAT;
/*EFC Error Status Register*/
60
uint8_t reserved3 [8];
61
uint32_t EFC_ST_CY;
/*EFC Self Test Cycles Register*/
62
uint32_t EFC_ST_SIG;
/*EFC Self Test Signature Register*/
63
tms570_efuse_t
64
65
66
/*-------------------TMS570_EFUSE_EFCBOUND-------------------*/
67
/* field: EFC_Self_Test_Error - This bit drives the self test error signal when bit 17 (Self Test Error OE) is high. */
68
#define TMS570_EFUSE_EFCBOUND_EFC_Self_Test_Error BSP_BIT32(21)
69
70
/* field: EFC_Single_Bit_Error - This bit drives the single bit error signal when bit 16 (Single bit Error OE) is high. */
71
#define TMS570_EFUSE_EFCBOUND_EFC_Single_Bit_Error BSP_BIT32(20)
72
73
/* field: EFC_Instruction_Error - This bit drives the instruction error signal when bit 15 (Instruction Error OE) is high. */
74
#define TMS570_EFUSE_EFCBOUND_EFC_Instruction_Error BSP_BIT32(19)
75
76
/* field: EFC_Autoload_Error - This bit drives the Autoload Error signal when bit 14 (Autoload Error OE) is high. */
77
#define TMS570_EFUSE_EFCBOUND_EFC_Autoload_Error BSP_BIT32(18)
78
79
/* field: Self_Test_Error_OE - The Self Test Error Output Enable bit determines if the EFC Self Test signal comes from the */
80
#define TMS570_EFUSE_EFCBOUND_Self_Test_Error_OE BSP_BIT32(17)
81
82
/* field: Single_Bit_Error_OE - The single bit error output enable signal determines if the EFC Single Bit Error signal comes */
83
#define TMS570_EFUSE_EFCBOUND_Single_Bit_Error_OE BSP_BIT32(16)
84
85
/* field: Instruction_Error_OE - comes from the eFuse controller or from bit 19 of the boundary register. */
86
#define TMS570_EFUSE_EFCBOUND_Instruction_Error_OE BSP_BIT32(15)
87
88
/* field: Autoload_Error_OE - The autoload error output enable signal determines if the EFC Autoload Error signal comes */
89
#define TMS570_EFUSE_EFCBOUND_Autoload_Error_OE BSP_BIT32(14)
90
91
/* field: EFC_ECC_Selftest - The eFuse Controller ECC Selftest Enable bit starts the selftest of the ECC logic if the four */
92
#define TMS570_EFUSE_EFCBOUND_EFC_ECC_Selftest BSP_BIT32(13)
93
94
/* field: Input_Enable - The eFuse Controller ECC Selftest Enable bit starts the selftest of the ECC logic if the four */
95
#define TMS570_EFUSE_EFCBOUND_Input_Enable(val) BSP_FLD32(val,0, 3)
96
#define TMS570_EFUSE_EFCBOUND_Input_Enable_GET(reg) BSP_FLD32GET(reg,0, 3)
97
#define TMS570_EFUSE_EFCBOUND_Input_Enable_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
98
99
100
/*--------------------TMS570_EFUSE_EFCPINS--------------------*/
101
/* field: EFC_Selftest_Done - This bit can be polled to determine when the EFC ECC selftest is complete */
102
#define TMS570_EFUSE_EFCPINS_EFC_Selftest_Done BSP_BIT32(15)
103
104
/* field: EFC_Selftest_Error - This bit indicates the pass/fail status of the EFC ECC Selftest once the EFC Selftest Done */
105
#define TMS570_EFUSE_EFCPINS_EFC_Selftest_Error BSP_BIT32(14)
106
107
/* field: EFC_Single_Bit_Error - This bit indicates if a single bit error was corrected by the ECC logic during the autoload */
108
#define TMS570_EFUSE_EFCPINS_EFC_Single_Bit_Error BSP_BIT32(12)
109
110
/* field: EFC_Instruction_Error - This bit indicates an error occured during a factory test or program operation. */
111
#define TMS570_EFUSE_EFCPINS_EFC_Instruction_Error BSP_BIT32(11)
112
113
/* field: EFC_Autoload_Error - This bit indicates that some non-correctable error occurred during the autoload sequence */
114
#define TMS570_EFUSE_EFCPINS_EFC_Autoload_Error BSP_BIT32(10)
115
116
117
/*-----------------TMS570_EFUSE_EFC_ERR_STAT-----------------*/
118
/* field: Instruc_Done - Instruction done. */
119
#define TMS570_EFUSE_EFC_ERR_STAT_Instruc_Done BSP_BIT32(5)
120
121
/* field: Error_Code - The error status of the last instruction executed by the eFuse Controller */
122
#define TMS570_EFUSE_EFC_ERR_STAT_Error_Code(val) BSP_FLD32(val,0, 4)
123
#define TMS570_EFUSE_EFC_ERR_STAT_Error_Code_GET(reg) BSP_FLD32GET(reg,0, 4)
124
#define TMS570_EFUSE_EFC_ERR_STAT_Error_Code_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
125
126
127
/*-------------------TMS570_EFUSE_EFC_ST_CY-------------------*/
128
/* field: Cycles - This register is used to determine the number of cycles to run the eFuse controller ECC logic self test. */
129
/* Whole 32 bits */
130
131
/*------------------TMS570_EFUSE_EFC_ST_SIG------------------*/
132
/* field: Signature - This register is used to hold the expected signature for the eFuse ECC logic self test. */
133
/* Whole 32 bits */
134
135
136
#endif
/* LIBBSP_ARM_TMS570_EFUSE */
utility.h
This header file provides utility macros for BSPs.
tms570_efuse_t
Definition
reg_efuse.h:54
