RTEMS 6.3
reg_dcc.h
2
10
11/* The header file is generated by make_header.py from DCC.json */
12/* Current script's version can be found at: */
13/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15/*
16 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17 *
18 * Czech Technical University in Prague
19 * Zikova 1903/4
20 * 166 36 Praha 6
21 * Czech Republic
22 *
23 * All rights reserved.
24 *
25 * Redistribution and use in source and binary forms, with or without
26 * modification, are permitted provided that the following conditions are met:
27 *
28 * 1. Redistributions of source code must retain the above copyright notice, this
29 * list of conditions and the following disclaimer.
30 * 2. Redistributions in binary form must reproduce the above copyright notice,
31 * this list of conditions and the following disclaimer in the documentation
32 * and/or other materials provided with the distribution.
33 *
34 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44 *
45 * The views and conclusions contained in the software and documentation are those
46 * of the authors and should not be interpreted as representing official policies,
47 * either expressed or implied, of the FreeBSD Project.
48*/
49#ifndef LIBBSP_ARM_TMS570_DCC
50#define LIBBSP_ARM_TMS570_DCC
51
52#include <bsp/utility.h>
53
59
60typedef struct{
61 uint32_t GCTRL; /*DCC Global Control Register*/
62 uint32_t REV; /*DCC Revision Id Register*/
63 uint32_t CNT0SEED; /*DCC Counter0 Seed Register*/
64 uint32_t VALID0SEED; /*DCC Valid0 Seed Register*/
65 uint32_t CNT1SEED; /*DCC Counter1 Seed Register*/
66 uint32_t STAT; /*DCC Status Register*/
67 uint32_t CNT0; /*DCC Counter0 Value Register*/
68 uint32_t VALID0; /*DCC Valid0 Value Register*/
69 uint32_t CNT1; /*DCC Counter1 Value Register*/
70 uint32_t CNT1CLKSRC; /*DCC Counter1 Clock Source Selection Register*/
71 uint32_t CNT0CLKSRC; /*DCC Counter0 Clock Source Selection Register*/
73
74
75/*----------------------TMS570_DCC_GCTRL----------------------*/
76/* field: DONE_INT_ENA - Done Interrupt Enable. */
77#define TMS570_DCC_GCTRL_DONE_INT_ENA(val) BSP_FLD32(val,12, 15)
78#define TMS570_DCC_GCTRL_DONE_INT_ENA_GET(reg) BSP_FLD32GET(reg,12, 15)
79#define TMS570_DCC_GCTRL_DONE_INT_ENA_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
80
81/* field: SINGLE_SHOT - Single-Shot Mode Enable. */
82#define TMS570_DCC_GCTRL_SINGLE_SHOT(val) BSP_FLD32(val,8, 11)
83#define TMS570_DCC_GCTRL_SINGLE_SHOT_GET(reg) BSP_FLD32GET(reg,8, 11)
84#define TMS570_DCC_GCTRL_SINGLE_SHOT_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
85
86/* field: ERR_ENA - Error Interrupt Enable. */
87#define TMS570_DCC_GCTRL_ERR_ENA(val) BSP_FLD32(val,4, 7)
88#define TMS570_DCC_GCTRL_ERR_ENA_GET(reg) BSP_FLD32GET(reg,4, 7)
89#define TMS570_DCC_GCTRL_ERR_ENA_SET(reg,val) BSP_FLD32SET(reg, val,4, 7)
90
91/* field: DCC_ENA - DCC Enable. */
92#define TMS570_DCC_GCTRL_DCC_ENA(val) BSP_FLD32(val,0, 3)
93#define TMS570_DCC_GCTRL_DCC_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
94#define TMS570_DCC_GCTRL_DCC_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
95
96
97/*-----------------------TMS570_DCC_REV-----------------------*/
98/* field: SCHEME - Reads return 01, writes have no effect. */
99#define TMS570_DCC_REV_SCHEME(val) BSP_FLD32(val,30, 31)
100#define TMS570_DCC_REV_SCHEME_GET(reg) BSP_FLD32GET(reg,30, 31)
101#define TMS570_DCC_REV_SCHEME_SET(reg,val) BSP_FLD32SET(reg, val,30, 31)
102
103/* field: FUNC - Functional release number. Reads return 0x000, writes have no effect. */
104#define TMS570_DCC_REV_FUNC(val) BSP_FLD32(val,16, 27)
105#define TMS570_DCC_REV_FUNC_GET(reg) BSP_FLD32GET(reg,16, 27)
106#define TMS570_DCC_REV_FUNC_SET(reg,val) BSP_FLD32SET(reg, val,16, 27)
107
108/* field: RTL - Design release number. Reads return 0x00, writes have no effect. */
109#define TMS570_DCC_REV_RTL(val) BSP_FLD32(val,11, 15)
110#define TMS570_DCC_REV_RTL_GET(reg) BSP_FLD32GET(reg,11, 15)
111#define TMS570_DCC_REV_RTL_SET(reg,val) BSP_FLD32SET(reg, val,11, 15)
112
113/* field: MAJOR - Major revision number. Reads return 0x2, writes have no effect. */
114#define TMS570_DCC_REV_MAJOR(val) BSP_FLD32(val,8, 10)
115#define TMS570_DCC_REV_MAJOR_GET(reg) BSP_FLD32GET(reg,8, 10)
116#define TMS570_DCC_REV_MAJOR_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
117
118/* field: CUSTOM - Custom version number. Reads return 0x0, writes have no effect. */
119#define TMS570_DCC_REV_CUSTOM(val) BSP_FLD32(val,6, 7)
120#define TMS570_DCC_REV_CUSTOM_GET(reg) BSP_FLD32GET(reg,6, 7)
121#define TMS570_DCC_REV_CUSTOM_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
122
123/* field: MINOR - Minor revision number. Reads return 0x4, writes have no effect. */
124#define TMS570_DCC_REV_MINOR(val) BSP_FLD32(val,0, 5)
125#define TMS570_DCC_REV_MINOR_GET(reg) BSP_FLD32GET(reg,0, 5)
126#define TMS570_DCC_REV_MINOR_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
127
128
129/*--------------------TMS570_DCC_CNT0SEED--------------------*/
130/* field: COUNT0_SEED - Seed value for DCC Counter0. */
131#define TMS570_DCC_CNT0SEED_COUNT0_SEED(val) BSP_FLD32(val,0, 19)
132#define TMS570_DCC_CNT0SEED_COUNT0_SEED_GET(reg) BSP_FLD32GET(reg,0, 19)
133#define TMS570_DCC_CNT0SEED_COUNT0_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
134
135
136/*-------------------TMS570_DCC_VALID0SEED-------------------*/
137/* field: VALID0_SEED - XXX */
138#define TMS570_DCC_VALID0SEED_VALID0_SEED(val) BSP_FLD32(val,0, 15)
139#define TMS570_DCC_VALID0SEED_VALID0_SEED_GET(reg) BSP_FLD32GET(reg,0, 15)
140#define TMS570_DCC_VALID0SEED_VALID0_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
141
142
143/*--------------------TMS570_DCC_CNT1SEED--------------------*/
144/* field: COUNT1_SEED - Seed value for DCC Counter1. */
145#define TMS570_DCC_CNT1SEED_COUNT1_SEED(val) BSP_FLD32(val,0, 19)
146#define TMS570_DCC_CNT1SEED_COUNT1_SEED_GET(reg) BSP_FLD32GET(reg,0, 19)
147#define TMS570_DCC_CNT1SEED_COUNT1_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
148
149
150/*----------------------TMS570_DCC_STAT----------------------*/
151/* field: DONE_FLG - Single-Shot Sequence Done flag. */
152#define TMS570_DCC_STAT_DONE_FLG BSP_BIT32(1)
153
154/* field: ERR_FLG - Error flag. Indicates that a DCC error has occurred. */
155#define TMS570_DCC_STAT_ERR_FLG BSP_BIT32(0)
156
157
158/*----------------------TMS570_DCC_CNT0----------------------*/
159/* field: COUNT0 - Current value of DCC Counter0. */
160#define TMS570_DCC_CNT0_COUNT0(val) BSP_FLD32(val,0, 19)
161#define TMS570_DCC_CNT0_COUNT0_GET(reg) BSP_FLD32GET(reg,0, 19)
162#define TMS570_DCC_CNT0_COUNT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
163
164
165/*---------------------TMS570_DCC_VALID0---------------------*/
166/* field: VALID0 - Current value for DCC Valid0. */
167#define TMS570_DCC_VALID0_VALID0(val) BSP_FLD32(val,0, 15)
168#define TMS570_DCC_VALID0_VALID0_GET(reg) BSP_FLD32GET(reg,0, 15)
169#define TMS570_DCC_VALID0_VALID0_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
170
171
172/*----------------------TMS570_DCC_CNT1----------------------*/
173/* field: COUNT1 - Current value for DCC Counter1. */
174#define TMS570_DCC_CNT1_COUNT1(val) BSP_FLD32(val,0, 19)
175#define TMS570_DCC_CNT1_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 19)
176#define TMS570_DCC_CNT1_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
177
178
179/*-------------------TMS570_DCC_CNT1CLKSRC-------------------*/
180/* field: KEY - Key to enable clock source selection for Counter1. */
181#define TMS570_DCC_CNT1CLKSRC_KEY(val) BSP_FLD32(val,12, 15)
182#define TMS570_DCC_CNT1CLKSRC_KEY_GET(reg) BSP_FLD32GET(reg,12, 15)
183#define TMS570_DCC_CNT1CLKSRC_KEY_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
184
185/* field: CNT1_CLKSRC - Clock Source for Counter1 when KEY is programmed to be 0xA. */
186#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC(val) BSP_FLD32(val,0, 3)
187#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC_GET(reg) BSP_FLD32GET(reg,0, 3)
188#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
189
190
191/*-------------------TMS570_DCC_CNT0CLKSRC-------------------*/
192/* field: CNT0_CLKSRC - Clock Source for Counter0 */
193#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC(val) BSP_FLD32(val,0, 3)
194#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC_GET(reg) BSP_FLD32GET(reg,0, 3)
195#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
196
197
198
199#endif /* LIBBSP_ARM_TMS570_DCC */
This header file provides utility macros for BSPs.
tms570_dcc1_cnt0_clksrc
Definition reg_dcc.h:54
@ DCC1_CNT0_HF_LPO
Definition reg_dcc.h:55
@ DCC1_CNT0_TCK
Definition reg_dcc.h:56
@ DCC1_CNT0_OSCIN
Definition reg_dcc.h:57
Definition reg_dcc.h:60
