378/* field: IntPndReg8 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Interrupt Pending X Register will be set. */
383/* field: IntPndReg7 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Interrupt Pending X Register will be set. */
388/* field: IntPndReg6 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Interrupt Pending X Register will be set. */
393/* field: IntPndReg5 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Interrupt Pending X Register will be set. */
398/* field: IntPndReg4 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Interrupt Pending X Register will be set. */
403/* field: IntPndReg3 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Interrupt Pending X Register will be set. */
408/* field: IntPndReg2 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Interrupt Pending X Register will be set. */
413/* field: IntPndReg1 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Interrupt Pending X Register will be set. */
424/* field: MsgValReg8 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Message Valid X Register will be set. */
429/* field: MsgValReg7 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Message Valid X Register will be set. */
434/* field: MsgValReg6 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Message Valid X Register will be set. */
439/* field: MsgValReg5 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Message Valid X Register will be set. */
444/* field: MsgValReg4 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Message Valid X Register will be set. */
449/* field: MsgValReg3 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Message Valid X Register will be set. */
454/* field: MsgValReg2 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Message Valid X Register will be set. */
459/* field: MsgValReg1 - If at least one of the IntPnd bits of these message objects are set, the corresponding bit in the Message Valid X Register will be set. */
