RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
ti_herc
reg_crc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
/* The header file is generated by make_header.py from CRC.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_CRC
50
#define LIBBSP_ARM_TMS570_CRC
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t CTRL0;
/*CRC Global Control Register*/
56
uint8_t reserved1 [4];
57
uint32_t CTRL1;
/*CRC Global Control Register 1*/
58
uint8_t reserved2 [4];
59
uint32_t CTRL2;
/*CRC Global Control Register 2*/
60
uint8_t reserved3 [4];
61
uint32_t INTS;
/*CRC Interrupt Enable Set Register*/
62
uint8_t reserved4 [4];
63
uint32_t INTR;
/*CRC Interrupt Enable Reset Register*/
64
uint8_t reserved5 [4];
65
uint32_t STATUS;
/*CRC Interrupt Status Register*/
66
uint8_t reserved6 [4];
67
uint32_t INT_OFFS_REG;
/*CRC Interrupt Offset Register*/
68
uint8_t reserved7 [4];
69
uint32_t BUSY;
/*CRC Busy Register*/
70
uint8_t reserved8 [4];
71
uint32_t PCOUNT_REG1;
/*CRC Channel 1 Pattern Counter Preload Register*/
72
uint32_t SCOUNT_REG1;
/*CRC Channel 1 Sector Counter Preload Register*/
73
uint32_t CURSEC_REG1;
/*CRC Channel 1 Current Sector Register*/
74
uint32_t WDTOPLD1;
/*CRC Channel 1 Watchdog Timeout Preload Register*/
75
uint32_t BCTOPLD1;
/*CRC Channel 1 Block Complete Timeout Preload Register*/
76
uint8_t reserved9 [12];
77
uint32_t PSA_SIGREGL1;
/*Channel 1 PSA Signature Low Register*/
78
uint32_t PSA_SIGREGH1;
/*Channel 1 PSA Signature High Register*/
79
uint32_t REGL1;
/*Channel 1 CRC Value Low Register*/
80
uint32_t REGH1;
/*Channel 1 CRC Value High Register*/
81
uint32_t PSA_SECSIGREGL1;
/*Channel 1 PSA Sector Signature Low Register*/
82
uint32_t PSA_SECSIGREGH1;
/*Channel 1 PSA Sector Signature High Register*/
83
uint32_t RAW_DATAREGL1;
/*Channel 1 Raw Data Low Register*/
84
uint32_t RAW_DATAREGH1;
/*Channel 1 Raw Data High Register*/
85
uint32_t PCOUNT_REG2;
/*CRC Channel 2 Pattern Counter Preload Register*/
86
uint32_t SCOUNT_REG2;
/*CRC Channel 2 Sector Counter Preload Register*/
87
uint32_t CURSEC_REG2;
/*CRC Current Sector Register 2*/
88
uint32_t WDTOPLD2;
/*CRC Channel 2 Watchdog Timeout Preload Register A*/
89
uint32_t BCTOPLD2;
/*CRC Channel 2 Block Complete Timeout Preload Register B*/
90
uint8_t reserved10 [12];
91
uint32_t PSA_SIGREGL2;
/*Channel 2 PSA Signature Low Register*/
92
uint32_t PSA_SIGREGH2;
/*Channel 2 PSA Signature High Register*/
93
uint32_t REGL2;
/*Channel 2 CRC Value Low Register*/
94
uint32_t REGH2;
/*Channel 2 CRC Value High Register*/
95
uint32_t PSA_SECSIGREGL2;
/*Channel 2 PSA Sector Signature Low Register*/
96
uint32_t PSA_SECSIGREGH2;
/*Channel 2 PSA Sector Signature High Register*/
97
uint32_t RAW_DATAREGL2;
/*Channel 2 Raw Data Low Register*/
98
uint32_t RAW_DATAREGH2;
/*Channel 2 Raw Data High Register*/
99
uint8_t reserved11 [128];
100
uint32_t BUS_SEL;
/*Data Bus Selection Register*/
101
tms570_crc_t
102
103
104
/*----------------------TMS570_CRC_CTRL0----------------------*/
105
/* field: CH2_PSA_SWREST - Channel 2 PSA Software Reset. When set, the PSA Signature Register is reset to all zero. */
106
#define TMS570_CRC_CTRL0_CH2_PSA_SWREST BSP_BIT32(8)
107
108
/* field: CH1_PSA_SWREST - Channel 1 PSA Software Reset. When set, the PSA Signature Register is reset to all zero. */
109
#define TMS570_CRC_CTRL0_CH1_PSA_SWREST BSP_BIT32(0)
110
111
112
/*----------------------TMS570_CRC_CTRL1----------------------*/
113
/* field: PWDN - Power Down. */
114
#define TMS570_CRC_CTRL1_PWDN BSP_BIT32(0)
115
116
117
/*----------------------TMS570_CRC_CTRL2----------------------*/
118
/* field: CH2_MODE - Channel 2 Mode Selection */
119
#define TMS570_CRC_CTRL2_CH2_MODE(val) BSP_FLD32(val,8, 9)
120
#define TMS570_CRC_CTRL2_CH2_MODE_GET(reg) BSP_FLD32GET(reg,8, 9)
121
#define TMS570_CRC_CTRL2_CH2_MODE_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
122
123
/* field: CH1_TRACEEN - Channel 1 Data Trace Enable. When set, the channel is put into data trace mode. */
124
#define TMS570_CRC_CTRL2_CH1_TRACEEN BSP_BIT32(4)
125
126
/* field: CH1_MODE - Channel 1 Mode Selection */
127
#define TMS570_CRC_CTRL2_CH1_MODE(val) BSP_FLD32(val,0, 1)
128
#define TMS570_CRC_CTRL2_CH1_MODE_GET(reg) BSP_FLD32GET(reg,0, 1)
129
#define TMS570_CRC_CTRL2_CH1_MODE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
130
131
132
/*----------------------TMS570_CRC_INTS----------------------*/
133
/* field: CH2_TIMEOUTENS - Channel 2 Timeout Interrupt Enable Bit. */
134
#define TMS570_CRC_INTS_CH2_TIMEOUTENS BSP_BIT32(12)
135
136
/* field: CH2_UNDERENS - Channel 2 Underrun Interrupt Enable Bit. */
137
#define TMS570_CRC_INTS_CH2_UNDERENS BSP_BIT32(11)
138
139
/* field: CH2_OVERENS - Channel 2 Overrun Interrupt Enable Bit. */
140
#define TMS570_CRC_INTS_CH2_OVERENS BSP_BIT32(10)
141
142
/* field: CH2_CRCFAILENS - Channel 2 CRC Fail Interrupt Enable Bit. */
143
#define TMS570_CRC_INTS_CH2_CRCFAILENS BSP_BIT32(9)
144
145
/* field: CH2_CCITENS - Channel 2 Compression Complete Interrupt Enable Bit. */
146
#define TMS570_CRC_INTS_CH2_CCITENS BSP_BIT32(8)
147
148
/* field: CH1_TIMEOUTENS - Channel 1 Timeout Interrupt Enable Bit. */
149
#define TMS570_CRC_INTS_CH1_TIMEOUTENS BSP_BIT32(4)
150
151
/* field: CH1_UNDERENS - Channel 1 Underrun Interrupt Enable Bit. */
152
#define TMS570_CRC_INTS_CH1_UNDERENS BSP_BIT32(3)
153
154
/* field: CH1_OVERENS - CH1_OVERENS Channel 1 Overrun Interrupt Enable Bit. */
155
#define TMS570_CRC_INTS_CH1_OVERENS BSP_BIT32(2)
156
157
/* field: CH1_CRCFAILENS - Channel 1 CRC Fail Interrupt Enable Bit. */
158
#define TMS570_CRC_INTS_CH1_CRCFAILENS BSP_BIT32(1)
159
160
/* field: CH1_CCITENS - Channel 1 Compression Complete Interrupt Enable Bit. */
161
#define TMS570_CRC_INTS_CH1_CCITENS BSP_BIT32(0)
162
163
164
/*----------------------TMS570_CRC_INTR----------------------*/
165
/* field: CH2_TIMEOUTENR - Channel 2 Timeout Interrupt Enable Bit. */
166
#define TMS570_CRC_INTR_CH2_TIMEOUTENR BSP_BIT32(12)
167
168
/* field: CH2_UNDERENR - Channel 2 Underrun Interrupt Enable Bit. */
169
#define TMS570_CRC_INTR_CH2_UNDERENR BSP_BIT32(11)
170
171
/* field: CH2_OVERENR - Channel 2 Overrun Interrupt Enable Bit. */
172
#define TMS570_CRC_INTR_CH2_OVERENR BSP_BIT32(10)
173
174
/* field: CH2_CRCFAILENR - Channel 2 CRC Fail Interrupt Enable Bit. */
175
#define TMS570_CRC_INTR_CH2_CRCFAILENR BSP_BIT32(9)
176
177
/* field: CH2_CCITENR - Channel 2 Compression Complete Interrupt Enable Bit. */
178
#define TMS570_CRC_INTR_CH2_CCITENR BSP_BIT32(8)
179
180
/* field: CH1_TIMEOUTENR - Channel 1 Timeout Interrupt Enable Bit. */
181
#define TMS570_CRC_INTR_CH1_TIMEOUTENR BSP_BIT32(4)
182
183
/* field: CH1_UNDERENR - interrupt. Writing a zero has no effect. */
184
#define TMS570_CRC_INTR_CH1_UNDERENR BSP_BIT32(3)
185
186
/* field: CH1_OVERENR - CH1_OVERENR */
187
#define TMS570_CRC_INTR_CH1_OVERENR BSP_BIT32(2)
188
189
/* field: CH1_CRCFAILENR - Channel 1 CRC Fail Interrupt Enable Bit. */
190
#define TMS570_CRC_INTR_CH1_CRCFAILENR BSP_BIT32(1)
191
192
/* field: CH1_CCITENR - Channel 1 Compression Complete Interrupt Enable Bit. */
193
#define TMS570_CRC_INTR_CH1_CCITENR BSP_BIT32(0)
194
195
196
/*---------------------TMS570_CRC_STATUS---------------------*/
197
/* field: CH2_TIMEOUT - Channel 2 CRC Timeout Status Flag. This bit is cleared by writing a '1' to it only. */
198
#define TMS570_CRC_STATUS_CH2_TIMEOUT BSP_BIT32(12)
199
200
/* field: CH2_UNDER - Channel 2 CRC Underrun Status Flag. This bit is cleared by writing a '1' to it only. */
201
#define TMS570_CRC_STATUS_CH2_UNDER BSP_BIT32(11)
202
203
/* field: CH2_OVER - Channel 2 CRC Overrun Status Flag. This bit is cleared by writing a '1' to it only. */
204
#define TMS570_CRC_STATUS_CH2_OVER BSP_BIT32(10)
205
206
/* field: CH2_CRCFAIL - Channel 2 CRC Compare Fail Status Flag. This bit is cleared by writing a '1' to it only. */
207
#define TMS570_CRC_STATUS_CH2_CRCFAIL BSP_BIT32(9)
208
209
/* field: CH2_CCIT - Channel 2 CRC Pattern Compression Complete Status Flag. */
210
#define TMS570_CRC_STATUS_CH2_CCIT BSP_BIT32(8)
211
212
/* field: CH1_TIMEOUT - Writing a zero has no effect. Reading from this bit gives the status (interrupt enable/disable). */
213
#define TMS570_CRC_STATUS_CH1_TIMEOUT BSP_BIT32(4)
214
215
/* field: CH1_UNDER - Channel 1 Underrun Interrupt Enable Bit. */
216
#define TMS570_CRC_STATUS_CH1_UNDER BSP_BIT32(3)
217
218
/* field: CH1_OVER - Channel 1 Overrun Interrupt Enable Bit. Writing a one to this bit disable the overrun interrupt. */
219
#define TMS570_CRC_STATUS_CH1_OVER BSP_BIT32(2)
220
221
/* field: CH1_CRCFAIL - Channel 1 CRC Fail Interrupt Enable Bit. */
222
#define TMS570_CRC_STATUS_CH1_CRCFAIL BSP_BIT32(1)
223
224
/* field: CH1_CCIT - Channel 1 CRC Pattern Compression Complete Status Flag. */
225
#define TMS570_CRC_STATUS_CH1_CCIT BSP_BIT32(0)
226
227
228
/*------------------TMS570_CRC_INT_OFFS_REG------------------*/
229
/* field: OFSTREG - CRC Interrupt Offset. This register indicates the highest priority pending interrupt vector address. */
230
#define TMS570_CRC_INT_OFFS_REG_OFSTREG(val) BSP_FLD32(val,0, 7)
231
#define TMS570_CRC_INT_OFFS_REG_OFSTREG_GET(reg) BSP_FLD32GET(reg,0, 7)
232
#define TMS570_CRC_INT_OFFS_REG_OFSTREG_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
233
234
235
/*----------------------TMS570_CRC_BUSY----------------------*/
236
/* field: CH2_BUSY - CH2_BUSY. */
237
#define TMS570_CRC_BUSY_CH2_BUSY BSP_BIT32(8)
238
239
/* field: CH1_BUSY - CH1_BUSY. */
240
#define TMS570_CRC_BUSY_CH1_BUSY BSP_BIT32(0)
241
242
243
/*-------------------TMS570_CRC_PCOUNT_REG1-------------------*/
244
/* field: CRC_PAT_COUNT1 - Channel 1 Pattern Counter Preload Register. */
245
#define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1(val) BSP_FLD32(val,0, 19)
246
#define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 19)
247
#define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
248
249
250
/*-------------------TMS570_CRC_SCOUNT_REG1-------------------*/
251
/* field: CRC_SEC_COUNT1 - Channel 1 Sector Counter Preload Register. */
252
#define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1(val) BSP_FLD32(val,0, 15)
253
#define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 15)
254
#define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
255
256
257
/*-------------------TMS570_CRC_CURSEC_REG1-------------------*/
258
/* field: CRC_CURSEC1 - Channel 1 Current Sector ID Register. */
259
#define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1(val) BSP_FLD32(val,0, 15)
260
#define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1_GET(reg) BSP_FLD32GET(reg,0, 15)
261
#define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
262
263
264
/*--------------------TMS570_CRC_WDTOPLD1--------------------*/
265
/* field: CRC_WDTOPLD1 - CRC_WDTOPLD1 */
266
#define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1(val) BSP_FLD32(val,0, 23)
267
#define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1_GET(reg) BSP_FLD32GET(reg,0, 23)
268
#define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
269
270
271
/*--------------------TMS570_CRC_BCTOPLD1--------------------*/
272
/* field: CRC_BCTOPLD1 - Channel 1 Block Complete Timeout Counter Preload Register. */
273
#define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1(val) BSP_FLD32(val,0, 23)
274
#define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1_GET(reg) BSP_FLD32GET(reg,0, 23)
275
#define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
276
277
278
/*------------------TMS570_CRC_PSA_SIGREGL1------------------*/
279
/* field: PSASIG1 - Channel 1 PSA Signature Low Register. */
280
/* Whole 32 bits */
281
282
/*------------------TMS570_CRC_PSA_SIGREGH1------------------*/
283
/* field: PSASIG1 - register. */
284
/* Whole 32 bits */
285
286
/*----------------------TMS570_CRC_REGL1----------------------*/
287
/* field: CRC1 - Channel 1 CRC Value Low Register. */
288
/* Whole 32 bits */
289
290
/*----------------------TMS570_CRC_REGH1----------------------*/
291
292
/* Whole 32 bits */
293
294
/*-----------------TMS570_CRC_PSA_SECSIGREGL1-----------------*/
295
/* field: PSASECSIG1 - Channel 1 PSA Sector Signature Low Register. */
296
/* Whole 32 bits */
297
298
/*-----------------TMS570_CRC_PSA_SECSIGREGH1-----------------*/
299
/* field: PSASECSIG1 - Channel 1 PSA Sector Signature High Register. */
300
/* Whole 32 bits */
301
302
/*------------------TMS570_CRC_RAW_DATAREGL1------------------*/
303
/* field: RAW_DATA1 - hannel 1 Raw Data Low Register.This register contains bits 31:0 of the uncompressed raw data. */
304
/* Whole 32 bits */
305
306
/*------------------TMS570_CRC_RAW_DATAREGH1------------------*/
307
/* field: RAW_DATA1 - Channel 1 Raw Data High Register. This register contains bits 63:32 of the uncompressed raw data. */
308
/* Whole 32 bits */
309
310
/*-------------------TMS570_CRC_PCOUNT_REG2-------------------*/
311
/* field: CRC_PAT_COUNT2 - Channel 2 Pattern Counter Preload Register. */
312
#define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2(val) BSP_FLD32(val,0, 19)
313
#define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2_GET(reg) BSP_FLD32GET(reg,0, 19)
314
#define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
315
316
317
/*-------------------TMS570_CRC_SCOUNT_REG2-------------------*/
318
/* field: CRC_SEC_COUNT2 - Channel 2 Sector Counter Preload Register. */
319
#define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2(val) BSP_FLD32(val,0, 15)
320
#define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2_GET(reg) BSP_FLD32GET(reg,0, 15)
321
#define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
322
323
324
/*-------------------TMS570_CRC_CURSEC_REG2-------------------*/
325
/* field: CRC_CURSEC2 - Channel 2 Current Sector ID Register. */
326
#define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2(val) BSP_FLD32(val,0, 15)
327
#define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2_GET(reg) BSP_FLD32GET(reg,0, 15)
328
#define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
329
330
331
/*--------------------TMS570_CRC_WDTOPLD2--------------------*/
332
/* field: CRC_WDTOPLD2 - Channel 2 Watchdog Timeout Counter Preload Register. */
333
#define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2(val) BSP_FLD32(val,0, 23)
334
#define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2_GET(reg) BSP_FLD32GET(reg,0, 23)
335
#define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
336
337
338
/*--------------------TMS570_CRC_BCTOPLD2--------------------*/
339
/* field: CRC_BCTOPLD2 - Channel 2 Block Complete Timeout Counter Preload Register. */
340
#define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2(val) BSP_FLD32(val,0, 23)
341
#define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2_GET(reg) BSP_FLD32GET(reg,0, 23)
342
#define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
343
344
345
/*------------------TMS570_CRC_PSA_SIGREGL2------------------*/
346
/* field: PSASIG2 - Channel 2 PSA Signature Low Register. */
347
/* Whole 32 bits */
348
349
/*------------------TMS570_CRC_PSA_SIGREGH2------------------*/
350
/* field: PSASIG2 - Channel 2 PSA Signature High Register. */
351
/* Whole 32 bits */
352
353
/*----------------------TMS570_CRC_REGL2----------------------*/
354
/* field: CRC2 - stored at CRC2[31:0] register. */
355
/* Whole 32 bits */
356
357
/*----------------------TMS570_CRC_REGH2----------------------*/
358
/* field: CRC2 - Channel 2 CRC Value High Register. */
359
/* Whole 32 bits */
360
361
/*-----------------TMS570_CRC_PSA_SECSIGREGL2-----------------*/
362
/* field: PSASECSIG2 - Channel 2 PSA Sector Signature Low Register. */
363
/* Whole 32 bits */
364
365
/*-----------------TMS570_CRC_PSA_SECSIGREGH2-----------------*/
366
/* field: PSASECSIG2 - Channel 2 PSA Sector Signature High Register. */
367
/* Whole 32 bits */
368
369
/*------------------TMS570_CRC_RAW_DATAREGL2------------------*/
370
/* field: RAW_DATA2 - Channel 2 Raw Data Low Register. This register contains bits 31:0 of the uncompressed raw data.. */
371
/* Whole 32 bits */
372
373
/*------------------TMS570_CRC_RAW_DATAREGH2------------------*/
374
/* field: RAW_DATA2 - Channel 2 Raw Data High Register. This register contains bits 63:32 of the uncompressed raw data.. */
375
/* Whole 32 bits */
376
377
/*---------------------TMS570_CRC_BUS_SEL---------------------*/
378
/* field: MEn - Enable/disables the tracing of Peripheral Bus Master */
379
#define TMS570_CRC_BUS_SEL_MEn BSP_BIT32(2)
380
381
/* field: DTCMEn - Enable/disables the tracing of data TCM */
382
#define TMS570_CRC_BUS_SEL_DTCMEn BSP_BIT32(1)
383
384
/* field: ITCMEn - Enable/disables the tracing of instruction TCM */
385
#define TMS570_CRC_BUS_SEL_ITCMEn BSP_BIT32(0)
386
387
388
389
#endif
/* LIBBSP_ARM_TMS570_CRC */
utility.h
This header file provides utility macros for BSPs.
tms570_crc_t
Definition
reg_crc.h:54
