RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
ti_herc
reg_adc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
/* The header file is generated by make_header.py from ADC.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_ADC
50
#define LIBBSP_ARM_TMS570_ADC
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t BUF0;
/*Group 0-2 result buffer 0 register*/
56
uint32_t BUF1;
/*Group 0-2 result buffer 1 register*/
57
uint32_t BUF2;
/*Group 0-2 result buffer 2 register*/
58
uint32_t BUF3;
/*Group 0-2 result buffer 3 register*/
59
uint32_t BUF4;
/*Group 0-2 result buffer 4 register*/
60
uint32_t BUF5;
/*Group 0-2 result buffer 5 register*/
61
uint32_t BUF6;
/*Group 0-2 result buffer 6 register*/
62
uint32_t BUF7;
/*Group 0-2 result buffer 7 register*/
63
tms570_gxbuf_t
64
65
typedef
struct
66
uint32_t RSTCR;
/*ADC Reset Control Register*/
67
uint32_t OPMODECR;
/*ADC Operating Mode Control Register*/
68
uint32_t CLOCKCR;
/*ADC Clock Control Register*/
69
uint32_t CALCR;
/*ADC Calibration Mode Control Register*/
70
uint32_t GxMODECR[3];
/*ADC Event Group Operating Mode Control Register*/
71
uint32_t EVSRC;
/*ADC Trigger Source Select Register*/
72
uint32_t G1SRC;
/*ADC Group1 Trigger Source Select Register*/
73
uint32_t G2SRC;
/*ADC Group2 Trigger Source Select Register*/
74
uint32_t GxINTENA[3];
/*ADC Event Interrupt Enable Control Register*/
75
uint32_t GxINTFLG[3];
/*ADC Event Group Interrupt Flag Register*/
76
uint32_t GxINTCR[3];
/*ADC Event Group Threshold Interrupt Control Register*/
77
uint32_t EVDMACR;
/*ADC Event Group DMA Control Register*/
78
uint32_t G1DMACR;
/*ADC Group1 DMA Control Register*/
79
uint32_t G2DMACR;
/*ADC Group2 DMA Control Register*/
80
uint32_t BNDCR;
/*ADC Results Memory Configuration Register*/
81
uint32_t BNDEND;
/*ADC Results Memory Size Configuration Register*/
82
uint32_t EVSAMP;
/*ADC Event Group Sampling Time Configuration Register*/
83
uint32_t G1SAMP;
/*ADC Group1 Sampling Time Configuration Register()*/
84
uint32_t G2SAMP;
/*ADC Group2 Sampling Time Configuration Register*/
85
uint32_t EVSR;
/*ADC Event Group Status Register*/
86
uint32_t G1SR;
/*ADC Group1 Status Register*/
87
uint32_t G2SR;
/*ADC Group2 Status Register*/
88
uint32_t GxSEL[3];
/*ADC Event Group Channel Select Register*/
89
uint32_t CALR;
/*ADC Calibration and Error Offset Correction Register*/
90
uint32_t SMSTATE;
/*ADC State Machine Status Register*/
91
uint32_t LASTCONV;
/*ADC Channel Last Conversion Value Register*/
92
tms570_gxbuf_t
GxBUF[3];
/*ADC Event Group Results Emulation FIFO Register*/
93
uint32_t EVEMUBUFFER;
94
uint32_t G1EMUBUFFER;
/*ADC Group1 Results Emulation FIFO Register*/
95
uint32_t G2EMUBUFFER;
/*ADC Group2 Results Emulation FIFO Register*/
96
uint32_t EVTDIR;
/*ADC ADEVT Pin Direction Control Register*/
97
uint32_t EVTOUT;
/*ADC ADEVT Pin Output Value Control Register*/
98
uint32_t EVTIN;
/*ADC ADEVT Pin Input Value Register*/
99
uint32_t EVTSET;
/*ADC ADEVT Pin Set Register*/
100
uint32_t EVTCLR;
/*ADC ADEVT Pin Clear Register*/
101
uint32_t EVTPDR;
/*ADC ADEVT Pin Open Drain Enable Register*/
102
uint32_t EVTPDIS;
/*ADC ADEVT Pin Pull Control Disable Register*/
103
uint32_t EVTPSEL;
/*ADC ADEVT Pin Pull Control Select Register*/
104
uint32_t EVSAMPDISEN;
/*ADC Event Group Sample Cap Discharge Control Register*/
105
uint32_t G1SAMPDISEN;
/*ADC Group1 Sample Cap Discharge Control Register*/
106
uint32_t G2SAMPDISEN;
/*ADC Group2 Sample Cap Discharge Control Register*/
107
uint32_t MAGINTCR1;
/*ADC Magnitude Compare Interrupt Control Register 2*/
108
uint32_t MAGINT1MASK;
/*ADC Magnitude Compare Mask Register 0*/
109
uint32_t MAGINTCR2;
110
uint32_t MAGINT2MASK;
111
uint32_t MAGINTCR3;
112
uint32_t MAGINT3MASK;
113
uint8_t reserved1 [24];
114
uint32_t MAGTHRINTENASET;
/*ADC Magnitude Compare Interrupt Enable Set Register*/
115
uint32_t MAGTHRINTENACLR;
/*ADC Magnitude Compare Interrupt Enable Clear Register*/
116
uint32_t MAGTHRINTFLG;
/*ADC Magnitude Compare Interrupt Flag Register*/
117
uint32_t MAGTHRINTOFFSET;
/*ADC Magnitude Compare Interrupt Offset Register*/
118
uint32_t GxFIFORESETCR[3];
/*ADC Event Group FIFO Reset Control Register*/
119
uint32_t EVRAMWRADDR;
/*ADC Event Group RAM Write Address Register*/
120
uint32_t G1RAMWRADDR;
/*ADC Group1 RAM Write Address Register*/
121
uint32_t G2RAMWRADDR;
/*ADC Group2 RAM Write Address Register*/
122
uint32_t PARCR;
/*ADC Parity Control Register*/
123
uint32_t PARADDR;
/*ADC Parity Error Address Register*/
124
uint32_t PWRUPDLYCTRL;
/*ADC Power-Up Delay Control Register*/
125
tms570_adc_t
126
127
128
/*----------------------TMS570_ADC_BUFx----------------------*/
129
/* field: G2_EMPTY_10bit_mode - Group2 FIFO Empty. */
130
#define TMS570_ADC_BUFx_G2_EMPTY_10bit_mode BSP_BIT32(15)
131
132
/* field: G2_CHID_10bit_mode - Group2 Channel Id. */
133
#define TMS570_ADC_BUFx_G2_CHID_10bit_mode(val) BSP_FLD32(val,10, 14)
134
#define TMS570_ADC_BUFx_G2_CHID_10bit_mode_GET(reg) BSP_FLD32GET(reg,10, 14)
135
#define TMS570_ADC_BUFx_G2_CHID_10bit_mode_SET(reg,val) BSP_FLD32SET(reg, val,10, 14)
136
137
/* field: G2_DR_10bit_mode - Group2 Digital Conversion Result. */
138
#define TMS570_ADC_BUFx_G2_DR_10bit_mode(val) BSP_FLD32(val,0, 9)
139
#define TMS570_ADC_BUFx_G2_DR_10bit_mode_GET(reg) BSP_FLD32GET(reg,0, 9)
140
#define TMS570_ADC_BUFx_G2_DR_10bit_mode_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
141
142
/* field: G2_EMPTY_12bit_mode - Group2 FIFO Empty. */
143
#define TMS570_ADC_BUFx_G2_EMPTY_12bit_mode BSP_BIT32(31)
144
145
/* field: G2_CHID_12bit_mode - Group2 Channel Id. */
146
#define TMS570_ADC_BUFx_G2_CHID_12bit_mode(val) BSP_FLD32(val,16, 20)
147
#define TMS570_ADC_BUFx_G2_CHID_12bit_mode_GET(reg) BSP_FLD32GET(reg,16, 20)
148
#define TMS570_ADC_BUFx_G2_CHID_12bit_mode_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
149
150
/* field: G2_DR_12bit_mode - Group2 Digital Conversion Result. */
151
#define TMS570_ADC_BUFx_G2_DR_12bit_mode(val) BSP_FLD32(val,0, 11)
152
#define TMS570_ADC_BUFx_G2_DR_12bit_mode_GET(reg) BSP_FLD32GET(reg,0, 11)
153
#define TMS570_ADC_BUFx_G2_DR_12bit_mode_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
154
155
156
/*----------------------TMS570_ADC_RSTCR----------------------*/
157
/* field: RESET - This bit is used to reset the ADC internal state machines and control/status registers. */
158
#define TMS570_ADC_RSTCR_RESET BSP_BIT32(0)
159
160
161
/*--------------------TMS570_ADC_OPMODECR--------------------*/
162
/* field: 10_12_BIT - This bit controls the resolution of the ADC core. */
163
#define TMS570_ADC_OPMODECR_10_12_BIT BSP_BIT32(31)
164
165
166
/*---------------------TMS570_ADC_CLOCKCR---------------------*/
167
/* field: PS - ADC Clock Prescaler. These bits define the prescaler value for the ADC core clock (ADCLK). */
168
#define TMS570_ADC_CLOCKCR_PS(val) BSP_FLD32(val,0, 4)
169
#define TMS570_ADC_CLOCKCR_PS_GET(reg) BSP_FLD32GET(reg,0, 4)
170
#define TMS570_ADC_CLOCKCR_PS_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
171
172
173
/*----------------------TMS570_ADC_CALCR----------------------*/
174
/* field: SELF_TEST - ADC Self Test Enable. */
175
#define TMS570_ADC_CALCR_SELF_TEST BSP_BIT32(24)
176
177
/* field: CAL_ST - ADC Calibration Conversion Start. */
178
#define TMS570_ADC_CALCR_CAL_ST BSP_BIT32(16)
179
180
/* field: BRIDGE_EN - Bridge Enable. */
181
#define TMS570_ADC_CALCR_BRIDGE_EN BSP_BIT32(9)
182
183
/* field: HILO - ADC Self Test mode and Calibration Mode Reference Source Selection. */
184
#define TMS570_ADC_CALCR_HILO BSP_BIT32(8)
185
186
/* field: CAL_EN - ADC Calibration Enable. */
187
#define TMS570_ADC_CALCR_CAL_EN BSP_BIT32(0)
188
189
190
/*--------------------TMS570_ADC_GxMODECR--------------------*/
191
/* field: No_Reset_on_ChnSel - No Event Group Results Memory Reset on New Channel Select. */
192
#define TMS570_ADC_GxMODECR_No_Reset_on_ChnSel BSP_BIT32(16)
193
194
/* field: EV_DATA_FMT - Event Group Read Data Format. */
195
#define TMS570_ADC_GxMODECR_EV_DATA_FMT(val) BSP_FLD32(val,8, 9)
196
#define TMS570_ADC_GxMODECR_EV_DATA_FMT_GET(reg) BSP_FLD32GET(reg,8, 9)
197
#define TMS570_ADC_GxMODECR_EV_DATA_FMT_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
198
199
200
/*----------------------TMS570_ADC_EVSRC----------------------*/
201
/* field: EV_EDG_BOTH - rising and falling edge detected on the selected trigger source. */
202
#define TMS570_ADC_EVSRC_EV_EDG_BOTH BSP_BIT32(4)
203
204
/* field: EV_EDG_SEL - Event Group Trigger Edge Polarity Select. */
205
#define TMS570_ADC_EVSRC_EV_EDG_SEL BSP_BIT32(3)
206
207
/* field: EV_SRC - Event Group Trigger Source. */
208
#define TMS570_ADC_EVSRC_EV_SRC(val) BSP_FLD32(val,0, 2)
209
#define TMS570_ADC_EVSRC_EV_SRC_GET(reg) BSP_FLD32GET(reg,0, 2)
210
#define TMS570_ADC_EVSRC_EV_SRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
211
212
213
/*----------------------TMS570_ADC_G1SRC----------------------*/
214
/* field: GI_EDG_BOTH - Group1 Trigger Edge Polarity Select. */
215
#define TMS570_ADC_G1SRC_GI_EDG_BOTH BSP_BIT32(4)
216
217
/* field: G1_EDG_SEL - Group1 Trigger Edge Polarity Select. */
218
#define TMS570_ADC_G1SRC_G1_EDG_SEL BSP_BIT32(3)
219
220
/* field: G1_SRC - Group1 Trigger Source. */
221
#define TMS570_ADC_G1SRC_G1_SRC(val) BSP_FLD32(val,0, 2)
222
#define TMS570_ADC_G1SRC_G1_SRC_GET(reg) BSP_FLD32GET(reg,0, 2)
223
#define TMS570_ADC_G1SRC_G1_SRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
224
225
226
/*----------------------TMS570_ADC_G2SRC----------------------*/
227
/* field: G2_EDG_BOTH - Group2 Trigger Edge Polarity Select. */
228
#define TMS570_ADC_G2SRC_G2_EDG_BOTH BSP_BIT32(4)
229
230
/* field: G2_EDG_SEL - Group2 Trigger Edge Polarity Select. */
231
#define TMS570_ADC_G2SRC_G2_EDG_SEL BSP_BIT32(3)
232
233
/* field: G2_SRC - Group2 Trigger Source. */
234
#define TMS570_ADC_G2SRC_G2_SRC(val) BSP_FLD32(val,0, 2)
235
#define TMS570_ADC_G2SRC_G2_SRC_GET(reg) BSP_FLD32GET(reg,0, 2)
236
#define TMS570_ADC_G2SRC_G2_SRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
237
238
239
/*--------------------TMS570_ADC_GxINTENA--------------------*/
240
/* field: EV_END_INT_EN - Event Group Conversion End Interrupt Enable. Please refer to Section 19.5. */
241
#define TMS570_ADC_GxINTENA_EV_END_INT_EN BSP_BIT32(3)
242
243
/* field: EV_OVR_INT_EN - write a new conversion result to the Event Group results memory which is already full. */
244
#define TMS570_ADC_GxINTENA_EV_OVR_INT_EN BSP_BIT32(1)
245
246
/* field: EV_THR_INT_EN - Event Group Threshold Interrupt Enable. */
247
#define TMS570_ADC_GxINTENA_EV_THR_INT_EN BSP_BIT32(0)
248
249
250
/*--------------------TMS570_ADC_GxINTFLG--------------------*/
251
/* field: EV_END - Event Group Conversion End. */
252
#define TMS570_ADC_GxINTFLG_EV_END BSP_BIT32(3)
253
254
/* field: EV_MEM_EMPTY - Event Group Results Memory Empty. This is a read-only bit; writes have no effect. It is not asource of an interrupt from the ADC module. */
255
#define TMS570_ADC_GxINTFLG_EV_MEM_EMPTY BSP_BIT32(2)
256
257
/* field: EV_MEM_OVERRUN - Event Group Memory Overrun. This is a read-only bit; writes have no effect. */
258
#define TMS570_ADC_GxINTFLG_EV_MEM_OVERRUN BSP_BIT32(1)
259
260
/* field: EV_THR_INT_FLG - Event Group Threshold Interrupt Flag. */
261
#define TMS570_ADC_GxINTFLG_EV_THR_INT_FLG BSP_BIT32(0)
262
263
264
/*---------------------TMS570_ADC_GxINTCR---------------------*/
265
/* field: Sign_Extension - These bits always read the same as the bit 8 of this register. */
266
#define TMS570_ADC_GxINTCR_Sign_Extension(val) BSP_FLD32(val,9, 15)
267
#define TMS570_ADC_GxINTCR_Sign_Extension_GET(reg) BSP_FLD32GET(reg,9, 15)
268
#define TMS570_ADC_GxINTCR_Sign_Extension_SET(reg,val) BSP_FLD32SET(reg, val,9, 15)
269
270
/* field: EV_THR - Event Group Threshold Counter. */
271
#define TMS570_ADC_GxINTCR_EV_THR(val) BSP_FLD32(val,0, 8)
272
#define TMS570_ADC_GxINTCR_EV_THR_GET(reg) BSP_FLD32GET(reg,0, 8)
273
#define TMS570_ADC_GxINTCR_EV_THR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
274
275
276
/*---------------------TMS570_ADC_EVDMACR---------------------*/
277
/* field: EV_BLOCKS - Number of Event Group Result buffers to be transferred using DMA if the ADC module is */
278
#define TMS570_ADC_EVDMACR_EV_BLOCKS(val) BSP_FLD32(val,16, 24)
279
#define TMS570_ADC_EVDMACR_EV_BLOCKS_GET(reg) BSP_FLD32GET(reg,16, 24)
280
#define TMS570_ADC_EVDMACR_EV_BLOCKS_SET(reg,val) BSP_FLD32SET(reg, val,16, 24)
281
282
/* field: DMA_EV_END - Event Group Conversion End DMA Transfer Enable. */
283
#define TMS570_ADC_EVDMACR_DMA_EV_END BSP_BIT32(3)
284
285
/* field: EV_BLK_XFER - Event Group Block DMA Transfer Enable. */
286
#define TMS570_ADC_EVDMACR_EV_BLK_XFER BSP_BIT32(2)
287
288
/* field: EV_DMA_EN - Event Group DMA Transfer Enable. */
289
#define TMS570_ADC_EVDMACR_EV_DMA_EN BSP_BIT32(0)
290
291
292
/*---------------------TMS570_ADC_G1DMACR---------------------*/
293
/* field: G1_BLOCKS - Number of Group1 Result buffers to be transferred using DMA if the ADC module is configured */
294
#define TMS570_ADC_G1DMACR_G1_BLOCKS(val) BSP_FLD32(val,16, 24)
295
#define TMS570_ADC_G1DMACR_G1_BLOCKS_GET(reg) BSP_FLD32GET(reg,16, 24)
296
#define TMS570_ADC_G1DMACR_G1_BLOCKS_SET(reg,val) BSP_FLD32SET(reg, val,16, 24)
297
298
/* field: DMA_G1_END - Group1 Conversion End DMA Transfer Enable. */
299
#define TMS570_ADC_G1DMACR_DMA_G1_END BSP_BIT32(3)
300
301
/* field: G1_BLK_XFER - Group1 Block DMA Transfer Enable. */
302
#define TMS570_ADC_G1DMACR_G1_BLK_XFER BSP_BIT32(2)
303
304
/* field: G1_DMA_EN - Group1 DMA Transfer Enable. */
305
#define TMS570_ADC_G1DMACR_G1_DMA_EN BSP_BIT32(0)
306
307
308
/*---------------------TMS570_ADC_G2DMACR---------------------*/
309
/* field: G2_BLOCKS - Number of Group2 Result buffers to be transferred using DMA if the ADC module is configured */
310
#define TMS570_ADC_G2DMACR_G2_BLOCKS(val) BSP_FLD32(val,16, 24)
311
#define TMS570_ADC_G2DMACR_G2_BLOCKS_GET(reg) BSP_FLD32GET(reg,16, 24)
312
#define TMS570_ADC_G2DMACR_G2_BLOCKS_SET(reg,val) BSP_FLD32SET(reg, val,16, 24)
313
314
/* field: DMA_G2_END - Group2 Conversion End DMA Transfer Enable. */
315
#define TMS570_ADC_G2DMACR_DMA_G2_END BSP_BIT32(3)
316
317
/* field: G2_BLK_XFER - Group2 Block DMA Transfer Enable. */
318
#define TMS570_ADC_G2DMACR_G2_BLK_XFER BSP_BIT32(2)
319
320
/* field: G2_DMA_EN - Group2 DMA Transfer Enable. */
321
#define TMS570_ADC_G2DMACR_G2_DMA_EN BSP_BIT32(0)
322
323
324
/*----------------------TMS570_ADC_BNDCR----------------------*/
325
/* field: BNDA - Buffer Boundary A. */
326
#define TMS570_ADC_BNDCR_BNDA(val) BSP_FLD32(val,16, 24)
327
#define TMS570_ADC_BNDCR_BNDA_GET(reg) BSP_FLD32GET(reg,16, 24)
328
#define TMS570_ADC_BNDCR_BNDA_SET(reg,val) BSP_FLD32SET(reg, val,16, 24)
329
330
/* field: BNDB - Buffer Boundary B. */
331
#define TMS570_ADC_BNDCR_BNDB(val) BSP_FLD32(val,0, 8)
332
#define TMS570_ADC_BNDCR_BNDB_GET(reg) BSP_FLD32GET(reg,0, 8)
333
#define TMS570_ADC_BNDCR_BNDB_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
334
335
336
/*---------------------TMS570_ADC_BNDEND---------------------*/
337
/* field: BUF_INIT_ACTIVE - ADC Results Memory Auto-initialization Status. */
338
#define TMS570_ADC_BNDEND_BUF_INIT_ACTIVE BSP_BIT32(16)
339
340
/* field: BNDEND - Buffer Boundary End. */
341
#define TMS570_ADC_BNDEND_BNDEND(val) BSP_FLD32(val,0, 2)
342
#define TMS570_ADC_BNDEND_BNDEND_GET(reg) BSP_FLD32GET(reg,0, 2)
343
#define TMS570_ADC_BNDEND_BNDEND_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
344
345
346
/*---------------------TMS570_ADC_EVSAMP---------------------*/
347
/* field: EV_ACQ - Event Group Acquisition Time. */
348
#define TMS570_ADC_EVSAMP_EV_ACQ(val) BSP_FLD32(val,0, 11)
349
#define TMS570_ADC_EVSAMP_EV_ACQ_GET(reg) BSP_FLD32GET(reg,0, 11)
350
#define TMS570_ADC_EVSAMP_EV_ACQ_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
351
352
353
/*---------------------TMS570_ADC_G1SAMP---------------------*/
354
/* field: G1_ACQ - Group1 Acquisition Time. These bits define the sampling window (SW) for the Group1 conversions. */
355
#define TMS570_ADC_G1SAMP_G1_ACQ(val) BSP_FLD32(val,0, 11)
356
#define TMS570_ADC_G1SAMP_G1_ACQ_GET(reg) BSP_FLD32GET(reg,0, 11)
357
#define TMS570_ADC_G1SAMP_G1_ACQ_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
358
359
360
/*---------------------TMS570_ADC_G2SAMP---------------------*/
361
/* field: G2_ACQ - Group2 Acquisition Time. These bits define the sampling window (SW) for the Group2 conversions. */
362
#define TMS570_ADC_G2SAMP_G2_ACQ(val) BSP_FLD32(val,0, 11)
363
#define TMS570_ADC_G2SAMP_G2_ACQ_GET(reg) BSP_FLD32GET(reg,0, 11)
364
#define TMS570_ADC_G2SAMP_G2_ACQ_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
365
366
367
/*----------------------TMS570_ADC_EVSR----------------------*/
368
/* field: EV_MEM_EMPTY - Event Group Results Memory Empty. */
369
#define TMS570_ADC_EVSR_EV_MEM_EMPTY BSP_BIT32(3)
370
371
/* field: EV_BUSY - Event Group Conversion Busy. */
372
#define TMS570_ADC_EVSR_EV_BUSY BSP_BIT32(2)
373
374
/* field: EV_STOP - Event Group Conversion Stopped. */
375
#define TMS570_ADC_EVSR_EV_STOP BSP_BIT32(1)
376
377
/* field: EV_END - Event Group Conversions Ended. */
378
#define TMS570_ADC_EVSR_EV_END BSP_BIT32(0)
379
380
381
/*----------------------TMS570_ADC_G1SR----------------------*/
382
/* field: G1_MEM_EMPTY - Group1 Results Memory Empty. */
383
#define TMS570_ADC_G1SR_G1_MEM_EMPTY BSP_BIT32(3)
384
385
/* field: G1_BUSY - Group1 Conversion Busy. */
386
#define TMS570_ADC_G1SR_G1_BUSY BSP_BIT32(2)
387
388
/* field: G1_STOP - Group1 Conversion Stopped. */
389
#define TMS570_ADC_G1SR_G1_STOP BSP_BIT32(1)
390
391
/* field: G1_END - Group1 Conversions Ended. */
392
#define TMS570_ADC_G1SR_G1_END BSP_BIT32(0)
393
394
395
/*----------------------TMS570_ADC_G2SR----------------------*/
396
/* field: G2_MEM_EMPTY - Group2 Results Memory Empty. */
397
#define TMS570_ADC_G2SR_G2_MEM_EMPTY BSP_BIT32(3)
398
399
/* field: G2_BUSY - Group2 Conversion Busy. */
400
#define TMS570_ADC_G2SR_G2_BUSY BSP_BIT32(2)
401
402
/* field: G2_STOP - Group2 Conversion Stopped. */
403
#define TMS570_ADC_G2SR_G2_STOP BSP_BIT32(1)
404
405
/* field: G2_END - Group2 Conversions Ended. */
406
#define TMS570_ADC_G2SR_G2_END BSP_BIT32(0)
407
408
409
/*----------------------TMS570_ADC_GxSEL----------------------*/
410
/* field: EV_SEL - Event Group channels selected. */
411
#define TMS570_ADC_GxSEL_EV_SEL(val) BSP_FLD32(val,0, 15)
412
#define TMS570_ADC_GxSEL_EV_SEL_GET(reg) BSP_FLD32GET(reg,0, 15)
413
#define TMS570_ADC_GxSEL_EV_SEL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
414
415
416
/*----------------------TMS570_ADC_CALR----------------------*/
417
/* field: ADCALR - ADC Calibration Result and Offset Error Correction Value. */
418
#define TMS570_ADC_CALR_ADCALR(val) BSP_FLD32(val,0, 11)
419
#define TMS570_ADC_CALR_ADCALR_GET(reg) BSP_FLD32GET(reg,0, 11)
420
#define TMS570_ADC_CALR_ADCALR_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
421
422
423
/*---------------------TMS570_ADC_SMSTATE---------------------*/
424
/* field: LAST_CONV - ADC Input Channel's Last Converted Value. */
425
#define TMS570_ADC_SMSTATE_LAST_CONV(val) BSP_FLD32(val,0, 23)
426
#define TMS570_ADC_SMSTATE_LAST_CONV_GET(reg) BSP_FLD32GET(reg,0, 23)
427
#define TMS570_ADC_SMSTATE_LAST_CONV_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
428
429
430
/*--------------------TMS570_ADC_LASTCONV--------------------*/
431
432
#define TMS570_ADC_LASTCONV_LAST_CONV(val) BSP_FLD32(val,0, 23)
433
#define TMS570_ADC_LASTCONV_LAST_CONV_GET(reg) BSP_FLD32GET(reg,0, 23)
434
#define TMS570_ADC_LASTCONV_LAST_CONV_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
435
436
437
/*----------------------TMS570_ADC_GxBUF----------------------*/
438
/* field: ADEVT_DIR - ADEVT Pin Direction. */
439
#define TMS570_ADC_GxBUF_ADEVT_DIR BSP_BIT32(0)
440
441
442
/*-------------------TMS570_ADC_EVEMUBUFFER-------------------*/
443
444
#define TMS570_ADC_EVEMUBUFFER_ADEVT_DIR BSP_BIT32(0)
445
446
447
/*-------------------TMS570_ADC_G1EMUBUFFER-------------------*/
448
449
#define TMS570_ADC_G1EMUBUFFER_ADEVT_DIR BSP_BIT32(0)
450
451
452
/*-------------------TMS570_ADC_G2EMUBUFFER-------------------*/
453
454
#define TMS570_ADC_G2EMUBUFFER_ADEVT_DIR BSP_BIT32(0)
455
456
457
/*---------------------TMS570_ADC_EVTDIR---------------------*/
458
459
#define TMS570_ADC_EVTDIR_ADEVT_DIR BSP_BIT32(0)
460
461
462
/*---------------------TMS570_ADC_EVTOUT---------------------*/
463
/* field: ADEVT_OUT - ADEVT Pin Output Value. */
464
#define TMS570_ADC_EVTOUT_ADEVT_OUT BSP_BIT32(0)
465
466
467
/*----------------------TMS570_ADC_EVTIN----------------------*/
468
/* field: ADEVT_IN - ADEVT Pin Input Value. This is a read-only bit which reflects the logic level on the ADEVT pin. */
469
#define TMS570_ADC_EVTIN_ADEVT_IN BSP_BIT32(0)
470
471
472
/*---------------------TMS570_ADC_EVTSET---------------------*/
473
/* field: ADEVT_SET - ADEVT Pin Set. This bit drives the output of the ADEVT pin high. */
474
#define TMS570_ADC_EVTSET_ADEVT_SET BSP_BIT32(0)
475
476
477
/*---------------------TMS570_ADC_EVTCLR---------------------*/
478
/* field: ADEVT_CLR - ADEVT Pin Clear. A read from this bit always returns the current state of the ADEVT pin. */
479
#define TMS570_ADC_EVTCLR_ADEVT_CLR BSP_BIT32(0)
480
481
482
/*---------------------TMS570_ADC_EVTPDR---------------------*/
483
/* field: ADEVT_PDR - ADEVT Pin Open Drain Enable. */
484
#define TMS570_ADC_EVTPDR_ADEVT_PDR BSP_BIT32(0)
485
486
487
/*---------------------TMS570_ADC_EVTPDIS---------------------*/
488
/* field: ADEVT_PDIS - ADEVT Pin Pull Control Disable. */
489
#define TMS570_ADC_EVTPDIS_ADEVT_PDIS BSP_BIT32(0)
490
491
492
/*---------------------TMS570_ADC_EVTPSEL---------------------*/
493
/* field: ADEVT_PSEL - ADEVT Pin Pull Control Select. */
494
#define TMS570_ADC_EVTPSEL_ADEVT_PSEL BSP_BIT32(0)
495
496
497
/*-------------------TMS570_ADC_EVSAMPDISEN-------------------*/
498
/* field: EV_SAMP_DIS_CYC - Event Group sample cap discharge cycles. */
499
#define TMS570_ADC_EVSAMPDISEN_EV_SAMP_DIS_CYC(val) BSP_FLD32(val,8, 15)
500
#define TMS570_ADC_EVSAMPDISEN_EV_SAMP_DIS_CYC_GET(reg) BSP_FLD32GET(reg,8, 15)
501
#define TMS570_ADC_EVSAMPDISEN_EV_SAMP_DIS_CYC_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
502
503
/* field: EV_SAMP_DIS_EN - Event Group sample cap discharge enable. */
504
#define TMS570_ADC_EVSAMPDISEN_EV_SAMP_DIS_EN BSP_BIT32(0)
505
506
507
/*-------------------TMS570_ADC_G1SAMPDISEN-------------------*/
508
/* field: G1_SAMP_DIS_CYC - Group1 sample cap discharge cycles. */
509
#define TMS570_ADC_G1SAMPDISEN_G1_SAMP_DIS_CYC(val) BSP_FLD32(val,8, 15)
510
#define TMS570_ADC_G1SAMPDISEN_G1_SAMP_DIS_CYC_GET(reg) BSP_FLD32GET(reg,8, 15)
511
#define TMS570_ADC_G1SAMPDISEN_G1_SAMP_DIS_CYC_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
512
513
/* field: G1_SAMP_DIS_EN - Group1 sample cap discharge enable. */
514
#define TMS570_ADC_G1SAMPDISEN_G1_SAMP_DIS_EN BSP_BIT32(0)
515
516
517
/*-------------------TMS570_ADC_G2SAMPDISEN-------------------*/
518
/* field: G2_SAMP_DIS_CYC - for which the ADC internal sampling capacitor is allowed to discharge before sampling the input */
519
#define TMS570_ADC_G2SAMPDISEN_G2_SAMP_DIS_CYC(val) BSP_FLD32(val,8, 15)
520
#define TMS570_ADC_G2SAMPDISEN_G2_SAMP_DIS_CYC_GET(reg) BSP_FLD32GET(reg,8, 15)
521
#define TMS570_ADC_G2SAMPDISEN_G2_SAMP_DIS_CYC_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
522
523
/* field: G2_SAMP_DIS_EN - Group2 sample cap discharge enable. */
524
#define TMS570_ADC_G2SAMPDISEN_G2_SAMP_DIS_EN BSP_BIT32(0)
525
526
527
/*--------------------TMS570_ADC_MAGINTCRx--------------------*/
528
/* field: MAG_CHID2 - These bits specify the channel number from 0 to 31 for which the conversion result needs to be */
529
#define TMS570_ADC_MAGINTCRx_MAG_CHID2(val) BSP_FLD32(val,26, 30)
530
#define TMS570_ADC_MAGINTCRx_MAG_CHID2_GET(reg) BSP_FLD32GET(reg,26, 30)
531
#define TMS570_ADC_MAGINTCRx_MAG_CHID2_SET(reg,val) BSP_FLD32SET(reg, val,26, 30)
532
533
/* field: MAG_THR2 - These bits specify the 10-bit compare value which the ADC will use for the comparison with the */
534
#define TMS570_ADC_MAGINTCRx_MAG_THR2(val) BSP_FLD32(val,16, 25)
535
#define TMS570_ADC_MAGINTCRx_MAG_THR2_GET(reg) BSP_FLD32GET(reg,16, 25)
536
#define TMS570_ADC_MAGINTCRx_MAG_THR2_SET(reg,val) BSP_FLD32SET(reg, val,16, 25)
537
538
/* field: COMP_CHID2 - These bits specify the channel number from 0 to 31 whose last conversion result is compared */
539
#define TMS570_ADC_MAGINTCRx_COMP_CHID2(val) BSP_FLD32(val,8, 12)
540
#define TMS570_ADC_MAGINTCRx_COMP_CHID2_GET(reg) BSP_FLD32GET(reg,8, 12)
541
#define TMS570_ADC_MAGINTCRx_COMP_CHID2_SET(reg,val) BSP_FLD32SET(reg, val,8, 12)
542
543
/* field: CHN_THR_COMP2 - Channel OR Threshold comparison. */
544
#define TMS570_ADC_MAGINTCRx_CHN_THR_COMP2 BSP_BIT32(1)
545
546
/* field: CMP_GE_LT2 - Greater than or equal to OR Less than comparison operator. */
547
#define TMS570_ADC_MAGINTCRx_CMP_GE_LT2 BSP_BIT32(0)
548
549
550
/*-------------------TMS570_ADC_MAGINTxMASK-------------------*/
551
/* field: MAG_INT0_MASK - These bits specify the mask for the comparison in order to generate the magnitude compare */
552
#define TMS570_ADC_MAGINTxMASK_MAG_INT0_MASK(val) BSP_FLD32(val,0, 9)
553
#define TMS570_ADC_MAGINTxMASK_MAG_INT0_MASK_GET(reg) BSP_FLD32GET(reg,0, 9)
554
#define TMS570_ADC_MAGINTxMASK_MAG_INT0_MASK_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
555
556
557
/*-----------------TMS570_ADC_MAGTHRINTENASET-----------------*/
558
/* field: MAG_INT_ENA_SET - Each of these three bits, when set, enable the corresponding magnitude compare interrupt. */
559
#define TMS570_ADC_MAGTHRINTENASET_MAG_INT_ENA_SET(val) BSP_FLD32(val,0, 2)
560
#define TMS570_ADC_MAGTHRINTENASET_MAG_INT_ENA_SET_GET(reg) BSP_FLD32GET(reg,0, 2)
561
#define TMS570_ADC_MAGTHRINTENASET_MAG_INT_ENA_SET_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
562
563
564
/*-----------------TMS570_ADC_MAGTHRINTENACLR-----------------*/
565
/* field: MAG_INT_ENA_CLR - Each of these three bits, when set, enable the corresponding magnitude compare interrupt. */
566
#define TMS570_ADC_MAGTHRINTENACLR_MAG_INT_ENA_CLR(val) BSP_FLD32(val,0, 2)
567
#define TMS570_ADC_MAGTHRINTENACLR_MAG_INT_ENA_CLR_GET(reg) BSP_FLD32GET(reg,0, 2)
568
#define TMS570_ADC_MAGTHRINTENACLR_MAG_INT_ENA_CLR_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
569
570
571
/*------------------TMS570_ADC_MAGTHRINTFLG------------------*/
572
/* field: MAG_INT_FLG - Magnitude Compare Interrupt Flags. */
573
#define TMS570_ADC_MAGTHRINTFLG_MAG_INT_FLG(val) BSP_FLD32(val,0, 2)
574
#define TMS570_ADC_MAGTHRINTFLG_MAG_INT_FLG_GET(reg) BSP_FLD32GET(reg,0, 2)
575
#define TMS570_ADC_MAGTHRINTFLG_MAG_INT_FLG_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
576
577
578
/*-----------------TMS570_ADC_MAGTHRINTOFFSET-----------------*/
579
/* field: MAG_INT_OFF - Magnitude Compare Interrupt Offset. */
580
#define TMS570_ADC_MAGTHRINTOFFSET_MAG_INT_OFF(val) BSP_FLD32(val,0, 3)
581
#define TMS570_ADC_MAGTHRINTOFFSET_MAG_INT_OFF_GET(reg) BSP_FLD32GET(reg,0, 3)
582
#define TMS570_ADC_MAGTHRINTOFFSET_MAG_INT_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
583
584
585
/*------------------TMS570_ADC_GxFIFORESETCR------------------*/
586
/* field: EV_FIFO_RESET - allows the ADC module to overwrite the contents of the Event Group results memory starting from */
587
#define TMS570_ADC_GxFIFORESETCR_EV_FIFO_RESET BSP_BIT32(0)
588
589
590
/*-------------------TMS570_ADC_EVRAMWRADDR-------------------*/
591
/* field: G1_RAM_ADDR - Group1 results memory write pointer. */
592
#define TMS570_ADC_EVRAMWRADDR_G1_RAM_ADDR(val) BSP_FLD32(val,0, 8)
593
#define TMS570_ADC_EVRAMWRADDR_G1_RAM_ADDR_GET(reg) BSP_FLD32GET(reg,0, 8)
594
#define TMS570_ADC_EVRAMWRADDR_G1_RAM_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
595
596
597
/*-------------------TMS570_ADC_G1RAMWRADDR-------------------*/
598
599
#define TMS570_ADC_G1RAMWRADDR_G1_RAM_ADDR(val) BSP_FLD32(val,0, 8)
600
#define TMS570_ADC_G1RAMWRADDR_G1_RAM_ADDR_GET(reg) BSP_FLD32GET(reg,0, 8)
601
#define TMS570_ADC_G1RAMWRADDR_G1_RAM_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
602
603
604
/*-------------------TMS570_ADC_G2RAMWRADDR-------------------*/
605
/* field: G2_RAM_ADDR - Group2 results memory write pointer. */
606
#define TMS570_ADC_G2RAMWRADDR_G2_RAM_ADDR(val) BSP_FLD32(val,0, 8)
607
#define TMS570_ADC_G2RAMWRADDR_G2_RAM_ADDR_GET(reg) BSP_FLD32GET(reg,0, 8)
608
#define TMS570_ADC_G2RAMWRADDR_G2_RAM_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
609
610
611
/*----------------------TMS570_ADC_PARCR----------------------*/
612
/* field: TEST - This bit maps the parity bits into the ADC results' RAM frame so that the application can access */
613
#define TMS570_ADC_PARCR_TEST BSP_BIT32(8)
614
615
/* field: PARITY_ENA - PARITY ENA */
616
#define TMS570_ADC_PARCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
617
#define TMS570_ADC_PARCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
618
#define TMS570_ADC_PARCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
619
620
621
/*---------------------TMS570_ADC_PARADDR---------------------*/
622
/* field: ERROR_ADDRESS - These bits hold the address of the first parity error generated in the ADC results' RAM. */
623
#define TMS570_ADC_PARADDR_ERROR_ADDRESS(val) BSP_FLD32(val,2, 11)
624
#define TMS570_ADC_PARADDR_ERROR_ADDRESS_GET(reg) BSP_FLD32GET(reg,2, 11)
625
#define TMS570_ADC_PARADDR_ERROR_ADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,2, 11)
626
627
628
/*------------------TMS570_ADC_PWRUPDLYCTRL------------------*/
629
/* field: PWRUP_DLY - This register defines the number of VCLK cycles that the ADC state machine has to wait after */
630
#define TMS570_ADC_PWRUPDLYCTRL_PWRUP_DLY(val) BSP_FLD32(val,0, 9)
631
#define TMS570_ADC_PWRUPDLYCTRL_PWRUP_DLY_GET(reg) BSP_FLD32GET(reg,0, 9)
632
#define TMS570_ADC_PWRUPDLYCTRL_PWRUP_DLY_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
633
634
635
636
#endif
/* LIBBSP_ARM_TMS570_ADC */
utility.h
This header file provides utility macros for BSPs.
tms570_adc_t
Definition
reg_adc.h:65
tms570_gxbuf_t
Definition
reg_adc.h:54
