RTEMS
6.3
Toggle main menu visibility
score
cpu
m68k
include
m68k
qsm.h
1
19
20
21
* This file was created by John S. Gwynne to support Motorola's 68332 MCU.
22
23
* Redistribution and use in source and binary forms are permitted
24
* provided that the following conditions are met:
25
* 1. Redistribution of source code and documentation must retain
26
* the above authorship, this list of conditions and the
27
* following disclaimer.
28
* 2. The name of the author may not be used to endorse or promote
29
* products derived from this software without specific prior
30
* written permission.
31
32
* This software is provided "AS IS" without warranty of any kind,
33
* either expressed or implied, including, but not limited to, the
34
* implied warranties of merchantability, title and fitness for a
35
* particular purpose.
36
37
38
39
40
#ifndef _RTEMS_M68K_QSM_H
41
#define _RTEMS_M68K_QSM_H
42
43
/* SAM-- shift and mask */
44
#undef SAM
45
#define SAM(a,b,c) ((a << b) & c)
46
47
48
/* QSM_CRB (QSM Control Register Block) base address of the QSM
49
control registers */
50
#if SIM_MM == 0
51
#define QSM_CRB 0x7ffc00
52
#else
53
#undef SIM_MM
54
#define SIM_MM 1
55
#define QSM_CRB 0xfffc00
56
#endif
57
58
59
#define QSMCR (volatile unsigned short int * const)(0x00 + QSM_CRB)
60
/* QSM Configuration Register */
61
#define STOP 0x8000
/* Stop Enable */
62
#define FRZ 0x6000
/* Freeze Control */
63
#define SUPV 0x0080
/* Supervisor/Unrestricted */
64
#define IARB 0x000f
/* Inerrupt Arbitration */
65
66
67
#define QTEST (volatile unsigned short int * const)(0x02 + QSM_CRB)
68
/* QSM Test Register */
69
/* Used only for factor testing */
70
71
72
#define QILR (volatile unsigned char * const)(0x04 + QSM_CRB)
73
/* QSM Interrupt Level Register */
74
#define ILQSPI 0x38
/* Interrupt Level for QSPI */
75
#define ILSCI 0x07
/* Interrupt Level for SCI */
76
77
78
#define QIVR (volatile unsigned char * const)(0x05 + QSM_CRB)
79
/* QSM Interrupt Vector Register */
80
#define INTV 0xff
/* Interrupt Vector Number */
81
82
83
#define SCCR0 (volatile unsigned short int * const)(0x08 + QSM_CRB)
84
/* SCI Control Register 0 */
85
#define SCBR 0x1fff
/* SCI Baud Rate */
86
87
88
#define SCCR1 (volatile unsigned short int * const)(0x0a + QSM_CRB)
89
/* SCI Control Register 1 */
90
#define LOOPS 0x4000
/* Loop Mode */
91
#define WOMS 0x2000
/* Wired-OR Mode for SCI Pins */
92
#define ILT 0x1000
/* Idle-Line Detect Type */
93
#define PT 0x0800
/* Parity Type */
94
#define PE 0x0400
/* Parity Enable */
95
#define M 0x0200
/* Mode Select */
96
#define WAKE 0x0100
/* Wakeup by Address Mark */
97
#define TIE 0x0080
/* Transmit Complete Interrupt Enable */
98
#define TCIE 0x0040
99
#define RIE 0x0020
/* Receiver Interrupt Enable */
100
#define ILIE 0x0010
/* Idle-Line Interrupt Enable */
101
#define TE 0x0008
/* Transmitter Enable */
102
#define RE 0x0004
/* Receiver Enable */
103
#define RWU 0x0002
/* Receiver Wakeup */
104
#define SBK 0x0001
/* Send Break */
105
106
107
#define SCSR (volatile unsigned short int * const)(0x0c + QSM_CRB)
108
/* SCI Status Register */
109
#define TDRE 0x0100
/* Transmit Data Register Empty */
110
#define TC 0x0080
/* Transmit Complete */
111
#define RDRF 0x0040
/* Receive Data Register Full */
112
#define RAF 0x0020
/* Receiver Active */
113
#define IDLE 0x0010
/* Idle-Line Detected */
114
#define OR 0x0008
/* Overrun Error */
115
#define NF 0x0004
/* Noise Error Flag */
116
#define FE 0x0002
/* Framing Error */
117
#define PF 0x0001
/* Parity Error */
118
119
120
#define SCDR (volatile unsigned short int * const)(0x0e + QSM_CRB)
121
/* SCI Data Register */
122
123
124
#define PORTQS (volatile unsigned char * const)(0x15 + QSM_CRB)
125
/* Port QS Data Register */
126
127
#define PQSPAR (volatile unsigned char * const)(0x16 + QSM_CRB)
128
/* PORT QS Pin Assignment Rgister */
129
/* Any bit cleared (zero) defines the corresponding pin to be an I/O
130
pin. Any bit set defines the corresponding pin to be a QSPI
131
signal. */
132
/* note: PQS2 is a digital I/O pin unless the SPI is enabled in which
133
case it becomes the SPI serial clock SCK. */
134
/* note: PQS7 is a digital I/O pin unless the SCI transmitter is
135
enabled in which case it becomes the SCI serial output TxD. */
136
#define QSMFun 0x0
137
#define QSMDis 0x1
138
139
* PQSPAR Field | QSM Function | Discrete I/O pin
140
141
#define PQSPA0 0
/* MISO | PQS0 */
142
#define PQSPA1 1
/* MOSI | PQS1 */
143
#define PQSPA2 2
/* SCK | PQS2 (see note)*/
144
#define PQSPA3 3
/* PCSO/!SS | PQS3 */
145
#define PQSPA4 4
/* PCS1 | PQS4 */
146
#define PQSPA5 5
/* PCS2 | PQS5 */
147
#define PQSPA6 6
/* PCS3 | PQS6 */
148
#define PQSPA7 7
/* TxD | PQS7 (see note)*/
149
150
151
#define DDRQS (volatile unsigned char * const)(0x17 + QSM_CRB)
152
/* PORT QS Data Direction Register */
153
/* Clearing a bit makes the corresponding pin an input; setting a bit
154
makes the pin an output. */
155
156
157
#define SPCR0 (volatile unsigned short int * const)(0x18 + QSM_CRB)
158
/* QSPI Control Register 0 */
159
#define MSTR 0x8000
/* Master/Slave Mode Select */
160
#define WOMQ 0x4000
/* Wired-OR Mode for QSPI Pins */
161
#define BITS 0x3c00
/* Bits Per Transfer */
162
#define CPOL 0x0200
/* Clock Polarity */
163
#define CPHA 0x0100
/* Clock Phase */
164
#define SPBR 0x00ff
/* Serial Clock Baud Rate */
165
166
167
#define SPCR1 (volatile unsigned short int * const)(0x1a + QSM_CRB)
168
/* QSPI Control Register 1 */
169
#define SPE 0x8000
/* QSPI Enable */
170
#define DSCKL 0x7f00
/* Delay before SCK */
171
#define DTL 0x00ff
/* Length of Delay after Transfer */
172
173
174
#define SPCR2 (volatile unsigned short int * const)(0x1c + QSM_CRB)
175
/* QSPI Control Register 2 */
176
#define SPIFIE 0x8000
/* SPI Finished Interrupt Enable */
177
#define WREN 0x4000
/* Wrap Enable */
178
#define WRTO 0x2000
/* Wrap To */
179
#define ENDQP 0x0f00
/* Ending Queue Pointer */
180
#define NEWQP 0x000f
/* New Queue Pointer Value */
181
182
183
#define SPCR3 (volatile unsigned char * const)(0x1e + QSM_CRB)
184
/* QSPI Control Register 3 */
185
#define LOOPQ 0x0400
/* QSPI Loop Mode */
186
#define HMIE 0x0200
/* HALTA and MODF Interrupt Enable */
187
#define HALT 0x0100
/* Halt */
188
189
190
#define SPSR (volatile unsigned char * const)(0x1f + QSM_CRB)
191
/* QSPI Status Register */
192
#define SPIF 0x0080
/* QSPI Finished Flag */
193
#define MODF 0x0040
/* Mode Fault Flag */
194
#define HALTA 0x0020
/* Halt Acknowlwdge Flag */
195
#define CPTQP x0000f
/* Completed Queue Pointer */
196
197
#define QSPIRR (volatile unsigned char * const)(0x100 + QSM_CRB)
198
/* QSPI Receive Data RAM */
199
#define QSPITR (volatile unsigned char * const)(0x120 + QSM_CRB)
200
/* QSPI Transmit Data RAM */
201
#define QSPIcR (volatile unsigned char * const)(0x140 + QSM_CRB)
202
/* QSPI Command RAM */
203
204
#endif
/* _RTEMS_M68K_QSM_H */
