RTEMS 6.3
qsm.h File Reference
Motorola M68K Queued Serial Module. More...
#define SAM(a, b, c)
#define QSM_CRB   0x7ffc00
#define QSMCR   (volatile unsigned short int * const)(0x00 + QSM_CRB)
#define STOP   0x8000
#define FRZ   0x6000
#define SUPV   0x0080
#define IARB   0x000f
#define QTEST   (volatile unsigned short int * const)(0x02 + QSM_CRB)
#define QILR   (volatile unsigned char * const)(0x04 + QSM_CRB)
#define ILQSPI   0x38
#define ILSCI   0x07
#define QIVR   (volatile unsigned char * const)(0x05 + QSM_CRB)
#define INTV   0xff
#define SCCR0   (volatile unsigned short int * const)(0x08 + QSM_CRB)
#define SCBR   0x1fff
#define SCCR1   (volatile unsigned short int * const)(0x0a + QSM_CRB)
#define LOOPS   0x4000
#define WOMS   0x2000
#define ILT   0x1000
#define PT   0x0800
#define PE   0x0400
#define M   0x0200
#define WAKE   0x0100
#define TIE   0x0080
#define TCIE   0x0040
#define RIE   0x0020
#define ILIE   0x0010
#define TE   0x0008
#define RE   0x0004
#define RWU   0x0002
#define SBK   0x0001
#define SCSR   (volatile unsigned short int * const)(0x0c + QSM_CRB)
#define TDRE   0x0100
#define TC   0x0080
#define RDRF   0x0040
#define RAF   0x0020
#define IDLE   0x0010
#define OR   0x0008
#define NF   0x0004
#define FE   0x0002
#define PF   0x0001
#define SCDR   (volatile unsigned short int * const)(0x0e + QSM_CRB)
#define PORTQS   (volatile unsigned char * const)(0x15 + QSM_CRB)
#define PQSPAR   (volatile unsigned char * const)(0x16 + QSM_CRB)
#define QSMFun   0x0
#define QSMDis   0x1
#define PQSPA0   0
#define PQSPA1   1
#define PQSPA2   2
#define PQSPA3   3
#define PQSPA4   4
#define PQSPA5   5
#define PQSPA6   6
#define PQSPA7   7
#define DDRQS   (volatile unsigned char * const)(0x17 + QSM_CRB)
#define SPCR0   (volatile unsigned short int * const)(0x18 + QSM_CRB)
#define MSTR   0x8000
#define WOMQ   0x4000
#define BITS   0x3c00
#define CPOL   0x0200
#define CPHA   0x0100
#define SPBR   0x00ff
#define SPCR1   (volatile unsigned short int * const)(0x1a + QSM_CRB)
#define SPE   0x8000
#define DSCKL   0x7f00
#define DTL   0x00ff
#define SPCR2   (volatile unsigned short int * const)(0x1c + QSM_CRB)
#define SPIFIE   0x8000
#define WREN   0x4000
#define WRTO   0x2000
#define ENDQP   0x0f00
#define NEWQP   0x000f
#define SPCR3   (volatile unsigned char * const)(0x1e + QSM_CRB)
#define LOOPQ   0x0400
#define HMIE   0x0200
#define HALT   0x0100
#define SPSR   (volatile unsigned char * const)(0x1f + QSM_CRB)
#define SPIF   0x0080
#define MODF   0x0040
#define HALTA   0x0020
#define CPTQP   x0000f
#define QSPIRR   (volatile unsigned char * const)(0x100 + QSM_CRB)
#define QSPITR   (volatile unsigned char * const)(0x120 + QSM_CRB)
#define QSPIcR   (volatile unsigned char * const)(0x140 + QSM_CRB)
The QSM contains two serial interfaces: (a) the queued serial peripheral interface (QSPI) and the serial communication interface (SCI). The QSPI provides peripheral expansion and/or interprocessor communication through a full-duplex, synchronous, three-wire bus. A self contained RAM queue permits serial data transfers without CPU intervention and automatic continuous sampling. The SCI provides a standard non-return to zero mark/space format with wakeup functions to allow the CPU to run uninterrupted until woken
For more information, refer to Motorola's "Modular Microcontroller Family Queued Serial Module Reference Manual" (Motorola document QSMRM/AD).
◆ SAM
#define SAM ( a,
b,
c )
Value:
((a << b) & c)
