RTEMS 6.3
bspstart.c File Reference
BSP startup. More...
#include <libfdt.h>
#include <rtems/config.h>
#include <rtems/counter.h>
#include <rtems/sysinit.h>
#include <libcpu/powerpc-utility.h>
#include <bsp.h>
#include <bsp/bootcard.h>
#include <bsp/fatal.h>
#include <bsp/fdt.h>
#include <bsp/intercom.h>
#include <bsp/irq-generic.h>
#include <bsp/linker-symbols.h>
#include <bsp/mmu.h>
#include <bsp/qoriq.h>
#include <bsp/vectors.h>
#define VECTOR_TABLE_ENTRY_SIZE   16
#define MTIVOR(vec, offset)
 LINKER_SYMBOL (bsp_exc_vector_base)
uint32_t _CPU_Counter_frequency (void)
void qoriq_initialize_exceptions (void *interrupt_stack_begin)
void bsp_start (void)
uint32_t bsp_fdt_map_intr (const uint32_t *intr, size_t icells)
 Maps the interrupt number of the FDT to the interrupt vector used by the interrupt management.
qoriq_start_spin_table * qoriq_start_spin_table_addr [QORIQ_CPU_COUNT/QORIQ_THREAD_COUNT]
unsigned int BSP_bus_frequency
uint32_t bsp_time_base_frequency
uint32_t qoriq_clock_frequency
BSP startup.
◆ MTIVOR
#define MTIVOR ( vec,
offset )
Value:
do { \
__asm__ volatile ("mtspr " RTEMS_XSTRING(vec) ", %0" : : "r" (offset)); \
offset += VECTOR_TABLE_ENTRY_SIZE; \
} while (0)
#define RTEMS_XSTRING(...)
Stringifies the expansion of the arguments.
Definition basedefs.h:987
◆ bsp_fdt_map_intr()
uint32_t bsp_fdt_map_intr ( const uint32_t * intr,
size_t icells )
This function is used by the libbsd to implement the OFW_BUS_MAP_INTR bus method.
Parameters
[in]intrThe FDT interrupt number cells.
[in]icellsThe FDT interrupt cell count.
Returns
The interrupt vector of the FDT interrupt number.
