RTEMS
6.3
Toggle main menu visibility
bsps
include
bsp
bootcard.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
8
9
10
* Copyright (C) 2008, 2014 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef LIBBSP_SHARED_BOOTCARD_H
35
#define LIBBSP_SHARED_BOOTCARD_H
36
37
#include <rtems/config.h>
38
rtems/bspIo.h
39
rtems/malloc.h
40
rtems/score/memory.h
41
42
#include <bspopts.h>
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
/* __cplusplus */
47
57
61
extern
const
char
bsp_boot_cmdline
62
63
void
bsp_start(
void
64
65
RTEMS_NO_RETURN
void
bsp_reset(
rtems_fatal_source
source,
rtems_fatal_code
code
66
83
RTEMS_NO_RETURN
void
boot_card
const
char
*cmdline);
84
85
struct
Per_CPU_Control
86
95
void
bsp_start_on_secondary_processor
struct
Per_CPU_Control
*cpu_self);
96
98
99
#ifdef __cplusplus
100
101
#endif
/* __cplusplus */
102
103
#endif
/* LIBBSP_SHARED_BOOTCARD_H */
bspIo.h
This header file provides the kernel character input/output support API.
memory.h
This header file provides the interfaces of the Memory Handler.
RTEMS_NO_RETURN
#define RTEMS_NO_RETURN
Tells the compiler in a function declaration that this function does not return.
Definition
basedefs.h:386
rtems_fatal_code
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition
extension.h:162
rtems_fatal_source
Internal_errors_Source rtems_fatal_source
This enumeration represents system termination sources.
Definition
extension.h:175
bsp_boot_cmdline
const char * bsp_boot_cmdline
Global pointer to the command line of boot_card().
Definition
bootcard.c:44
void bsp_start_on_secondary_processor(struct Per_CPU_Control *cpu_self)
Standard start routine for secondary processors.
Definition
bspsmp.c:98
boot_card
RTEMS_NO_RETURN void boot_card(const char *cmdline)
Standard system initialization procedure.
Definition
bootcard.c:58
malloc.h
This header file defines interfaces to support and use dynamic memory allocation.
Per_CPU_Control
Per CPU Core Structure.
Definition
percpu.h:384
code
Definition
inftrees.h:24
