RTEMS 6.3
start.h
2
10
11/*
12 * Copyright (c) 2010 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_POWERPC_SHARED_START_H
37#define LIBBSP_POWERPC_SHARED_START_H
38
39#include <stddef.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
54
55#define BSP_START_TEXT_SECTION __attribute__((section(".bsp_start_text")))
56
57#define BSP_START_DATA_SECTION __attribute__((section(".bsp_start_data")))
58
62void _start(void);
63
74void BSP_START_TEXT_SECTION bsp_start_zero(void *begin, size_t byte_count);
75
79extern char bsp_start_zero_begin [];
80
84extern char bsp_start_zero_end [];
85
89extern char bsp_start_zero_size [];
90
92
93#ifdef __cplusplus
94}
95#endif /* __cplusplus */
96
97#endif /* LIBBSP_POWERPC_SHARED_START_H */
char bsp_start_zero_size[]
Symbol which equals the bsp_start_zero() code size.
char bsp_start_zero_end[]
Symbol which equals the bsp_start_zero() code end.
char bsp_start_zero_begin[]
Symbol which equals the bsp_start_zero() code begin.
void _start(void)
System start entry.
