RTEMS 6.3
Aarch64 system low level start. More...
Files | |
| file | bsps/aarch64/include/bsp/aarch64-mmu.h |
| AArch64 MMU configuration. | |
| file | bsps/aarch64/include/bsp/start.h |
| Aarch64 system low level start. | |
| file | bsps/aarch64/shared/mmu/mmu-setup.c |
| #define | BSP_START_TEXT_SECTION __attribute__((section(".bsp_start_text"))) |
| #define | BSP_START_DATA_SECTION __attribute__((section(".bsp_start_data"))) |
| void | _start (void) |
| System start entry. | |
| void | bsp_start_hook_0 (void) |
| Start entry hook 0. | |
| void | bsp_start_hook_1 (void) |
| Start entry hook 1. | |
| void bsp_start_hook_0 | ( | void | ) |
Start entry hook 0.
This hook will be called from the start entry code after all modes and stack pointers are initialized but before the copying of the exception vectors.
| void bsp_start_hook_1 | ( | void | ) |
Start entry hook 1.
This hook will be called from the start entry code after copying of the exception vectors but before the call to boot_card().
