RTEMS 6.3
priorityimpl.h
2
11
12/*
13 * COPYRIGHT (c) 1989-2011.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_POSIX_PRIORITYIMPL_H
39#define _RTEMS_POSIX_PRIORITYIMPL_H
40
42#include <rtems/score/assert.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif
47
57
61#define POSIX_SCHEDULER_MINIMUM_PRIORITY (1)
62
71static inline int _POSIX_Priority_Get_maximum(
72 const Scheduler_Control *scheduler
73)
74{
75 _Assert( (int) scheduler->maximum_priority > 1 );
76 return (int) scheduler->maximum_priority - 1;
77}
78
103 const Scheduler_Control *scheduler,
104 int priority,
105 bool *valid
106);
107
118 const Scheduler_Control *scheduler,
119 Priority_Control priority
120);
121
123
124#ifdef __cplusplus
125}
126#endif
127
128#endif
This header file provides the interfaces of the Assert Handler.
Priority_Control _POSIX_Priority_To_core(const Scheduler_Control *scheduler, int priority, bool *valid)
Converts the POSIX API priority to the corresponding SuperCore priority and validates it.
Definition psxpriorityisvalid.c:43
int _POSIX_Priority_From_core(const Scheduler_Control *scheduler, Priority_Control priority)
Converts the SuperCore priority to the corresponding POSIX API priority.
Definition psxpriorityisvalid.c:61
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
Definition assert.h:96
uint64_t Priority_Control
The thread priority control.
Definition priority.h:91
This header file provides interfaces of the Scheduler Handler which are used by the implementation an...
Priority_Control maximum_priority
The maximum priority value of this scheduler.
Definition scheduler.h:354
