RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
mvme3100
include
bsp
VMEConfig.h
1
8
9
#ifndef RTEMS_BSP_VME_CONFIG_H
10
#define RTEMS_BSP_VME_CONFIG_H
11
12
13
* Authorship
14
15
* This software was created by
16
* Till Straumann <strauman@slac.stanford.edu>, 2002..2007,
17
* Stanford Linear Accelerator Center, Stanford University.
18
19
* Acknowledgement of sponsorship
20
21
* This software was produced by
22
* the Stanford Linear Accelerator Center, Stanford University,
23
* under Contract DE-AC03-76SFO0515 with the Department of Energy.
24
25
* Government disclaimer of liability
26
27
* Neither the United States nor the United States Department of Energy,
28
* nor any of their employees, makes any warranty, express or implied, or
29
* assumes any legal liability or responsibility for the accuracy,
30
* completeness, or usefulness of any data, apparatus, product, or process
31
* disclosed, or represents that its use would not infringe privately owned
32
* rights.
33
34
* Stanford disclaimer of liability
35
36
* Stanford University makes no representations or warranties, express or
37
* implied, nor assumes any liability for the use of this software.
38
39
* Stanford disclaimer of copyright
40
41
* Stanford University, owner of the copyright, hereby disclaims its
42
* copyright and all other rights in this software. Hence, anyone may
43
* freely use it for any purpose without restriction.
44
45
* Maintenance of notices
46
47
* In the interest of clarity regarding the origin and status of this
48
* SLAC software, this and all the preceding Stanford University notices
49
* are to remain affixed to any copy or derivative of this software made
50
* or distributed by the recipient and are to be affixed to any copy of
51
* software made or distributed by the recipient that contains a copy or
52
* derivative of this software.
53
54
* ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
55
56
57
58
* NOTE: the BSP (startup/bspstart.c) uses
59
* hardcoded window lengths that match this
60
* layout:
61
62
63
#define _VME_A32_WIN0_ON_PCI 0xc0000000
64
#define _VME_CSR_ON_PCI 0xce000000
65
#define _VME_A24_ON_PCI 0xcf000000
66
#define _VME_A16_ON_PCI 0xcfff0000
67
68
/* start of the A32 window on the VME bus
69
* TODO: this should perhaps be a run-time configuration option
70
71
#define _VME_A32_WIN0_ON_VME 0x20000000
72
73
/* if _VME_DRAM_OFFSET is defined, the BSP
74
* will map the board RAM onto the VME bus, starting
75
* at _VME_DRAM_OFFSET
76
77
#define _VME_DRAM_OFFSET 0xc0000000
78
79
/* If your BSP requires a non-standard way to configure
80
* the VME interrupt manager then define the symbol
81
82
* BSP_VME_INSTALL_IRQ_MGR
83
84
* to a proper instruction sequence that installs the
85
* universe interrupt manager. This requires knowledge
86
* of the wiring between the universe and the PIC (main
87
* interrupt controller), i.e., which IRQ 'pins' of the
88
* universe are wired to which 'lines'/inputs at the PIC.
89
* (consult vmeUniverse.h for more information).
90
91
* When installing the universe IRQ manager it is also
92
* possible to specify whether it should try to share
93
* PIC interrupts with other sources. This might not
94
* be supported by all BSPs (but the unverse driver
95
* recognizes that).
96
97
* If BSP_VME_INSTALL_IRQ_MGR is undefined then
98
* the default algorithm is used (vme_universe.c):
99
100
* This default setup uses only a single wire. It reads
101
* the PIC 'line' from PCI configuration space and assumes
102
* this to be wired to the first (LIRQ0) IRQ input at the
103
* universe. The default setup tries to use interrupt
104
* sharing.
105
106
107
extern
int
BSP_VMEInit(
void
108
extern
int
BSP_VMEIrqMgrInstall(
void
109
117
#define BSP_VME_INSTALL_IRQ_MGR(err) \
118
do { \
119
err = vmeTsi148InstallIrqMgrAlt(\
120
VMETSI148_IRQ_MGR_FLAG_SHARED,
/* use shared IRQs */
121
0, BSP_VME0_IRQ, \
122
1, BSP_VME1_IRQ, \
123
2, BSP_VME2_IRQ, \
124
3, BSP_VME3_IRQ, \
125
-1
/* terminate list */
126
127
} while (0)
128
129
/* This BSP uses the Tsi148 Driver */
130
#define _VME_DRIVER_TSI148
131
132
#endif
