RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
gen5200
mscan
mscan_int.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* RTEMS generic MPC5200 BSP
5
6
* This file has to be included by the m driver.
7
8
9
10
* Copyright (c) 2005 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef __MSCAN_INT_H__
35
#define __MSCAN_INT_H__
36
37
#ifdef __cplusplus
38
extern
"C"
39
#endif
40
41
bsp/mscan-base.h
42
43
#include <bsp/mscan.h>
44
45
#define MSCAN_RX_BUFF_NUM 4
46
#define MSCAN_TX_BUFF_NUM 3
47
48
#define MSCAN_NON_INITIALIZED_MODE 0
49
#define MSCAN_INITIALIZED_MODE 1
50
#define MSCAN_INIT_NORMAL_MODE 2
51
#define MSCAN_NORMAL_MODE 4
52
#define MSCAN_SLEEP_MODE 8
53
54
#define MSCAN_RX_BUFF_NOACTIVE (0 << 4)
55
#define MSCAN_RX_BUFF_EMPTY (1 << 6)
56
#define MSCAN_RX_BUFF_FULL (1 << 5)
57
#define MSCAN_RX_BUFF_OVERRUN ((MSCAN_RX_BUFF_EMPTY) | (MSCAN_RX_BUFF_FULL))
58
#define MSCAN_RX_BUFF_BUSY (1 << 4)
59
60
#define MSCAN_MBUFF_MASK 0x07
61
62
#define MSCAN_TX_BUFF0 (1 << 0)
63
#define MSCAN_TX_BUFF1 (1 << 1)
64
#define MSCAN_TX_BUFF2 (1 << 2)
65
66
#define MSCAN_IDE (1 << 0)
67
#define MSCAN_RTR (1 << 1)
68
#define MSCAN_READ_RXBUFF_0 (1 << 2)
69
#define MSCAN_READ_RXBUFF_1 (1 << 2)
70
#define MSCAN_READ_RXBUFF_2 (1 << 2)
71
#define MSCAN_READ_RXBUFF_3 (1 << 2)
72
73
#define MSCAN_STATE_OK 0
74
#define MSCAN_STATE_ERR 1
75
#define MSCAN_STATE_WRN 2
76
#define MSCAN_STATE_BUSOFF 3
77
78
#define TX_MBUF_SEL(buf_no) (1 << (buf_no))
79
#define TX_DATA_LEN(len) ((len) & 0x0F)
80
81
#define TX_MBUF_EMPTY(val) (1 << (val))
82
83
#define ID_RTR (1 << 4)
84
85
#define SET_IDR0(u16) ((uint8_t)((u16) >> 3))
86
#define SET_IDR1(u16) (MSCAN_MESS_ID_HAS_RTR(u16) ? ((uint8_t)(((u16) & 0x0007) << 5))|((uint8_t)(ID_RTR)) : ((uint8_t)(((u16) & 0x0007) << 5)))
87
88
#define SET_IDR2(u16) SET_IDR0(u16)
89
#define SET_IDR3(u16) SET_IDR1(u16)
90
91
#define SET_IDR4(u16) SET_IDR0(u16)
92
#define SET_IDR5(u16) SET_IDR1(u16)
93
94
#define SET_IDR6(u16) SET_IDR0(u16)
95
#define SET_IDR7(u16) SET_IDR1(u16)
96
97
#define GET_IDR0(u16) ((uint16_t) ((u16) << 3))
98
#define GET_IDR1(u16) ((((u16)&(ID_RTR))==(ID_RTR)) ? (uint16_t) ((((u16) >> 5)&0x0007)|MSCAN_MESS_ID_RTR) : (uint16_t)(((u16) >> 5)&0x0007))
99
100
#define GET_IDR2(u16) GET_IDR0(u16)
101
#define GET_IDR3(u16) GET_IDR1(u16)
102
103
#define GET_IDR4(u16) GET_IDR0(u16)
104
#define GET_IDR5(u16) GET_IDR1(u16)
105
106
#define GET_IDR6(u16) GET_IDR0(u16)
107
#define GET_IDR7(u16) GET_IDR1(u16)
108
109
#define SET_IDMR0(u16) ((uint8_t)((u16) >> 3))
110
#define SET_IDMR1(u16) (MSCAN_MESS_ID_HAS_RTR(u16) ? ((uint8_t) (((((u16) & 0x0007) << 5)|((uint8_t)(ID_RTR)))|0x0007)) : ((uint8_t)((((u16) & 0x0007) << 5))|0x0007))
111
112
#define SET_IDMR2(u16) SET_IDMR0(u16)
113
#define SET_IDMR3(u16) SET_IDMR1(u16)
114
115
#define SET_IDMR4(u16) SET_IDMR0(u16)
116
#define SET_IDMR5(u16) SET_IDMR1(u16)
117
118
#define SET_IDMR6(u16) SET_IDMR0(u16)
119
#define SET_IDMR7(u16) SET_IDMR1(u16)
120
121
#define GET_IDMR0(u16) ((uint16_t)((u16) << 3))
122
#define GET_IDMR1(u16) ((((u16)&(ID_RTR))==(ID_RTR)) ? (uint16_t) ((((u16) >> 5)&0x0007)|MSCAN_MESS_ID_RTR) : (uint16_t)(((u16) >> 5)&0x0007))
123
124
#define GET_IDMR2(u16) GET_IDMR0(u16)
125
#define GET_IDMR3(u16) GET_IDMR1(u16)
126
127
#define GET_IDMR4(u16) GET_IDMR0(u16)
128
#define GET_IDMR5(u16) GET_IDMR1(u16)
129
130
#define GET_IDMR6(u16) GET_IDMR0(u16)
131
#define GET_IDMR7(u16) GET_IDMR1(u16)
132
133
#define NO_OF_MSCAN_RX_BUFF 20
134
#define MSCAN_MESSAGE_SIZE(size) (((size)%CPU_ALIGNMENT) ? (((size) + CPU_ALIGNMENT)-((size) + CPU_ALIGNMENT)%CPU_ALIGNMENT) : (size))
135
136
#define TX_BUFFER_0 0
137
#define TX_BUFFER_1 1
138
#define TX_BUFFER_2 2
139
140
#define RX_BUFFER_0 0
141
#define RX_BUFFER_1 1
142
#define RX_BUFFER_2 2
143
#define RX_BUFFER_3 3
144
145
#define NO_OF_MSCAN_TX_BUFF 20
146
#define RING_BUFFER_EMPTY(rbuff) ((((rbuff)->head) == ((rbuff)->tail)) ? TRUE : FALSE)
147
#define RING_BUFFER_FULL(rbuff) ((((rbuff)->head) == ((rbuff)->tail)) ? TRUE : FALSE)
148
149
150
typedef
struct
_mscan_handle
151
152
uint8_t mscan_channel;
153
void (*toucan_callback)(int16_t);
154
} mscan_handle;
155
156
struct
ring_buf
157
158
struct
can_message
volatile
buf_ptr;
159
struct
can_message
volatile
head_ptr;
160
struct
can_message
volatile
tail_ptr;
161
162
163
struct
mpc5200_rx_cntrl
164
165
struct
can_message
can_rx_message[MSCAN_RX_BUFF_NUM];
166
167
168
struct
mscan_channel_info
169
170
mscan
*regs;
171
uint32_t int_rx_err;
172
rtems_id
rx_qid;
173
uint32_t rx_qname;
174
rtems_id
tx_rb_sid;
175
uint32_t tx_rb_sname;
176
uint8_t id_extended;
177
uint8_t mode;
178
uint8_t tx_buf_no;
179
struct
ring_buf
tx_ring_buf;
180
181
182
extern
void
CanInterrupt_A(int16_t);
183
extern
void
CanInterrupt_B(int16_t);
184
185
/*MSCAN driver internal functions */
186
void
mscan_hardware_initialize(
rtems_device_major_number
, uint32_t,
void
187
void
mpc5200_mscan_wait_sync(
mscan
188
void
mpc5200_mscan_perform_init_mode_settings(
mscan
189
void
mpc5200_mscan_perform_normal_mode_settings(
mscan
190
rtems_status_code
mpc5200_mscan_set_mode(
rtems_device_minor_number
, uint8_t);
191
rtems_status_code
mscan_channel_initialize(
192
193
#ifdef __cplusplus
194
195
#endif
196
197
#endif
/* __MSCAN_H__ */
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition
io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition
io.h:115
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition
types.h:94
mscan
struct mpc5200_mscan mscan
MSCAN registers.
Definition
mscan-base.h:255
mscan-base.h
MSCAN register definitions and support functions.
_mscan_handle
Definition
mscan_int.h:151
mpc5200_rx_cntrl
Definition
mscan_int.h:164
mscan_channel_info
Definition
mscan_int.h:169
ring_buf
Definition
mscan_int.h:157
can_message
A CAN message represented of both forms.
Definition
can.h:66
