RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
gen5200
i2c
mpc5200mbus.h
1
2
* RTEMS generic MPC5200 BSP
3
4
* MBUS module (I2C bus) definitions
5
6
* Adapted from: MCF5206e MBUS module (I2C bus) driver header file.
7
8
9
10
* Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
11
* Author: Victor V. Vengerov <vvv@oktet.ru>
12
* Copyright (c) 2005 embedded brains GmbH & Co. KG
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
#ifndef __MPC5200BSP_MPC5200MBUS_H__
20
#define __MPC5200BSP_MPC5200MBUS_H__
21
22
#include <bsp/mpc5200.h>
23
#include <bsp/i2c.h>
24
25
26
/* States of I2C machine */
27
typedef
enum
mpc5200mbus_i2c_state {
28
STATE_UNINITIALIZED,
29
STATE_IDLE,
30
STATE_ADDR_7,
31
STATE_ADDR_1_W,
32
STATE_ADDR_1_R,
33
STATE_SENDING,
34
STATE_RECEIVING
35
} mpc5200mbus_i2c_state;
36
37
typedef
struct
mpc5200_mbus
38
enum
mpc5200mbus_i2c_state state;
/* State of I2C machine */
39
i2c_message
*msg;
/* Pointer to the first message in transfer */
40
int
nmsg;
/* Number of messages in transfer */
41
i2c_message
*cmsg;
/* Current message */
42
int
byte;
/* Byte number in current message */
43
rtems_id
sema;
/* MBUS semaphore */
44
i2c_transfer_done done;
/* Transfer done function */
45
void
* done_arg_ptr;
/* Done function argument pointer */
46
int
bus_idx;
/* bus index: 0 or 1 */
47
} mpc5200mbus;
48
49
/* mpc5200mbus_initialize --
50
* Initialize ColdFire MBUS I2C bus controller.
51
52
* PARAMETERS:
53
* i2c_bus - pointer to the bus descriptor structure
54
55
* RETURNS:
56
* RTEMS_SUCCESSFUL, or RTEMS error code when initialization failed.
57
58
rtems_status_code
59
mpc5200mbus_initialize(mpc5200mbus *
i2c_bus
60
61
/* mpc5200mbus_select_clock_divider --
62
* Select divider for system clock which is used for I2C bus clock
63
* generation. Not each divider can be selected for I2C bus; this
64
* function select nearest larger or equal divider, or maximum
65
* possible divider, if passed value greater.
66
67
* PARAMETERS:
68
69
* divider - system frequency divider for I2C serial clock.
70
71
* RETURNS:
72
* RTEMS_SUCCESSFUL, if operation performed successfully, or
73
* RTEMS error code when failed.
74
75
rtems_status_code
76
mpc5200mbus_select_clock_divider(mpc5200mbus *
i2c_bus
int
divider);
77
78
/* mpc5200mbus_i2c_transfer --
79
* Initiate multiple-messages transfer over I2C bus via ColdFire MBUS
80
* controller.
81
82
* PARAMETERS:
83
* bus - pointer to MBUS controller descriptor
84
* nmsg - number of messages
85
* msg - pointer to messages array
86
* done - function which is called when transfer is finished
87
* done_arg_ptr - arbitrary argument ptr passed to done funciton
88
89
* RETURNS:
90
* RTEMS_SUCCESSFUL if transfer initiated successfully, or error
91
* code when failed.
92
93
rtems_status_code
94
mpc5200mbus_i2c_transfer(mpc5200mbus *bus,
int
nmsg,
i2c_message
msg
95
i2c_transfer_done done,
void
* done_arg_ptr);
96
97
/* mpc5200mbus_i2c_done --
98
* Close ColdFire MBUS I2C bus controller and release all resources.
99
100
* PARAMETERS:
101
102
103
* RETURNS:
104
* RTEMS_SUCCESSFUL, if transfer initiated successfully, or error
105
* code when failed.
106
107
rtems_status_code
108
mpc5200mbus_i2c_done(mpc5200mbus *
i2c_bus
109
110
/* mpc5200mbus_i2c_interrupt_handler --
111
* ColdFire MBUS I2C bus controller interrupt handler. This function
112
* called from real interrupt handler, and pointer to MBUS descriptor
113
* structure passed to this function.
114
115
* PARAMETERS:
116
* bus - pointert to the bus descriptor structure
117
118
* RETURNS:
119
* none
120
121
void
mpc5200mbus_i2c_interrupt_handler(mpc5200mbus *bus);
122
123
/* mpc5200mbus_poll --
124
* MBUS module poll routine; used to poll events when I2C driver
125
* operates in poll-driven mode.
126
127
* PARAMETERS:
128
* none
129
130
* RETURNS:
131
* none
132
133
void
mpc5200mbus_poll(mpc5200mbus *bus);
134
135
#endif
/* __MPC5200BSP_MPC5200MBUS_H__ */
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition
types.h:94
i2c_bus
I2C bus control.
Definition
i2c.h:123
i2c_message
Definition
i2c.h:53
mpc5200_mbus
Definition
mpc5200mbus.h:37
msg
Definition
b1553brm.c:94
