RTEMS 6.3
Definitions used in MMU setup. More...
#include <rtems.h>Go to the source code of this file.
| #define | MMU_DESC_AF ( 1 << 10 ) |
| #define | MMU_DESC_SH_INNER ( ( 1 << 9 ) | ( 1 << 8 ) ) |
| #define | MMU_DESC_WRITE_DISABLE ( 1 << 7 ) |
| #define | MMU_DESC_TYPE_TABLE ( 1 << 1 ) |
| #define | MMU_DESC_TYPE_PAGE ( 1 << 1 ) |
| #define | MMU_DESC_VALID ( 1 << 0 ) |
| #define | MMU_DESC_MAIR_ATTR(val) |
| #define | MMU_DESC_PAGE_TABLE_MASK 0xFFFFFFFFF000LL |
| #define | MMU_PAGE_BITS 12 |
| #define | MMU_PAGE_SIZE ( 1 << MMU_PAGE_BITS ) |
| #define | MMU_BITS_PER_LEVEL 9 |
| #define | AARCH64_MMU_FLAGS_BASE ( MMU_DESC_VALID | MMU_DESC_SH_INNER | MMU_DESC_AF ) |
| #define | AARCH64_MMU_DATA_RO_CACHED ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 3 ) | MMU_DESC_WRITE_DISABLE ) |
| #define | AARCH64_MMU_CODE_CACHED AARCH64_MMU_DATA_RO_CACHED |
| #define | AARCH64_MMU_CODE_RW_CACHED AARCH64_MMU_DATA_RW_CACHED |
| #define | AARCH64_MMU_DATA_RO ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 2 ) | MMU_DESC_WRITE_DISABLE ) |
| #define | AARCH64_MMU_CODE AARCH64_MMU_DATA_RO |
| #define | AARCH64_MMU_CODE_RW AARCH64_MMU_DATA_RW |
| #define | AARCH64_MMU_DATA_RW_CACHED ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 3 ) ) |
| #define | AARCH64_MMU_DATA_RW ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 2 ) ) |
| #define | AARCH64_MMU_DEVICE ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 0 ) ) |
| rtems_status_code | aarch64_mmu_map (uintptr_t addr, uint64_t size, uint64_t flags) |
| #define MMU_DESC_MAIR_ATTR | ( | val | ) |
