RTEMS 6.3
IDT 4650 Timer Driver. More...
| #define | CLOCKS_PER_MICROSECOND ( CPU_CLOCK_RATE_MHZ ) |
| #define | TIMER_MAX_VALUE 0xffffffff |
| #define | AVG_OVERHEAD 8 |
| #define | LEAST_VALID 1 |
| uint32_t | mips_read_timer (void) |
| void | benchmark_timer_initialize (void) |
| Initialize the Benchmark Timer. | |
| benchmark_timer_t | benchmark_timer_read (void) |
| Read the Benchmark Timer. | |
| void | benchmark_timer_disable_subtracting_average_overhead (bool find_flag) |
| Disable Average Overhead Removal from the Benchmark Timer. | |
This file manages the benchmark timer used by the RTEMS Timing Test Suite.
| void benchmark_timer_disable_subtracting_average_overhead | ( | bool | find_flag | ) |
This method places the benchmark timer in a "raw" mode where it returns the actual number of units which have passed between calls to benchmark_timer_initialize and benchmark_timer_read counting.
| [in] | find_flag | indicates to enable or disable the mode |
| void benchmark_timer_initialize | ( | void | ) |
This method initializes the benchmark timer and resets it to begin counting.
| benchmark_timer_t benchmark_timer_read | ( | void | ) |
This method stops the benchmark timer and returns the number of units that have passed since benchmark_timer_initialize was invoked.
