RTEMS
6.3
Toggle main menu visibility
bsps
include
libchip
mcp7940m-rtc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2023 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBCHIP_MCP7940M_RTC_H
37
#define LIBCHIP_MCP7940M_RTC_H
38
39
libchip/i2c-rtc.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
65
66
struct
mcp7940m_rtc
67
struct
i2c_rtc_base
base;
68
70
bool
crystal
71
72
74
int
mcp7940m_hw_init
struct
i2c_rtc_base
*base);
75
76
#define MCP7940M_RTC_INITIALIZER(i2c_path, i2c_address, has_crystal) { \
77
.base = I2C_RTC_INITIALIZER( \
78
i2c_path, \
79
i2c_address, \
80
0, \
81
I2C_RTC_ORDER_sec_min_hour_wkday_day_month_year, \
82
"mcp7940", \
83
mcp7940m_hw_init), \
84
.crystal = has_crystal, \
85
86
87
#define MCP7940M_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx) \
88
I2C_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx)
89
91
92
#ifdef __cplusplus
93
94
#endif
/* __cplusplus */
95
96
#endif
/* LIBCHIP_MCP7940M_RTC_H */
mcp7940m_hw_init
int mcp7940m_hw_init(struct i2c_rtc_base *base)
Definition
mcp7940m.c:68
i2c-rtc.h
This file provides the interfaces of Shared_tod_i2c_rtc.
i2c_rtc_base
Definition
i2c-rtc.h:98
mcp7940m_rtc
Definition
mcp7940m-rtc.h:66
mcp7940m_rtc::crystal
bool crystal
Definition
mcp7940m-rtc.h:70
