RTEMS
6.3
Toggle main menu visibility
bsps
m68k
gen68360
spi
m360_spi.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (c) 2008 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
43
44
#ifndef _M360_SPIDRV_H
45
#define _M360_SPIDRV_H
46
47
rtems/m68k/m68360.h
48
rtems/libi2c.h
49
rtems/irq.h
50
51
#ifdef __cplusplus
52
extern
"C"
53
#endif
54
55
typedef
struct
m360_spi_softc
56
int
initialized;
57
rtems_id
irq_sema_id;
58
rtems_isr_entry
old_handler;
59
m360BufferDescriptor_t *rx_bd;
60
m360BufferDescriptor_t *tx_bd;
61
} m360_spi_softc_t ;
62
63
typedef
struct
64
rtems_libi2c_bus_t bus_desc;
65
m360_spi_softc_t softc;
66
m360_spi_desc_t
67
68
69
| Function: |
70
71
rtems_status_code
m360_spi_init
72
73
74
| Purpose: |
75
| initialize the driver |
76
77
| Input Parameters: |
78
79
rtems_libi2c_bus_t *bh
/* bus specifier structure */
80
81
82
| Return Value: |
83
| o = ok or error code |
84
85
86
87
| Function: |
88
89
int
m360_spi_read_bytes
90
91
92
| Purpose: |
93
| receive some bytes from SPI device |
94
95
| Input Parameters: |
96
97
rtems_libi2c_bus_t *bh,
98
unsigned
char
*buf,
/* buffer to store bytes */
99
int
len
/* number of bytes to receive */
100
101
102
| Return Value: |
103
| number of bytes received or (negative) error code |
104
105
106
107
| Function: |
108
109
int
m360_spi_write_bytes
110
111
112
| Purpose: |
113
| send some bytes to SPI device |
114
115
| Input Parameters: |
116
117
118
unsigned
char
*buf,
/* buffer to send */
119
int
len
/* number of bytes to send */
120
121
122
123
| Return Value: |
124
| number of bytes sent or (negative) error code |
125
126
127
128
| Function: |
129
130
rtems_status_code
m360_spi_set_tfr_mode
131
132
133
| Purpose: |
134
| set SPI to desired baudrate/clock mode/character mode |
135
136
| Input Parameters: |
137
138
139
const
rtems_libi2c_tfr_mode_t
*tfr_mode
/* transfer mode info */
140
141
142
| Return Value: |
143
| rtems_status_code |
144
145
146
147
| Function: |
148
149
int
m360_spi_ioctl
150
151
152
| Purpose: |
153
| perform selected ioctl function for SPI |
154
155
| Input Parameters: |
156
157
158
int
cmd,
/* ioctl command code */
159
void
*arg
/* additional argument array */
160
161
162
| Return Value: |
163
| rtems_status_code |
164
165
166
#ifdef __cplusplus
167
168
#endif
169
170
171
#endif
/* _M360_SPIDRV_H */
irq.h
rtems_isr_entry
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition
intr.h:134
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition
types.h:94
libi2c.h
Legacy I2C Library.
m68360.h
Definitions for Motorola MC68360 Processor.
m360_spi_desc_t
Definition
m360_spi.h:63
m360_spi_softc
Definition
m360_spi.h:55
Definition
libi2c.h:481
