RTEMS
6.3
Toggle main menu visibility
bsps
arm
lpc32xx
include
bsp
lpc-ethernet-config.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (c) 2009 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_LPC32XX_LPC_ETHERNET_CONFIG_H
37
#define LIBBSP_ARM_LPC32XX_LPC_ETHERNET_CONFIG_H
38
39
#include <limits.h>
41
42
rtems.h
43
rtems/malloc.h
44
45
#include <bsp.h>
46
bsp/lpc32xx.h
47
48
#ifdef __cplusplus
49
extern
"C"
50
#endif
/* __cplusplus */
51
61
62
#define LPC_ETH_CONFIG_INTERRUPT LPC32XX_IRQ_ETHERNET
63
64
#define LPC_ETH_CONFIG_REG_BASE LPC32XX_BASE_ETHERNET
65
66
#define LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT 16
67
#define LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX INT_MAX
68
69
#define LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT 128
70
#define LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX INT_MAX
71
72
#define LPC_ETH_CONFIG_UNIT_MULTIPLE 8U
73
74
#ifdef LPC32XX_ETHERNET_RMII
75
#define LPC_ETH_CONFIG_RMII
76
77
static
void
lpc_eth_config_module_enable(
void
78
79
LPC32XX_MAC_CLK_CTRL = 0x1f;
80
81
#else
82
static
void
void
83
84
LPC32XX_MAC_CLK_CTRL = 0x0f;
85
86
#endif
87
88
static
void
lpc_eth_config_module_disable(
void
89
90
LPC32XX_MAC_CLK_CTRL = 0;
91
92
93
#define LPC_ETH_CONFIG_USE_TRANSMIT_DMA
94
95
static
char
*lpc_eth_config_alloc_table_area(
size_t
size)
96
97
return
rtems_heap_allocate_aligned_with_boundary
(size, 32, 0);
98
99
100
static
void
lpc_eth_config_free_table_area(
char
*table_area)
101
102
/* FIXME: Type */
103
free(table_area, NULL);
104
105
107
108
#ifdef __cplusplus
109
110
#endif
/* __cplusplus */
111
112
#endif
/* LIBBSP_ARM_LPC32XX_LPC_ETHERNET_CONFIG_H */
void * rtems_heap_allocate_aligned_with_boundary(size_t size, uintptr_t alignment, uintptr_t boundary) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE(1) RTEMS_ALLOC_ALIGN(2) RTEMS_WARN_UNUSED_RESULT
Allocates a memory area of size size bytes from the heap.
lpc32xx.h
Register base addresses.
malloc.h
This header file defines interfaces to support and use dynamic memory allocation.
rtems.h
