22#ifndef LIBBSP_ARM_LPC176X_GPIO_H
23#define LIBBSP_ARM_LPC176X_GPIO_H
uint32_t lpc176x_pin_number
A pin of the board.
Definition common-types.h:32
API definitions of the GPIO driver for the lpc176x bsp in RTEMS.
lpc176x_gpio_direction
The direction of the GPIO port (input or output).
Definition gpio-defs.h:103
void(*) lpc176x_gpio_interrupt_function(const lpc176x_pin_number pin, const lpc176x_gpio_interrupt edge)
A function that attends an interrupt for GPIO.
Definition gpio-defs.h:195
The interrupt sources edge for a GPIO.
Definition gpio-defs.h:115
rtems_status_code
Definition status.h:85
rtems_status_code lpc176x_gpio_clear_pin(const lpc176x_pin_number pin)
Sets the output pin to 0.
Definition lpc-gpio.c:343
rtems_status_code lpc176x_gpio_config(const lpc176x_pin_number pin, const lpc176x_gpio_direction dir)
Configures the pin as input or output GPIO.
Definition lpc-gpio.c:33
rtems_status_code lpc176x_gpio_write_pin(const lpc176x_pin_number pin, const bool value)
Sets the output pin to 0 or 1 according to value.
Definition lpc-gpio.c:362
rtems_status_code lpc176x_gpio_config_input_with_interrupt(const lpc176x_pin_number pin, const lpc176x_gpio_interrupt edge, const lpc176x_gpio_interrupt_function isr_funct)
Configures the pin as input, enables interrupt for an edge/s and sets isrfunct as the function to cal...
Definition lpc-gpio.c:303
rtems_status_code lpc176x_gpio_get_pin_value(const lpc176x_pin_number pin, bool *pin_value)
Returns the value at the given input pin.
Definition lpc-gpio.c:378
rtems_status_code lpc176x_gpio_set_pin(const lpc176x_pin_number pin)
Sets the output pin to 1.
Definition lpc-gpio.c:324
Specific register definitions according to lpc176x family boards.
