RTEMS
6.3
Toggle main menu visibility
bsps
arm
include
bsp
lpc-emc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2010, 2011 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_SHARED_LPC_EMC_H
37
#define LIBBSP_ARM_SHARED_LPC_EMC_H
38
39
bsp/utility.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
55
61
62
#define EMC_CTRL_E BSP_BIT32(0)
63
#define EMC_CTRL_M BSP_BIT32(0)
64
#define EMC_CTRL_L BSP_BIT32(2)
65
67
73
74
#define EMC_DYN_CTRL_CE BSP_BIT32(0)
75
#define EMC_DYN_CTRL_CS BSP_BIT32(1)
76
#define EMC_DYN_CTRL_SR BSP_BIT32(2)
77
#define EMC_DYN_CTRL_SRMCC BSP_BIT32(3)
78
#define EMC_DYN_CTRL_IMCC BSP_BIT32(4)
79
#define EMC_DYN_CTRL_MCC BSP_BIT32(5)
80
#define EMC_DYN_CTRL_I_MASK BSP_MSK32(7, 8)
81
#define EMC_DYN_CTRL_I_NORMAL BSP_FLD32(0x0, 7, 8)
82
#define EMC_DYN_CTRL_I_MODE BSP_FLD32(0x1, 7, 8)
83
#define EMC_DYN_CTRL_I_PALL BSP_FLD32(0x2, 7, 8)
84
#define EMC_DYN_CTRL_I_NOP BSP_FLD32(0x3, 7, 8)
85
#define EMC_DYN_CTRL_DP BSP_BIT32(13)
86
88
94
95
#define EMC_DYN_READ_CONFIG_SDR_STRAT(val) BSP_FLD32(val, 0, 1)
96
#define EMC_DYN_READ_CONFIG_SDR_POL_POS BSP_BIT32(4)
97
#define EMC_DYN_READ_CONFIG_DDR_STRAT(val) BSP_FLD32(val, 8, 9)
98
#define EMC_DYN_READ_CONFIG_DDR_POL_POS BSP_BIT32(12)
99
101
107
108
#define EMC_DYN_CFG_MD_LPC24XX(val) BSP_FLD32(val, 3, 4)
109
#define EMC_DYN_CFG_MD_LPC32XX(val) BSP_FLD32(val, 0, 2)
110
#define EMC_DYN_CFG_AM(val) BSP_FLD32(val, 7, 14)
111
#define EMC_DYN_CFG_B BSP_BIT32(19)
112
#define EMC_DYN_CFG_P BSP_BIT32(20)
113
115
121
122
#define EMC_DYN_RASCAS_RAS(val) BSP_FLD32(val, 0, 3)
123
#define EMC_DYN_RASCAS_CAS(val, half) BSP_FLD32(((val) << 1) | (half), 7, 10)
124
126
127
#define EMC_DYN_CHIP_COUNT 4
128
129
#define EMC_STATIC_CHIP_COUNT 4
130
131
typedef
struct
132
uint32_t config;
133
uint32_t rascas;
134
uint32_t reserved_0 [6];
135
lpc_emc_dynamic
136
137
typedef
struct
138
uint32_t config;
139
uint32_t waitwen;
140
uint32_t waitoen;
141
uint32_t waitrd;
142
uint32_t waitpage;
143
uint32_t waitwr;
144
uint32_t waitturn;
145
uint32_t reserved_0 [1];
146
lpc_emc_static
147
148
typedef
struct
149
uint32_t control;
150
uint32_t status;
151
uint32_t config;
152
uint32_t reserved_0 [5];
153
uint32_t dynamiccontrol;
154
uint32_t dynamicrefresh;
155
uint32_t dynamicreadconfig;
156
uint32_t reserved_1;
157
uint32_t dynamictrp;
158
uint32_t dynamictras;
159
uint32_t dynamictsrex;
160
uint32_t dynamictapr;
161
uint32_t dynamictdal;
162
uint32_t dynamictwr;
163
uint32_t dynamictrc;
164
uint32_t dynamictrfc;
165
uint32_t dynamictxsr;
166
uint32_t dynamictrrd;
167
uint32_t dynamictmrd;
168
uint32_t dynamictcdlr;
169
uint32_t reserved_3 [8];
170
uint32_t staticextendedwait;
171
uint32_t reserved_4 [31];
172
lpc_emc_dynamic
dynamic [EMC_DYN_CHIP_COUNT];
173
uint32_t reserved_5 [32];
174
lpc_emc_static
emcstatic [EMC_STATIC_CHIP_COUNT];
175
lpc_emc
176
178
179
#ifdef __cplusplus
180
181
#endif
/* __cplusplus */
182
183
#endif
/* LIBBSP_ARM_SHARED_LPC_EMC_H */
utility.h
This header file provides utility macros for BSPs.
lpc_emc_dynamic
Definition
lpc-emc.h:131
lpc_emc_static
Definition
lpc-emc.h:137
lpc_emc
Definition
lpc-emc.h:148
