RTEMS
6.3
Toggle main menu visibility
libfs
src
jffs2
include
linux
list.h
1
2
* JFFS2 -- Journalling Flash File System, Version 2.
3
4
5
* Created by Jonathan Larmour <jlarmour@redhat.com>
6
7
8
* ####ECOSGPLCOPYRIGHTBEGIN####
9
10
* This file is part of eCos, the Embedded Configurable Operating System.
11
* Copyright (C) 2002, 2003 Free Software Foundation, Inc.
12
13
* eCos is free software; you can redistribute it and/or modify it under
14
* the terms of the GNU General Public License as published by the Free
15
* Software Foundation; either version 2 or (at your option) any later
16
* version.
17
18
* eCos is distributed in the hope that it will be useful, but WITHOUT
19
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
20
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
21
* for more details.
22
23
* You should have received a copy of the GNU General Public License
24
* along with eCos; if not, write to the Free Software Foundation, Inc.,
25
* 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
26
27
* As a special exception, if other files instantiate templates or use
28
* macros or inline functions from this file, or you compile this file
29
* and link it with other works to produce a work based on this file,
30
* this file does not by itself cause the resulting work to be covered by
31
* the GNU General Public License. However the source code for this file
32
* must still be made available in accordance with section (3) of the GNU
33
* General Public License v2.
34
35
* This exception does not invalidate any other reasons why a work based
36
* on this file might be covered by the GNU General Public License.
37
38
* ####ECOSGPLCOPYRIGHTEND####
39
40
41
42
43
#ifndef CYGONCE_FS_JFFS2_LIST_H
44
#define CYGONCE_FS_JFFS2_LIST_H
45
46
47
48
49
/* Doubly linked list implementation to replace the GPL'd one used in
50
the Linux kernel. */
51
52
#include <stddef.h>
53
#include <cyg/infra/cyg_type.h>
54
55
/* TYPES */
56
57
struct
list_head
58
struct
list_head
*next;
59
struct
list_head
*prev;
60
61
62
/* MACROS */
63
64
#define LIST_HEAD_INIT(name) { &(name), &(name) }
65
66
#define LIST_HEAD(name) \
67
struct list_head name = LIST_HEAD_INIT(name)
68
69
#define INIT_LIST_HEAD( _list_ ) \
70
CYG_MACRO_START \
71
(_list_)->next = (_list_)->prev = (_list_); \
72
CYG_MACRO_END
73
74
/* FUNCTIONS */
75
76
/* Insert an entry _after_ the specified entry */
77
static
__inline__
void
78
list_add(
struct
list_head
*newent,
struct
list_head
*afterthisent )
79
80
struct
list_head
*next = afterthisent->next;
81
newent->next = next;
82
newent->prev = afterthisent;
83
afterthisent->next = newent;
84
next->prev = newent;
85
/* list_add() */
86
87
/* Insert an entry _before_ the specified entry */
88
static
__inline__
void
89
list_add_tail(
struct
list_head
*newent,
struct
list_head
*beforethisent )
90
91
struct
list_head
*prev = beforethisent->prev;
92
newent->prev = prev;
93
newent->next = beforethisent;
94
beforethisent->prev = newent;
95
prev->next = newent;
96
/* list_add_tail() */
97
98
/* Delete the specified entry */
99
static
__inline__
void
100
list_del(
struct
list_head
*ent )
101
102
ent->prev->next = ent->next;
103
ent->next->prev = ent->prev;
104
/* list_del() */
105
106
static
__inline__
void
107
list_move(
struct
list_head
*list,
struct
list_head
*head )
108
109
list_del( list );
110
list_add( list, head );
111
112
113
static
__inline__
void
114
list_move_tail(
struct
list_head
*list,
struct
list_head
*head )
115
116
list_del( list );
117
list_add_tail( list, head );
118
119
120
/* Is this list empty? */
121
static
__inline__
int
122
list_empty(
struct
list_head
*list )
123
124
return
( list->next == list );
125
/* list_empty() */
126
127
/* list_entry - Assuming you have a struct of type _type_ that contains a
128
list which has the name _member_ in that struct type, then given the
129
address of that list in the struct, _list_, this returns the address
130
of the container structure */
131
132
#define list_entry( _list_, _type_, _member_ ) \
133
((_type_ *)((char *)(_list_)-(char *)(offsetof(_type_,_member_))))
134
135
/* list_for_each - using _ent_, iterate through list _list_ */
136
137
#define list_for_each( _ent_, _list_ ) \
138
for ( (_ent_) = (_list_)->next; \
139
(_ent_) != (_list_); \
140
(_ent_) = (_ent_)->next )
141
142
/* list_for_each_safe - using _ent_, iterate through list _list_
143
while protecting against removal of list elements */
144
145
#define list_for_each_safe( _ent_, _tmp_, _list_ ) \
146
for ( (_ent_) = (_list_)->next, (_tmp_) = (_ent_)->next; \
147
148
(_ent_) = (_tmp_), (_tmp_) = (_ent_)->next )
149
150
151
* list_for_each_entry - this function can be use to iterate over all
152
* items in a list* _list_ with it's head at _head_ and link _item_
153
154
#define list_for_each_entry(_list_, _head_, _item_) \
155
for ((_list_) = list_entry((_head_)->next, typeof(*_list_), _item_); \
156
&((_list_)->_item_) != (_head_); \
157
(_list_) = list_entry((_list_)->_item_.next, typeof(*_list_), _item_))
158
159
160
#endif
/* #ifndef CYGONCE_FS_JFFS2_LIST_H */
161
/* EOF list.h */
list_head
Definition
list.h:57
