RTEMS
6.3
Toggle main menu visibility
bsps
sparc
leon3
include
bsp
irqimpl.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (C) 2021 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H
38
#define LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H
39
40
rtems.h
41
grlib/irqamp-regs.h
42
#include <grlib/io.h>
43
44
#include <bspopts.h>
45
46
struct
ambapp_dev
47
48
#ifdef __cplusplus
49
extern
"C"
50
#endif
51
57
63
extern
uint32_t
LEON3_Cpu_Index
64
68
extern
rtems_interrupt_lock
LEON3_IrqCtrl_Lock
69
75
#define LEON3_IRQCTRL_ACQUIRE( _lock_context ) \
76
rtems_interrupt_lock_acquire( &LEON3_IrqCtrl_Lock, _lock_context )
77
83
#define LEON3_IRQCTRL_RELEASE( _lock_context ) \
84
rtems_interrupt_lock_release( &LEON3_IrqCtrl_Lock, _lock_context )
85
89
#if defined(LEON3_IRQAMP_BASE)
90
#define LEON3_IrqCtrl_Regs ((irqamp *) LEON3_IRQAMP_BASE)
91
#else
92
extern
irqamp
LEON3_IrqCtrl_Regs
93
97
extern
struct
ambapp_dev
LEON3_IrqCtrl_Adev
98
#endif
99
106
#if defined(LEON3_IRQAMP_EXTENDED_INTERRUPT)
107
#define LEON3_IrqCtrl_EIrq LEON3_IRQAMP_EXTENDED_INTERRUPT
108
#else
109
extern
uint32_t
LEON3_IrqCtrl_EIrq
110
#endif
111
117
void
leon3_ext_irq_init
irqamp
*regs );
118
125
static
inline
uint32_t bsp_irq_fixup( uint32_t irq )
126
127
uint32_t eirq;
128
uint32_t cpu_self;
129
130
if
( irq !=
LEON3_IrqCtrl_EIrq
131
return
irq;
132
133
134
cpu_self = _LEON3_Get_current_processor();
135
eirq = grlib_load_32( &
LEON3_IrqCtrl_Regs
pextack
[ cpu_self ] );
136
eirq = IRQAMP_PEXTACK_EID_4_0_GET( eirq );
137
138
if
( eirq < 16 ) {
139
return
irq;
140
141
142
return
eirq;
143
144
146
147
#ifdef __cplusplus
148
149
#endif
150
151
#endif
/* LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H */
char rtems_interrupt_lock
This structure represents an ISR lock.
Definition
intr.h:532
LEON3_IrqCtrl_Regs
irqamp * LEON3_IrqCtrl_Regs
This pointer provides the IRQ(A)MP register block address.
Definition
amba.c:121
leon3_ext_irq_init
void leon3_ext_irq_init(irqamp *regs)
Initializes the interrupt controller for the boot processor.
Definition
eirq.c:54
LEON3_IrqCtrl_Adev
struct ambapp_dev * LEON3_IrqCtrl_Adev
This pointer provides the IRQ(A)MP device information block.
Definition
amba.c:122
LEON3_IrqCtrl_EIrq
uint32_t LEON3_IrqCtrl_EIrq
This object provides the interrupt number used to multiplex extended interrupts or is zero if no exte...
Definition
eirq.c:47
LEON3_Cpu_Index
uint32_t LEON3_Cpu_Index
This object provides the index of the boot processor.
Definition
bspstart.c:64
LEON3_IrqCtrl_Lock
rtems_interrupt_lock LEON3_IrqCtrl_Lock
This lock serializes the interrupt controller access.
Definition
eirq.c:50
irqamp-regs.h
This header file defines the IRQAMP register block interface.
rtems.h
ambapp_dev
Definition
ambapp.h:94
irqamp
This structure defines the IRQ(A)MP register block memory map.
Definition
irqamp-regs.h:780
irqamp::pextack
uint32_t pextack[16]
See Processor n extended interrupt acknowledge register (PEXTACK).
Definition
irqamp-regs.h:846
