RTEMS
6.3
Toggle main menu visibility
bsps
riscv
riscv
include
bsp
k210.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (c) 2022 Alan Cudmore
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_RISCV_RISCV_K210_H
37
#define LIBBSP_RISCV_RISCV_K210_H
38
39
#include <bspopts.h>
40
#include <stdint.h>
41
bsp/utility.h
42
52
53
#ifdef __cplusplus
54
extern
"C"
55
#endif
56
57
/* For PLL / Clocks */
58
#define K210_SYSCTL_BASE 0x50440000
59
60
#define PLL_CLK_R(n) (n & 0x00000F)
61
#define PLL_CLK_F(n) ((n & 0x0003F0) >> 4)
62
#define PLL_CLK_OD(n) ((n & 0x003C00) >> 10)
63
#define CLKSEL0_ACLK_SEL(n) (n & 0x00000001)
64
65
typedef
struct
66
uint32_t git_id;
67
uint32_t clk_freq;
68
uint32_t pll0;
69
uint32_t pll1;
70
uint32_t pll2;
71
uint32_t resv5;
72
uint32_t pll_lock;
73
uint32_t rom_error;
74
uint32_t clk_sel0;
75
uint32_t clk_sel1;
76
uint32_t clk_en_cent;
77
uint32_t clk_en_peri;
78
uint32_t soft_reset;
79
uint32_t peri_reset;
80
uint32_t clk_th0;
81
uint32_t clk_th1;
82
uint32_t clk_th2;
83
uint32_t clk_th3;
84
uint32_t clk_th4;
85
uint32_t clk_th5;
86
uint32_t clk_th6;
87
uint32_t misc;
88
uint32_t peri;
89
uint32_t spi_sleep;
90
uint32_t reset_status;
91
uint32_t dma_sel0;
92
uint32_t dma_sel1;
93
uint32_t power_sel;
94
uint32_t resv28;
95
uint32_t resv29;
96
uint32_t resv30;
97
uint32_t resv31;
98
k210_sysctl_t
99
100
#ifdef __cplusplus
101
102
#endif
103
105
#endif
/* LIBBSP_RISCV_RISCV_K210_H */
utility.h
This header file provides utility macros for BSPs.
k210_sysctl_t
Definition
k210.h:65
