RTEMS 6.3
intc.h
2
10
11/*
12 * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_MICROBLAZE_FPGA_INTC_H
37#define LIBBSP_MICROBLAZE_FPGA_INTC_H
38
39#include <bspopts.h>
40
41#include <bsp/utility.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
47typedef struct {
48 /* Interrupt Status Register */
49 uint32_t isr;
50 uint32_t ipr;
51 /* Interrupt Enable Register */
52 uint32_t ier;
53 /* Interrupt Acknowledge Register */
54 uint32_t iar;
55 uint32_t sie;
56 uint32_t cie;
57 uint32_t ivr;
58#define MICROBLAZE_INTC_MER_HIE BSP_BIT32(1)
59#define MICROBLAZE_INTC_MER_ME BSP_BIT32(0)
60 /* Master Enable Register */
61 uint32_t mer;
62 /* Interrupt Mode Register, this is present only for Fast Interrupt */
63 uint32_t imr;
64 /* Interrupt Level Register */
65 uint32_t ilr;
67
68#ifdef __cplusplus
69}
70#endif /* __cplusplus */
71
72#endif /* LIBBSP_MICROBLAZE_FPGA_INTC_H */
This header file provides utility macros for BSPs.
Definition intc.h:47
