RTEMS
6.3
Toggle main menu visibility
bsps
arm
imx
include
arm
freescale
imx
imx6ul_ccmreg.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (C) 2022 embedded brains GmbH & Co. KG
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
27
28
#ifndef IMX6UL_CCMREG_H
29
#define IMX6UL_CCMREG_H
30
31
bsp/utility.h
32
33
typedef
struct
34
uint32_t ccr;
35
uint32_t ccdr;
36
uint32_t csr;
37
uint32_t ccsr;
38
uint32_t cacrr;
39
uint32_t cbcdr;
40
uint32_t cbcmr;
41
uint32_t cscmr1;
42
uint32_t cscmr2;
43
uint32_t cscdr1;
44
uint32_t cs1cdr;
45
uint32_t cs2cdr;
46
uint32_t cdcdr;
47
uint32_t chsccdr;
48
uint32_t cscdr2;
49
uint32_t cscdr3;
50
uint32_t reserved_40[2];
51
uint32_t cdhipr;
52
uint32_t reserved_4c[2];
53
uint32_t clpcr;
54
uint32_t cisr;
55
uint32_t cimr;
56
uint32_t ccosr;
57
uint32_t cgpr;
58
uint32_t ccgr0;
59
uint32_t ccgr1;
60
uint32_t ccgr2;
61
uint32_t ccgr3;
62
uint32_t ccgr4;
63
uint32_t ccgr5;
64
uint32_t ccgr6;
65
uint32_t reserved_84[1];
66
uint32_t cmeor;
67
imx6ul_ccm
68
69
typedef
struct
70
uint32_t pll_arm;
71
uint32_t pll_arm_set;
72
uint32_t pll_arm_clr;
73
uint32_t pll_arm_tog;
74
uint32_t pll_usb1;
75
uint32_t pll_usb1_set;
76
uint32_t pll_usb1_clr;
77
uint32_t pll_usb1_tog;
78
uint32_t pll_usb2;
79
uint32_t pll_usb2_set;
80
uint32_t pll_usb2_clr;
81
uint32_t pll_usb2_tog;
82
uint32_t pll_sys;
83
uint32_t pll_sys_set;
84
uint32_t pll_sys_clr;
85
uint32_t pll_sys_tog;
86
uint32_t pll_sys_ss;
87
uint32_t reserved_44[3];
88
uint32_t pll_sys_num;
89
uint32_t reserved_54[3];
90
uint32_t pll_sys_denom;
91
uint32_t reserved_64[3];
92
uint32_t pll_audio;
93
uint32_t pll_audio_set;
94
uint32_t pll_audio_clr;
95
uint32_t pll_audio_tog;
96
uint32_t pll_audio_num;
97
uint32_t reserved_84[3];
98
uint32_t pll_audio_denom;
99
uint32_t reserved_94[3];
100
uint32_t pll_video;
101
uint32_t pll_video_set;
102
uint32_t pll_video_clr;
103
uint32_t pll_video_tog;
104
uint32_t pll_video_num;
105
uint32_t reserved_b4[3];
106
uint32_t pll_video_denom;
107
uint32_t reserved_c4[7];
108
uint32_t pll_enet;
109
#define IMX6UL_CCM_ANALOG_PLL_ENET_LOCK BSP_BIT32(31)
110
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN BSP_BIT32(21)
111
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET2_125M_EN BSP_BIT32(20)
112
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENABLE_125M BSP_BIT32(19)
113
#define IMX6UL_CCM_ANALOG_PLL_ENET_PFD_OFFSET_EN BSP_BIT32(18)
114
#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS BSP_BIT32(16)
115
#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC(val) BSP_FLD32(val, 14, 15)
116
#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_GET(val) BSP_FLD32GET(val, 14, 15)
117
#define IMX6UL_CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_SET(val) BSP_FLD32SET(val, 14, 15)
118
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_125M_EN BSP_BIT32(13)
119
#define IMX6UL_CCM_ANALOG_PLL_ENET_POWERDOWN BSP_BIT32(12)
120
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT(val) BSP_FLD32(val, 3, 2)
121
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT_GET(val) BSP_FLD32GET(val, 3, 2)
122
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET1_DIV_SELECT_SET(val) BSP_FLD32SET(val, 3, 2)
123
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT(val) BSP_FLD32(val, 0, 1)
124
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT_GET(val) BSP_FLD32GET(val, 0, 1)
125
#define IMX6UL_CCM_ANALOG_PLL_ENET_ENET0_DIV_SELECT_SET(val) BSP_FLD32SET(val, 0, 1)
126
uint32_t pll_enet_set;
127
uint32_t pll_enet_clr;
128
uint32_t pll_enet_tog;
129
uint32_t pfd_480;
130
uint32_t pfd_480_set;
131
uint32_t pfd_480_clr;
132
uint32_t pfd_480_tog;
133
uint32_t pfd_528;
134
uint32_t pfd_528_set;
135
uint32_t pfd_528_clr;
136
uint32_t pfd_528_tog;
137
uint32_t reserved_110[16];
138
uint32_t misc0;
139
uint32_t misc0_set;
140
uint32_t misc0_clr;
141
uint32_t misc0_tog;
142
uint32_t misc1;
143
uint32_t misc1_set;
144
uint32_t misc1_clr;
145
uint32_t misc1_tog;
146
uint32_t misc2;
147
uint32_t misc2_set;
148
uint32_t misc2_clr;
149
uint32_t misc2_tog;
150
imx6ul_ccm_analog
151
152
#endif
/* IMX6UL_CCMREG_H */
utility.h
This header file provides utility macros for BSPs.
imx6ul_ccm_analog
Definition
imx6ul_ccmreg.h:69
imx6ul_ccm
Definition
imx6ul_ccmreg.h:33
