RTEMS
6.3
Toggle main menu visibility
bsps
i386
include
bsp
apic.h
1
6
7
8
* Author: Erich Boleyn <erich@uruk.org>
9
* http://www.uruk.org/~erich/
10
11
* Copyright (c) 1997-2011 Erich Boleyn. All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions
15
* are met:
16
* 1. Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
* 2. Redistributions in binary form must reproduce the above copyright
19
* notice, this list of conditions and the following disclaimer in the
20
* documentation and/or other materials provided with the distribution.
21
* 3. The name of the author may not be used to endorse or promote products
22
* derived from this software without specific prior written permission.
23
24
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
25
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
26
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
27
* IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
28
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
29
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
30
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
31
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
33
* THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
42
43
44
* Header file for Intel Architecture local and I/O APIC definitions.
45
46
* This file was created from information in the Intel Pentium Pro
47
* Family Developer's Manual, Volume 3: Operating System Writer's
48
* Manual, order number 242692-001, which can be ordered from the
49
* Intel literature center.
50
51
52
#ifndef _APIC_H
53
#define _APIC_H
54
55
56
* APIC Defines.
57
58
59
60
* Recommendation: Don't use this except for MSI interrupt delivery.
61
* In general, the "Destination Mode" can be used to control this, since
62
* it is DIFFERENT (0xF) for Pentium and P6, but not on the same APIC
63
* version for AMD Opteron.
64
65
#define APIC_BCAST_ID 0xFF
66
67
68
* APIC register definitions
69
70
71
72
* Shared defines for I/O and local APIC definitions
73
75
#define APIC_VERSION(x) ((x) & 0xFF)
76
#define APIC_MAXREDIR(x) (((x) >> 16) & 0xFF)
78
#define APIC_ID(x) ((x) >> 24)
79
#define APIC_VER_NEW 0x10
80
81
#define IOAPIC_REGSEL 0
82
#define IOAPIC_RW 0x10
83
#define IOAPIC_ID 0
84
#define IOAPIC_VER 1
85
#define IOAPIC_REDIR 0x10
86
87
#define LAPIC_ID 0x20
88
#define LAPIC_VER 0x30
89
#define LAPIC_TPR 0x80
90
#define LAPIC_APR 0x90
91
#define LAPIC_PPR 0xA0
92
#define LAPIC_EOI 0xB0
93
#define LAPIC_LDR 0xD0
94
#define LAPIC_DFR 0xE0
95
#define LAPIC_SPIV 0xF0
96
#define LAPIC_SPIV_ENABLE_APIC 0x100
97
#define LAPIC_ISR 0x100
98
#define LAPIC_TMR 0x180
99
#define LAPIC_IRR 0x200
100
#define LAPIC_ESR 0x280
101
#define LAPIC_ICR 0x300
102
#define LAPIC_ICR_DS_SELF 0x40000
103
#define LAPIC_ICR_DS_ALLINC 0x80000
104
#define LAPIC_ICR_DS_ALLEX 0xC0000
105
#define LAPIC_ICR_TM_LEVEL 0x8000
106
#define LAPIC_ICR_LEVELASSERT 0x4000
107
#define LAPIC_ICR_STATUS_PEND 0x1000
108
#define LAPIC_ICR_DM_LOGICAL 0x800
109
#define LAPIC_ICR_DM_LOWPRI 0x100
110
#define LAPIC_ICR_DM_SMI 0x200
111
#define LAPIC_ICR_DM_NMI 0x400
112
#define LAPIC_ICR_DM_INIT 0x500
113
#define LAPIC_ICR_DM_SIPI 0x600
114
#define LAPIC_LVTT 0x320
115
#define LAPIC_LVTPC 0x340
116
#define LAPIC_LVT0 0x350
117
#define LAPIC_LVT1 0x360
118
#define LAPIC_LVTE 0x370
119
#define LAPIC_TICR 0x380
120
#define LAPIC_TCCR 0x390
121
#define LAPIC_TDCR 0x3E0
122
123
#endif
/* _APIC_H */
124
