RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
mpc83xx
gtm.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
8
9
10
* Copyright (c) 2008 embedded brains GmbH & Co. KG
11
12
* modification, are permitted provided that the following conditions
13
* are met:
14
* 1. Redistributions of source code must retain the above copyright
15
* notice, this list of conditions and the following disclaimer.
16
* 2. Redistributions in binary form must reproduce the above copyright
17
* notice, this list of conditions and the following disclaimer in the
18
* documentation and/or other materials provided with the distribution.
19
20
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30
* POSSIBILITY OF SUCH DAMAGE.
31
32
33
#ifndef LIBBSP_POWERPC_MPC83XX_TIMER_H
34
#define LIBBSP_POWERPC_MPC83XX_TIMER_H
35
36
#include <stdint.h>
37
#include <stdbool.h>
38
39
rtems.h
40
41
#define MPC83XX_GTM_NUMBER 8
42
43
#define MPC83XX_GTM_CLOCK_CASCADED 0x0000
44
#define MPC83XX_GTM_CLOCK_SYSTEM 0x0002
45
#define MPC83XX_GTM_CLOCK_SYSTEM_SLOW 0x0004
46
#define MPC83XX_GTM_CLOCK_EXTERN 0x0006
47
48
rtems_status_code
mpc83xx_gtm_initialize(
int
timer,
int
clock);
49
50
rtems_status_code
mpc83xx_gtm_enable_restart(
int
timer,
bool
enable);
51
52
rtems_status_code
mpc83xx_gtm_set_clock(
int
timer,
int
clock);
53
54
rtems_status_code
mpc83xx_gtm_get_clock(
int
timer,
int
*clock);
55
56
rtems_status_code
mpc83xx_gtm_start(
int
timer);
57
58
rtems_status_code
mpc83xx_gtm_stop(
int
timer);
59
60
rtems_status_code
mpc83xx_gtm_set_value(
int
timer, uint16_t value);
61
62
rtems_status_code
mpc83xx_gtm_get_value(
int
timer, uint16_t *value);
63
64
rtems_status_code
mpc83xx_gtm_set_reference(
int
timer, uint16_t reference);
65
66
rtems_status_code
mpc83xx_gtm_get_reference(
int
timer, uint16_t *reference);
67
68
rtems_status_code
mpc83xx_gtm_set_prescale(
int
timer, uint8_t prescale);
69
70
rtems_status_code
mpc83xx_gtm_get_prescale(
int
timer, uint8_t *prescale);
71
72
rtems_status_code
mpc83xx_gtm_interrupt_get_vector(
int
timer,
rtems_vector_number
*vector);
73
74
rtems_status_code
mpc83xx_gtm_interrupt_enable(
int
timer);
75
76
rtems_status_code
mpc83xx_gtm_interrupt_disable(
int
timer);
77
78
rtems_status_code
mpc83xx_gtm_interrupt_clear(
int
timer);
79
80
#endif
/* LIBBSP_POWERPC_MPC83XX_TIMER_H */
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition
intr.h:102
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems.h
