RTEMS 6.3
Files | |
| file | bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_clock.h |
| file | bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_clock.h |
| struct | _clock_arm_pll_config |
| PLL configuration for ARM. More... | |
| struct | _clock_usb_pll_config |
| PLL configuration for USB. More... | |
| struct | _clock_sys_pll_config |
| PLL configuration for System. More... | |
| struct | _clock_audio_pll_config |
| PLL configuration for AUDIO and VIDEO. More... | |
| struct | _clock_video_pll_config |
| struct | _clock_enet_pll_config |
| PLL configuration for ENET. More... | |
| struct | _clock_group_config |
| The structure used to configure clock group. More... | |
| struct | _clock_pll_ss_config |
| Spread specturm configure Pll. More... | |
| struct | _clock_sys_pll2_config |
| PLL configure for Sys Pll2. More... | |
| struct | _clock_sys_pll1_config |
| PLL configure for Sys Pll1. More... | |
| struct | _clock_audio_pll_gpc_config |
| PLL configuration fro AUDIO PLL, SYSTEM PLL1 and VIDEO PLL. More... | |
| struct | _clock_root_config_t |
| Clock root configuration. More... | |
| struct | _clock_root_setpoint_config_t |
| Clock root configuration in SetPoint Mode. More... | |
| #define | FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL 0 |
| Configure whether driver controls clock. | |
Driver version | |
| enum | _clock_name { kCLOCK_CpuClk = 0x0U , kCLOCK_AhbClk = 0x1U , kCLOCK_SemcClk = 0x2U , kCLOCK_IpgClk = 0x3U , kCLOCK_PerClk = 0x4U , kCLOCK_OscClk = 0x5U , kCLOCK_RtcClk = 0x6U , kCLOCK_ArmPllClk = 0x7U , kCLOCK_Usb1PllClk = 0x8U , kCLOCK_Usb1PllPfd0Clk = 0x9U , kCLOCK_Usb1PllPfd1Clk = 0xAU , kCLOCK_Usb1PllPfd2Clk = 0xBU , kCLOCK_Usb1PllPfd3Clk = 0xCU , kCLOCK_Usb1SwClk = 0x17U , kCLOCK_Usb1Sw120MClk = 0x18U , kCLOCK_Usb1Sw60MClk = 0x19U , kCLOCK_Usb1Sw80MClk = 0x1AU , kCLOCK_Usb2PllClk = 0xDU , kCLOCK_SysPllClk = 0xEU , kCLOCK_SysPllPfd0Clk = 0xFU , kCLOCK_SysPllPfd1Clk = 0x10U , kCLOCK_SysPllPfd2Clk = 0x11U , kCLOCK_SysPllPfd3Clk = 0x12U , kCLOCK_EnetPll0Clk = 0x13U , kCLOCK_EnetPll1Clk = 0x14U , kCLOCK_AudioPllClk = 0x15U , kCLOCK_VideoPllClk = 0x16U , kCLOCK_NoneName = CLOCK_SOURCE_NONE } |
| Clock name used to get clock frequency. More... | |
| enum | _clock_ip_name { kCLOCK_IpInvalid = -1 , kCLOCK_Aips_tz1 = (0U << 8U) | CCM_CCGR0_CG0_SHIFT , kCLOCK_Aips_tz2 = (0U << 8U) | CCM_CCGR0_CG1_SHIFT , kCLOCK_Mqs = (0U << 8U) | CCM_CCGR0_CG2_SHIFT , kCLOCK_FlexSpiExsc = (0U << 8U) | CCM_CCGR0_CG3_SHIFT , kCLOCK_Sim_M_Main = (0U << 8U) | CCM_CCGR0_CG4_SHIFT , kCLOCK_Dcp = (0U << 8U) | CCM_CCGR0_CG5_SHIFT , kCLOCK_Lpuart3 = (0U << 8U) | CCM_CCGR0_CG6_SHIFT , kCLOCK_Can1 = (0U << 8U) | CCM_CCGR0_CG7_SHIFT , kCLOCK_Can1S = (0U << 8U) | CCM_CCGR0_CG8_SHIFT , kCLOCK_Can2 = (0U << 8U) | CCM_CCGR0_CG9_SHIFT , kCLOCK_Can2S = (0U << 8U) | CCM_CCGR0_CG10_SHIFT , kCLOCK_Trace = (0U << 8U) | CCM_CCGR0_CG11_SHIFT , kCLOCK_Gpt2 = (0U << 8U) | CCM_CCGR0_CG12_SHIFT , kCLOCK_Gpt2S = (0U << 8U) | CCM_CCGR0_CG13_SHIFT , kCLOCK_Lpuart2 = (0U << 8U) | CCM_CCGR0_CG14_SHIFT , kCLOCK_Gpio2 = (0U << 8U) | CCM_CCGR0_CG15_SHIFT , kCLOCK_Lpspi1 = (1U << 8U) | CCM_CCGR1_CG0_SHIFT , kCLOCK_Lpspi2 = (1U << 8U) | CCM_CCGR1_CG1_SHIFT , kCLOCK_Lpspi3 = (1U << 8U) | CCM_CCGR1_CG2_SHIFT , kCLOCK_Lpspi4 = (1U << 8U) | CCM_CCGR1_CG3_SHIFT , kCLOCK_Adc2 = (1U << 8U) | CCM_CCGR1_CG4_SHIFT , kCLOCK_Enet = (1U << 8U) | CCM_CCGR1_CG5_SHIFT , kCLOCK_Pit = (1U << 8U) | CCM_CCGR1_CG6_SHIFT , kCLOCK_Aoi2 = (1U << 8U) | CCM_CCGR1_CG7_SHIFT , kCLOCK_Adc1 = (1U << 8U) | CCM_CCGR1_CG8_SHIFT , kCLOCK_SemcExsc = (1U << 8U) | CCM_CCGR1_CG9_SHIFT , kCLOCK_Gpt1 = (1U << 8U) | CCM_CCGR1_CG10_SHIFT , kCLOCK_Gpt1S = (1U << 8U) | CCM_CCGR1_CG11_SHIFT , kCLOCK_Lpuart4 = (1U << 8U) | CCM_CCGR1_CG12_SHIFT , kCLOCK_Gpio1 = (1U << 8U) | CCM_CCGR1_CG13_SHIFT , kCLOCK_Csu = (1U << 8U) | CCM_CCGR1_CG14_SHIFT , kCLOCK_Gpio5 = (1U << 8U) | CCM_CCGR1_CG15_SHIFT , kCLOCK_OcramExsc = (2U << 8U) | CCM_CCGR2_CG0_SHIFT , kCLOCK_Csi = (2U << 8U) | CCM_CCGR2_CG1_SHIFT , kCLOCK_IomuxcSnvs = (2U << 8U) | CCM_CCGR2_CG2_SHIFT , kCLOCK_Lpi2c1 = (2U << 8U) | CCM_CCGR2_CG3_SHIFT , kCLOCK_Lpi2c2 = (2U << 8U) | CCM_CCGR2_CG4_SHIFT , kCLOCK_Lpi2c3 = (2U << 8U) | CCM_CCGR2_CG5_SHIFT , kCLOCK_Ocotp = (2U << 8U) | CCM_CCGR2_CG6_SHIFT , kCLOCK_Xbar3 = (2U << 8U) | CCM_CCGR2_CG7_SHIFT , kCLOCK_Ipmux1 = (2U << 8U) | CCM_CCGR2_CG8_SHIFT , kCLOCK_Ipmux2 = (2U << 8U) | CCM_CCGR2_CG9_SHIFT , kCLOCK_Ipmux3 = (2U << 8U) | CCM_CCGR2_CG10_SHIFT , kCLOCK_Xbar1 = (2U << 8U) | CCM_CCGR2_CG11_SHIFT , kCLOCK_Xbar2 = (2U << 8U) | CCM_CCGR2_CG12_SHIFT , kCLOCK_Gpio3 = (2U << 8U) | CCM_CCGR2_CG13_SHIFT , kCLOCK_Lcd = (2U << 8U) | CCM_CCGR2_CG14_SHIFT , kCLOCK_Pxp = (2U << 8U) | CCM_CCGR2_CG15_SHIFT , kCLOCK_Flexio2 = (3U << 8U) | CCM_CCGR3_CG0_SHIFT , kCLOCK_Lpuart5 = (3U << 8U) | CCM_CCGR3_CG1_SHIFT , kCLOCK_Semc = (3U << 8U) | CCM_CCGR3_CG2_SHIFT , kCLOCK_Lpuart6 = (3U << 8U) | CCM_CCGR3_CG3_SHIFT , kCLOCK_Aoi1 = (3U << 8U) | CCM_CCGR3_CG4_SHIFT , kCLOCK_LcdPixel = (3U << 8U) | CCM_CCGR3_CG5_SHIFT , kCLOCK_Gpio4 = (3U << 8U) | CCM_CCGR3_CG6_SHIFT , kCLOCK_Ewm0 = (3U << 8U) | CCM_CCGR3_CG7_SHIFT , kCLOCK_Wdog1 = (3U << 8U) | CCM_CCGR3_CG8_SHIFT , kCLOCK_FlexRam = (3U << 8U) | CCM_CCGR3_CG9_SHIFT , kCLOCK_Acmp1 = (3U << 8U) | CCM_CCGR3_CG10_SHIFT , kCLOCK_Acmp2 = (3U << 8U) | CCM_CCGR3_CG11_SHIFT , kCLOCK_Acmp3 = (3U << 8U) | CCM_CCGR3_CG12_SHIFT , kCLOCK_Acmp4 = (3U << 8U) | CCM_CCGR3_CG13_SHIFT , kCLOCK_Ocram = (3U << 8U) | CCM_CCGR3_CG14_SHIFT , kCLOCK_IomuxcSnvsGpr = (3U << 8U) | CCM_CCGR3_CG15_SHIFT , kCLOCK_Sim_m7_clk_r = (4U << 8U) | CCM_CCGR4_CG0_SHIFT , kCLOCK_Iomuxc = (4U << 8U) | CCM_CCGR4_CG1_SHIFT , kCLOCK_IomuxcGpr = (4U << 8U) | CCM_CCGR4_CG2_SHIFT , kCLOCK_Bee = (4U << 8U) | CCM_CCGR4_CG3_SHIFT , kCLOCK_SimM7 = (4U << 8U) | CCM_CCGR4_CG4_SHIFT , kCLOCK_Tsc = (4U << 8U) | CCM_CCGR4_CG5_SHIFT , kCLOCK_SimM = (4U << 8U) | CCM_CCGR4_CG6_SHIFT , kCLOCK_SimEms = (4U << 8U) | CCM_CCGR4_CG7_SHIFT , kCLOCK_Pwm1 = (4U << 8U) | CCM_CCGR4_CG8_SHIFT , kCLOCK_Pwm2 = (4U << 8U) | CCM_CCGR4_CG9_SHIFT , kCLOCK_Pwm3 = (4U << 8U) | CCM_CCGR4_CG10_SHIFT , kCLOCK_Pwm4 = (4U << 8U) | CCM_CCGR4_CG11_SHIFT , kCLOCK_Enc1 = (4U << 8U) | CCM_CCGR4_CG12_SHIFT , kCLOCK_Enc2 = (4U << 8U) | CCM_CCGR4_CG13_SHIFT , kCLOCK_Enc3 = (4U << 8U) | CCM_CCGR4_CG14_SHIFT , kCLOCK_Enc4 = (4U << 8U) | CCM_CCGR4_CG15_SHIFT , kCLOCK_Rom = (5U << 8U) | CCM_CCGR5_CG0_SHIFT , kCLOCK_Flexio1 = (5U << 8U) | CCM_CCGR5_CG1_SHIFT , kCLOCK_Wdog3 = (5U << 8U) | CCM_CCGR5_CG2_SHIFT , kCLOCK_Dma = (5U << 8U) | CCM_CCGR5_CG3_SHIFT , kCLOCK_Kpp = (5U << 8U) | CCM_CCGR5_CG4_SHIFT , kCLOCK_Wdog2 = (5U << 8U) | CCM_CCGR5_CG5_SHIFT , kCLOCK_Aips_tz4 = (5U << 8U) | CCM_CCGR5_CG6_SHIFT , kCLOCK_Spdif = (5U << 8U) | CCM_CCGR5_CG7_SHIFT , kCLOCK_SimMain = (5U << 8U) | CCM_CCGR5_CG8_SHIFT , kCLOCK_Sai1 = (5U << 8U) | CCM_CCGR5_CG9_SHIFT , kCLOCK_Sai2 = (5U << 8U) | CCM_CCGR5_CG10_SHIFT , kCLOCK_Sai3 = (5U << 8U) | CCM_CCGR5_CG11_SHIFT , kCLOCK_Lpuart1 = (5U << 8U) | CCM_CCGR5_CG12_SHIFT , kCLOCK_Lpuart7 = (5U << 8U) | CCM_CCGR5_CG13_SHIFT , kCLOCK_SnvsHp = (5U << 8U) | CCM_CCGR5_CG14_SHIFT , kCLOCK_SnvsLp = (5U << 8U) | CCM_CCGR5_CG15_SHIFT , kCLOCK_UsbOh3 = (6U << 8U) | CCM_CCGR6_CG0_SHIFT , kCLOCK_Usdhc1 = (6U << 8U) | CCM_CCGR6_CG1_SHIFT , kCLOCK_Usdhc2 = (6U << 8U) | CCM_CCGR6_CG2_SHIFT , kCLOCK_Dcdc = (6U << 8U) | CCM_CCGR6_CG3_SHIFT , kCLOCK_Ipmux4 = (6U << 8U) | CCM_CCGR6_CG4_SHIFT , kCLOCK_FlexSpi = (6U << 8U) | CCM_CCGR6_CG5_SHIFT , kCLOCK_Trng = (6U << 8U) | CCM_CCGR6_CG6_SHIFT , kCLOCK_Lpuart8 = (6U << 8U) | CCM_CCGR6_CG7_SHIFT , kCLOCK_Timer4 = (6U << 8U) | CCM_CCGR6_CG8_SHIFT , kCLOCK_Aips_tz3 = (6U << 8U) | CCM_CCGR6_CG9_SHIFT , kCLOCK_SimPer = (6U << 8U) | CCM_CCGR6_CG10_SHIFT , kCLOCK_Anadig = (6U << 8U) | CCM_CCGR6_CG11_SHIFT , kCLOCK_Lpi2c4 = (6U << 8U) | CCM_CCGR6_CG12_SHIFT , kCLOCK_Timer1 = (6U << 8U) | CCM_CCGR6_CG13_SHIFT , kCLOCK_Timer2 = (6U << 8U) | CCM_CCGR6_CG14_SHIFT , kCLOCK_Timer3 = (6U << 8U) | CCM_CCGR6_CG15_SHIFT } |
| CCM CCGR gate control for each module independently. More... | |
| enum | _clock_osc { kCLOCK_RcOsc = 0U , kCLOCK_XtalOsc = 1U } |
| OSC 24M sorce select. More... | |
| enum | _clock_gate_value { kCLOCK_ClockNotNeeded = 0U , kCLOCK_ClockNeededRun = 1U , kCLOCK_ClockNeededRunWait = 3U } |
| Clock gate value. More... | |
| enum | _clock_mode_t { kCLOCK_ModeRun = 0U , kCLOCK_ModeWait = 1U , kCLOCK_ModeStop = 2U } |
| System clock mode. More... | |
| enum | _clock_mux { kCLOCK_Pll3SwMux , kCLOCK_PeriphMux , kCLOCK_SemcAltMux , kCLOCK_SemcMux , kCLOCK_PrePeriphMux , kCLOCK_TraceMux , kCLOCK_PeriphClk2Mux , kCLOCK_LpspiMux , kCLOCK_FlexspiMux , kCLOCK_Usdhc2Mux , kCLOCK_Usdhc1Mux , kCLOCK_Sai3Mux , kCLOCK_Sai2Mux , kCLOCK_Sai1Mux , kCLOCK_PerclkMux , kCLOCK_Flexio2Mux , kCLOCK_CanMux , kCLOCK_UartMux , kCLOCK_SpdifMux , kCLOCK_Flexio1Mux , kCLOCK_Lpi2cMux , kCLOCK_LcdifPreMux , kCLOCK_CsiMux } |
| MUX control names for clock mux setting. More... | |
| enum | _clock_div { kCLOCK_ArmDiv , kCLOCK_PeriphClk2Div , kCLOCK_SemcDiv , kCLOCK_AhbDiv , kCLOCK_IpgDiv , kCLOCK_LpspiDiv , kCLOCK_LcdifDiv , kCLOCK_FlexspiDiv , kCLOCK_PerclkDiv , kCLOCK_CanDiv , kCLOCK_TraceDiv , kCLOCK_Usdhc2Div , kCLOCK_Usdhc1Div , kCLOCK_UartDiv , kCLOCK_Flexio2Div , kCLOCK_Sai3PreDiv , kCLOCK_Sai3Div , kCLOCK_Flexio2PreDiv , kCLOCK_Sai1PreDiv , kCLOCK_Sai1Div , kCLOCK_Sai2PreDiv , kCLOCK_Sai2Div , kCLOCK_Spdif0PreDiv , kCLOCK_Spdif0Div , kCLOCK_Flexio1PreDiv , kCLOCK_Flexio1Div , kCLOCK_Lpi2cDiv , kCLOCK_LcdifPreDiv , kCLOCK_CsiDiv , kCLOCK_NonePreDiv = CLOCK_ROOT_NONE_PRE_DIV } |
| DIV control names for clock div setting. More... | |
| enum | _clock_div_value { kCLOCK_ArmDivBy1 = 0 , kCLOCK_ArmDivBy2 = 1 , kCLOCK_ArmDivBy3 = 2 , kCLOCK_ArmDivBy4 = 3 , kCLOCK_ArmDivBy5 = 4 , kCLOCK_ArmDivBy6 = 5 , kCLOCK_ArmDivBy7 = 6 , kCLOCK_ArmDivBy8 = 7 , kCLOCK_PeriphClk2DivBy1 = 0 , kCLOCK_PeriphClk2DivBy2 = 1 , kCLOCK_PeriphClk2DivBy3 = 2 , kCLOCK_PeriphClk2DivBy4 = 3 , kCLOCK_PeriphClk2DivBy5 = 4 , kCLOCK_PeriphClk2DivBy6 = 5 , kCLOCK_PeriphClk2DivBy7 = 6 , kCLOCK_PeriphClk2DivBy8 = 7 , kCLOCK_SemcDivBy1 = 0 , kCLOCK_SemcDivBy2 = 1 , kCLOCK_SemcDivBy3 = 2 , kCLOCK_SemcDivBy4 = 3 , kCLOCK_SemcDivBy5 = 4 , kCLOCK_SemcDivBy6 = 5 , kCLOCK_SemcDivBy7 = 6 , kCLOCK_SemcDivBy8 = 7 , kCLOCK_AhbDivBy1 = 0 , kCLOCK_AhbDivBy2 = 1 , kCLOCK_AhbDivBy3 = 2 , kCLOCK_AhbDivBy4 = 3 , kCLOCK_AhbDivBy5 = 4 , kCLOCK_AhbDivBy6 = 5 , kCLOCK_AhbDivBy7 = 6 , kCLOCK_AhbDivBy8 = 7 , kCLOCK_IpgDivBy1 = 0 , kCLOCK_IpgDivBy2 = 1 , kCLOCK_IpgDivBy3 = 2 , kCLOCK_IpgDivBy4 = 3 , kCLOCK_LpspiDivBy1 = 0 , kCLOCK_LpspiDivBy2 = 1 , kCLOCK_LpspiDivBy3 = 2 , kCLOCK_LpspiDivBy4 = 3 , kCLOCK_LpspiDivBy5 = 4 , kCLOCK_LpspiDivBy6 = 5 , kCLOCK_LpspiDivBy7 = 6 , kCLOCK_LpspiDivBy8 = 7 , kCLOCK_LcdifDivBy1 = 0 , kCLOCK_LcdifDivBy2 = 1 , kCLOCK_LcdifDivBy3 = 2 , kCLOCK_LcdifDivBy4 = 3 , kCLOCK_LcdifDivBy5 = 4 , kCLOCK_LcdifDivBy6 = 5 , kCLOCK_LcdifDivBy7 = 6 , kCLOCK_LcdifDivBy8 = 7 , kCLOCK_FlexspiDivBy1 = 0 , kCLOCK_FlexspiDivBy2 = 1 , kCLOCK_FlexspiDivBy3 = 2 , kCLOCK_FlexspiDivBy4 = 3 , kCLOCK_FlexspiDivBy5 = 4 , kCLOCK_FlexspiDivBy6 = 5 , kCLOCK_FlexspiDivBy7 = 6 , kCLOCK_FlexspiDivBy8 = 7 , kCLOCK_TraceDivBy1 = 0 , kCLOCK_TraceDivBy2 = 1 , kCLOCK_TraceDivBy3 = 2 , kCLOCK_TraceDivBy4 = 3 , kCLOCK_Usdhc2DivBy1 = 0 , kCLOCK_Usdhc2DivBy2 = 1 , kCLOCK_Usdhc2DivBy3 = 2 , kCLOCK_Usdhc2DivBy4 = 3 , kCLOCK_Usdhc2DivBy5 = 4 , kCLOCK_Usdhc2DivBy6 = 5 , kCLOCK_Usdhc2DivBy7 = 6 , kCLOCK_Usdhc2DivBy8 = 7 , kCLOCK_Usdhc1DivBy1 = 0 , kCLOCK_Usdhc1DivBy2 = 1 , kCLOCK_Usdhc1DivBy3 = 2 , kCLOCK_Usdhc1DivBy4 = 3 , kCLOCK_Usdhc1DivBy5 = 4 , kCLOCK_Usdhc1DivBy6 = 5 , kCLOCK_Usdhc1DivBy7 = 6 , kCLOCK_Usdhc1DivBy8 = 7 , kCLOCK_Flexio2DivBy1 = 0 , kCLOCK_Flexio2DivBy2 = 1 , kCLOCK_Flexio2DivBy3 = 2 , kCLOCK_Flexio2DivBy4 = 3 , kCLOCK_Flexio2DivBy5 = 4 , kCLOCK_Flexio2DivBy6 = 5 , kCLOCK_Flexio2DivBy7 = 6 , kCLOCK_Flexio2DivBy8 = 7 , kCLOCK_Sai3PreDivBy1 = 0 , kCLOCK_Sai3PreDivBy2 = 1 , kCLOCK_Sai3PreDivBy3 = 2 , kCLOCK_Sai3PreDivBy4 = 3 , kCLOCK_Sai3PreDivBy5 = 4 , kCLOCK_Sai3PreDivBy6 = 5 , kCLOCK_Sai3PreDivBy7 = 6 , kCLOCK_Sai3PreDivBy8 = 7 , kCLOCK_Flexio2PreDivBy1 = 0 , kCLOCK_Flexio2PreDivBy2 = 1 , kCLOCK_Flexio2PreDivBy3 = 2 , kCLOCK_Flexio2PreDivBy4 = 3 , kCLOCK_Flexio2PreDivBy5 = 4 , kCLOCK_Flexio2PreDivBy6 = 5 , kCLOCK_Flexio2PreDivBy7 = 6 , kCLOCK_Flexio2PreDivBy8 = 7 , kCLOCK_Sai1PreDivBy1 = 0 , kCLOCK_Sai1PreDivBy2 = 1 , kCLOCK_Sai1PreDivBy3 = 2 , kCLOCK_Sai1PreDivBy4 = 3 , kCLOCK_Sai1PreDivBy5 = 4 , kCLOCK_Sai1PreDivBy6 = 5 , kCLOCK_Sai1PreDivBy7 = 6 , kCLOCK_Sai1PreDivBy8 = 7 , kCLOCK_Sai2PreDivBy1 = 0 , kCLOCK_Sai2PreDivBy2 = 1 , kCLOCK_Sai2PreDivBy3 = 2 , kCLOCK_Sai2PreDivBy4 = 3 , kCLOCK_Sai2PreDivBy5 = 4 , kCLOCK_Sai2PreDivBy6 = 5 , kCLOCK_Sai2PreDivBy7 = 6 , kCLOCK_Sai2PreDivBy8 = 7 , kCLOCK_Spdif0PreDivBy1 = 0 , kCLOCK_Spdif0PreDivBy2 = 1 , kCLOCK_Spdif0PreDivBy3 = 2 , kCLOCK_Spdif0PreDivBy4 = 3 , kCLOCK_Spdif0PreDivBy5 = 4 , kCLOCK_Spdif0PreDivBy6 = 5 , kCLOCK_Spdif0PreDivBy7 = 6 , kCLOCK_Spdif0PreDivBy8 = 7 , kCLOCK_Spdif0DivBy1 = 0 , kCLOCK_Spdif0DivBy2 = 1 , kCLOCK_Spdif0DivBy3 = 2 , kCLOCK_Spdif0DivBy4 = 3 , kCLOCK_Spdif0DivBy5 = 4 , kCLOCK_Spdif0DivBy6 = 5 , kCLOCK_Spdif0DivBy7 = 6 , kCLOCK_Spdif0DivBy8 = 7 , kCLOCK_Flexio1PreDivBy1 = 0 , kCLOCK_Flexio1PreDivBy2 = 1 , kCLOCK_Flexio1PreDivBy3 = 2 , kCLOCK_Flexio1PreDivBy4 = 3 , kCLOCK_Flexio1PreDivBy5 = 4 , kCLOCK_Flexio1PreDivBy6 = 5 , kCLOCK_Flexio1PreDivBy7 = 6 , kCLOCK_Flexio1PreDivBy8 = 7 , kCLOCK_Flexio1DivBy1 = 0 , kCLOCK_Flexio1DivBy2 = 1 , kCLOCK_Flexio1DivBy3 = 2 , kCLOCK_Flexio1DivBy4 = 3 , kCLOCK_Flexio1DivBy5 = 4 , kCLOCK_Flexio1DivBy6 = 5 , kCLOCK_Flexio1DivBy7 = 6 , kCLOCK_Flexio1DivBy8 = 7 , kCLOCK_LcdifPreDivBy1 = 0 , kCLOCK_LcdifPreDivBy2 = 1 , kCLOCK_LcdifPreDivBy3 = 2 , kCLOCK_LcdifPreDivBy4 = 3 , kCLOCK_LcdifPreDivBy5 = 4 , kCLOCK_LcdifPreDivBy6 = 5 , kCLOCK_LcdifPreDivBy7 = 6 , kCLOCK_LcdifPreDivBy8 = 7 , kCLOCK_CsiDivBy1 = 0 , kCLOCK_CsiDivBy2 = 1 , kCLOCK_CsiDivBy3 = 2 , kCLOCK_CsiDivBy4 = 3 , kCLOCK_CsiDivBy5 = 4 , kCLOCK_CsiDivBy6 = 5 , kCLOCK_CsiDivBy7 = 6 , kCLOCK_CsiDivBy8 = 7 , kCLOCK_MiscDivBy1 = 0 , kCLOCK_MiscDivBy2 = 1 , kCLOCK_MiscDivBy3 = 2 , kCLOCK_MiscDivBy4 = 3 , kCLOCK_MiscDivBy5 = 4 , kCLOCK_MiscDivBy6 = 5 , kCLOCK_MiscDivBy7 = 6 , kCLOCK_MiscDivBy8 = 7 , kCLOCK_MiscDivBy9 = 8 , kCLOCK_MiscDivBy10 = 9 , kCLOCK_MiscDivBy11 = 10 , kCLOCK_MiscDivBy12 = 11 , kCLOCK_MiscDivBy13 = 12 , kCLOCK_MiscDivBy14 = 13 , kCLOCK_MiscDivBy15 = 14 , kCLOCK_MiscDivBy16 = 15 , kCLOCK_MiscDivBy17 = 16 , kCLOCK_MiscDivBy18 = 17 , kCLOCK_MiscDivBy19 = 18 , kCLOCK_MiscDivBy20 = 19 , kCLOCK_MiscDivBy21 = 20 , kCLOCK_MiscDivBy22 = 21 , kCLOCK_MiscDivBy23 = 22 , kCLOCK_MiscDivBy24 = 23 , kCLOCK_MiscDivBy25 = 24 , kCLOCK_MiscDivBy26 = 25 , kCLOCK_MiscDivBy27 = 26 , kCLOCK_MiscDivBy28 = 27 , kCLOCK_MiscDivBy29 = 28 , kCLOCK_MiscDivBy30 = 29 , kCLOCK_MiscDivBy31 = 30 , kCLOCK_MiscDivBy32 = 31 , kCLOCK_MiscDivBy33 = 32 , kCLOCK_MiscDivBy34 = 33 , kCLOCK_MiscDivBy35 = 34 , kCLOCK_MiscDivBy36 = 35 , kCLOCK_MiscDivBy37 = 36 , kCLOCK_MiscDivBy38 = 37 , kCLOCK_MiscDivBy39 = 38 , kCLOCK_MiscDivBy40 = 39 , kCLOCK_MiscDivBy41 = 40 , kCLOCK_MiscDivBy42 = 41 , kCLOCK_MiscDivBy43 = 42 , kCLOCK_MiscDivBy44 = 43 , kCLOCK_MiscDivBy45 = 44 , kCLOCK_MiscDivBy46 = 45 , kCLOCK_MiscDivBy47 = 46 , kCLOCK_MiscDivBy48 = 47 , kCLOCK_MiscDivBy49 = 48 , kCLOCK_MiscDivBy50 = 49 , kCLOCK_MiscDivBy51 = 50 , kCLOCK_MiscDivBy52 = 51 , kCLOCK_MiscDivBy53 = 52 , kCLOCK_MiscDivBy54 = 53 , kCLOCK_MiscDivBy55 = 54 , kCLOCK_MiscDivBy56 = 55 , kCLOCK_MiscDivBy57 = 56 , kCLOCK_MiscDivBy58 = 57 , kCLOCK_MiscDivBy59 = 58 , kCLOCK_MiscDivBy60 = 59 , kCLOCK_MiscDivBy61 = 60 , kCLOCK_MiscDivBy62 = 61 , kCLOCK_MiscDivBy63 = 62 , kCLOCK_MiscDivBy64 = 63 } |
| Clock divider value. More... | |
| enum | _clock_usb_src { kCLOCK_Usb480M = 0 , kCLOCK_UsbSrcUnused = (int)0xFFFFFFFFU } |
| USB clock source definition. More... | |
| enum | _clock_usb_phy_src { kCLOCK_Usbphy480M = 0 } |
| Source of the USB HS PHY. More... | |
| enum | _clock_pll_clk_src { kCLOCK_PllClkSrc24M = 0U , kCLOCK_PllSrcClkPN = 1U } |
| PLL clock source, bypass cloco source also. More... | |
| enum | _clock_pll { kCLOCK_PllArm = CCM_ANALOG_TUPLE(PLL_ARM_OFFSET, CCM_ANALOG_PLL_ARM_ENABLE_SHIFT) , kCLOCK_PllSys = CCM_ANALOG_TUPLE(PLL_SYS_OFFSET, CCM_ANALOG_PLL_SYS_ENABLE_SHIFT) , kCLOCK_PllUsb1 = CCM_ANALOG_TUPLE(PLL_USB1_OFFSET, CCM_ANALOG_PLL_USB1_ENABLE_SHIFT) , kCLOCK_PllAudio = CCM_ANALOG_TUPLE(PLL_AUDIO_OFFSET, CCM_ANALOG_PLL_AUDIO_ENABLE_SHIFT) , kCLOCK_PllVideo = CCM_ANALOG_TUPLE(PLL_VIDEO_OFFSET, CCM_ANALOG_PLL_VIDEO_ENABLE_SHIFT) , kCLOCK_PllEnet = CCM_ANALOG_TUPLE(PLL_ENET_OFFSET, CCM_ANALOG_PLL_ENET_ENABLE_SHIFT) , kCLOCK_PllEnet25M = CCM_ANALOG_TUPLE(PLL_ENET_OFFSET, CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN_SHIFT) , kCLOCK_PllUsb2 = CCM_ANALOG_TUPLE(PLL_USB2_OFFSET, CCM_ANALOG_PLL_USB2_ENABLE_SHIFT) } |
| PLL name. More... | |
| enum | _clock_pfd { kCLOCK_Pfd0 = 0U , kCLOCK_Pfd1 = 1U , kCLOCK_Pfd2 = 2U , kCLOCK_Pfd3 = 3U } |
| PLL PFD name. More... | |
| enum | _clock_output1_selection { kCLOCK_OutputPllUsb1 = 0U , kCLOCK_OutputPllSys = 1U , kCLOCK_OutputPllVideo = 3U , kCLOCK_OutputSemcClk = 5U , kCLOCK_OutputLcdifPixClk = 0xAU , kCLOCK_OutputAhbClk = 0xBU , kCLOCK_OutputIpgClk = 0xCU , kCLOCK_OutputPerClk = 0xDU , kCLOCK_OutputCkilSyncClk = 0xEU , kCLOCK_OutputPll4MainClk = 0xFU , kCLOCK_DisableClockOutput1 = 0x10U } |
| The enumerater of clock output1's clock source, such as USB1 PLL, SYS PLL and so on. More... | |
| enum | _clock_output2_selection { kCLOCK_OutputUsdhc1Clk = 3U , kCLOCK_OutputLpi2cClk = 6U , kCLOCK_OutputCsiClk = 0xBU , kCLOCK_OutputOscClk = 0xEU , kCLOCK_OutputUsdhc2Clk = 0x11U , kCLOCK_OutputSai1Clk = 0x12U , kCLOCK_OutputSai2Clk = 0x13U , kCLOCK_OutputSai3Clk = 0x14U , kCLOCK_OutputCanClk = 0x17U , kCLOCK_OutputFlexspiClk = 0x1BU , kCLOCK_OutputUartClk = 0x1CU , kCLOCK_OutputSpdif0Clk = 0x1DU , kCLOCK_DisableClockOutput2 = 0x1FU } |
| The enumerater of clock output2's clock source, such as USDHC1 clock root, LPI2C clock root and so on. More... | |
| enum | _clock_output_divider { kCLOCK_DivideBy1 = 0U , kCLOCK_DivideBy2 , kCLOCK_DivideBy3 , kCLOCK_DivideBy4 , kCLOCK_DivideBy5 , kCLOCK_DivideBy6 , kCLOCK_DivideBy7 , kCLOCK_DivideBy8 } |
| The enumerator of clock output's divider. More... | |
| enum | _clock_root { kCLOCK_Usdhc1ClkRoot = 0U , kCLOCK_Usdhc2ClkRoot , kCLOCK_FlexspiClkRoot , kCLOCK_CsiClkRoot , kCLOCK_LpspiClkRoot , kCLOCK_TraceClkRoot , kCLOCK_Sai1ClkRoot , kCLOCK_Sai2ClkRoot , kCLOCK_Sai3ClkRoot , kCLOCK_Lpi2cClkRoot , kCLOCK_CanClkRoot , kCLOCK_UartClkRoot , kCLOCK_LcdifClkRoot , kCLOCK_SpdifClkRoot , kCLOCK_Flexio1ClkRoot , kCLOCK_Flexio2ClkRoot } |
| The enumerator of clock root. More... | |
| typedef enum _clock_name | clock_name_t |
| Clock name used to get clock frequency. | |
| typedef enum _clock_ip_name | clock_ip_name_t |
| CCM CCGR gate control for each module independently. | |
| typedef enum _clock_osc | clock_osc_t |
| OSC 24M sorce select. | |
| typedef enum _clock_gate_value | clock_gate_value_t |
| Clock gate value. | |
| typedef enum _clock_mode_t | clock_mode_t |
| System clock mode. | |
| typedef enum _clock_mux | clock_mux_t |
| MUX control names for clock mux setting. | |
| typedef enum _clock_div | clock_div_t |
| DIV control names for clock div setting. | |
| typedef enum _clock_div_value | clock_div_value_t |
| Clock divider value. | |
| typedef enum _clock_usb_src | clock_usb_src_t |
| USB clock source definition. | |
| typedef enum _clock_usb_phy_src | clock_usb_phy_src_t |
| Source of the USB HS PHY. | |
| typedef struct _clock_arm_pll_config | clock_arm_pll_config_t |
| PLL configuration for ARM. | |
| typedef struct _clock_usb_pll_config | clock_usb_pll_config_t |
| PLL configuration for USB. | |
| typedef struct _clock_sys_pll_config | clock_sys_pll_config_t |
| PLL configuration for System. | |
| typedef struct _clock_audio_pll_config | clock_audio_pll_config_t |
| PLL configuration for AUDIO and VIDEO. | |
| typedef struct _clock_video_pll_config | clock_video_pll_config_t |
| typedef struct _clock_enet_pll_config | clock_enet_pll_config_t |
| PLL configuration for ENET. | |
| typedef enum _clock_pll | clock_pll_t |
| PLL name. | |
| typedef enum _clock_pfd | clock_pfd_t |
| PLL PFD name. | |
| typedef enum _clock_output1_selection | clock_output1_selection_t |
| The enumerater of clock output1's clock source, such as USB1 PLL, SYS PLL and so on. | |
| typedef enum _clock_output2_selection | clock_output2_selection_t |
| The enumerater of clock output2's clock source, such as USDHC1 clock root, LPI2C clock root and so on. | |
| typedef enum _clock_output_divider | clock_output_divider_t |
| The enumerator of clock output's divider. | |
| typedef enum _clock_root | clock_root_t |
| The enumerator of clock root. | |
| volatile uint32_t | g_xtalFreq |
| External XTAL (24M OSC/SYSOSC) clock frequency. | |
| volatile uint32_t | g_rtcXtalFreq |
| External RTC XTAL (32K OSC) clock frequency. | |
| uint32_t | CLOCK_GetAhbFreq (void) |
| Gets the AHB clock frequency. | |
| uint32_t | CLOCK_GetSemcFreq (void) |
| Gets the SEMC clock frequency. | |
| uint32_t | CLOCK_GetIpgFreq (void) |
| Gets the IPG clock frequency. | |
| uint32_t | CLOCK_GetPerClkFreq (void) |
| Gets the PER clock frequency. | |
| uint32_t | CLOCK_GetFreq (clock_name_t name) |
| Gets the clock frequency for a specific clock name. | |
| uint32_t | CLOCK_GetClockRootFreq (clock_root_t clockRoot) |
| Gets the frequency of selected clock root. | |
| #define | CCM_ANALOG_PLL_BYPASS_SHIFT (16U) |
| #define | CCM_ANALOG_PLL_BYPASS_CLK_SRC_MASK (0xC000U) |
| #define | CCM_ANALOG_PLL_BYPASS_CLK_SRC_SHIFT (14U) |
| #define | PLL_ARM_OFFSET 0x00 |
| CCM Analog registers offset. | |
| #define | CCM_NO_BUSY_WAIT (0x20U) |
| #define | CLKPN_FREQ 0U |
| clock1PN frequency. | |
| #define | CLOCK_SetXtal0Freq CLOCK_SetXtalFreq |
| #define | CLOCK_SetXtal32Freq CLOCK_SetRtcXtalFreq |
| #define | ADC_CLOCKS |
| Clock ip name array for ADC. | |
| #define | BEE_CLOCKS |
| Clock ip name array for BEE. | |
| #define | DCP_CLOCKS |
| Clock ip name array for DCP. | |
| #define | FLEXCAN_PERIPH_CLOCKS |
| Clock ip name array for FLEXCAN Peripheral clock. | |
| #define | FLEXSPI_EXSC_CLOCKS |
| Clock ip name array for FLEXSPI EXSC. | |
| #define | LCDIF_PERIPH_CLOCKS |
| Clock ip name array for LCDIF PIXEL. | |
| #define | OCRAM_EXSC_CLOCKS |
| Clock ip name array for OCRAM EXSC. | |
| #define | RTWDOG_CLOCKS |
| Clock ip name array for RTWDOG. | |
| #define | SEMC_EXSC_CLOCKS |
| Clock ip name array for SEMC EXSC. | |
| #define | TRNG_CLOCKS |
| Clock ip name array for TRNG. | |
| #define | TSC_CLOCKS |
| Clock ip name array for TSC. | |
| #define | CLOCK_SOURCE_NONE (0xFFU) |
| #define | CLOCK_ROOT_SOUCE |
| #define | CLOCK_ROOT_MUX_TUPLE |
| #define | CLOCK_ROOT_NONE_PRE_DIV 0UL |
| #define | CLOCK_ROOT_DIV_TUPLE |
| #define | kCLOCK_CoreSysClk kCLOCK_CpuClk |
OSC operations | |
| void | CLOCK_InitExternalClk (bool bypassXtalOsc) |
| Initialize the external 24MHz clock. | |
| void | CLOCK_DeinitExternalClk (void) |
| Deinitialize the external 24MHz clock. | |
| void | CLOCK_SwitchOsc (clock_osc_t osc) |
| Switch the OSC. | |
| void | CLOCK_InitRcOsc24M (void) |
| Initialize the RC oscillator 24MHz clock. | |
| void | CLOCK_DeinitRcOsc24M (void) |
| Power down the RCOSC 24M clock. | |
| bool | CLOCK_EnableUsbhs0Clock (clock_usb_src_t src, uint32_t freq) |
| Enable USB HS clock. | |
| bool | CLOCK_EnableUsbhs1Clock (clock_usb_src_t src, uint32_t freq) |
PLL/PFD operations | |
| void | CLOCK_InitArmPll (const clock_arm_pll_config_t *config) |
| Initialize the ARM PLL. | |
| void | CLOCK_DeinitArmPll (void) |
| De-initialize the ARM PLL. | |
| void | CLOCK_InitSysPll (const clock_sys_pll_config_t *config) |
| Initialize the System PLL. | |
| void | CLOCK_DeinitSysPll (void) |
| De-initialize the System PLL. | |
| void | CLOCK_InitUsb1Pll (const clock_usb_pll_config_t *config) |
| Initialize the USB1 PLL. | |
| void | CLOCK_DeinitUsb1Pll (void) |
| Deinitialize the USB1 PLL. | |
| void | CLOCK_InitUsb2Pll (const clock_usb_pll_config_t *config) |
| Initialize the USB2 PLL. | |
| void | CLOCK_DeinitUsb2Pll (void) |
| Deinitialize the USB2 PLL. | |
| void | CLOCK_InitAudioPll (const clock_audio_pll_config_t *config) |
| Initializes the Audio PLL. | |
| void | CLOCK_DeinitAudioPll (void) |
| De-initialize the Audio PLL. | |
| void | CLOCK_InitVideoPll (const clock_video_pll_config_t *config) |
| Initialize the video PLL. | |
| void | CLOCK_DeinitVideoPll (void) |
| De-initialize the Video PLL. | |
| void | CLOCK_InitEnetPll (const clock_enet_pll_config_t *config) |
| Initialize the ENET PLL. | |
| void | CLOCK_DeinitEnetPll (void) |
| Deinitialize the ENET PLL. | |
| uint32_t | CLOCK_GetPllFreq (clock_pll_t pll) |
| Get current PLL output frequency. | |
| void | CLOCK_InitSysPfd (clock_pfd_t pfd, uint8_t pfdFrac) |
| Initialize the System PLL PFD. | |
| void | CLOCK_DeinitSysPfd (clock_pfd_t pfd) |
| De-initialize the System PLL PFD. | |
| bool | CLOCK_IsSysPfdEnabled (clock_pfd_t pfd) |
| Check if Sys PFD is enabled. | |
| void | CLOCK_InitUsb1Pfd (clock_pfd_t pfd, uint8_t pfdFrac) |
| Initialize the USB1 PLL PFD. | |
| void | CLOCK_DeinitUsb1Pfd (clock_pfd_t pfd) |
| De-initialize the USB1 PLL PFD. | |
| bool | CLOCK_IsUsb1PfdEnabled (clock_pfd_t pfd) |
| Check if Usb1 PFD is enabled. | |
| uint32_t | CLOCK_GetSysPfdFreq (clock_pfd_t pfd) |
| Get current System PLL PFD output frequency. | |
| uint32_t | CLOCK_GetUsb1PfdFreq (clock_pfd_t pfd) |
| Get current USB1 PLL PFD output frequency. | |
| bool | CLOCK_EnableUsbhs0PhyPllClock (clock_usb_phy_src_t src, uint32_t freq) |
| Enable USB HS PHY PLL clock. | |
| void | CLOCK_DisableUsbhs0PhyPllClock (void) |
| Disable USB HS PHY PLL clock. | |
| bool | CLOCK_EnableUsbhs1PhyPllClock (clock_usb_phy_src_t src, uint32_t freq) |
| void | CLOCK_DisableUsbhs1PhyPllClock (void) |
Clock Output Inferfaces | |
| void | CLOCK_SetClockOutput1 (clock_output1_selection_t selection, clock_output_divider_t divider) |
| Set the clock source and the divider of the clock output1. | |
| void | CLOCK_SetClockOutput2 (clock_output2_selection_t selection, clock_output_divider_t divider) |
| Set the clock source and the divider of the clock output2. | |
| uint32_t | CLOCK_GetClockOutCLKO1Freq (void) |
| Get the frequency of clock output1 clock signal. | |
| uint32_t | CLOCK_GetClockOutClkO2Freq (void) |
| Get the frequency of clock output2 clock signal. | |
OSC operations | |
| void | CLOCK_OSC_EnableOsc24M (void) |
| Enable OSC 24Mhz. | |
| void | CLOCK_OSC_SetOsc24MWorkMode (clock_24MOsc_mode_t workMode) |
| Set the work mode of 24MHz crystal oscillator, the available modes are high gian mode, low power mode, and bypass mode. | |
| void | CLOCK_OSC_EnableOscRc400M (void) |
| Enable OSC RC 400Mhz. | |
| void | CLOCK_OSC_TrimOscRc400M (bool enable, bool bypass, uint16_t trim) |
| Trims OSC RC 400MHz. | |
| void | CLOCK_OSC_SetOscRc400MRefClkDiv (uint8_t divValue) |
| Set the divide value for ref_clk to generate slow clock. | |
| void | CLOCK_OSC_SetOscRc400MFastClkCount (uint16_t targetCount) |
| Set the target count for the fast clock. | |
| void | CLOCK_OSC_SetOscRc400MHysteresisValue (uint8_t negHysteresis, uint8_t posHysteresis) |
| Set the negative and positive hysteresis value for the tuned clock. | |
| void | CLOCK_OSC_BypassOscRc400MTuneLogic (bool enableBypass) |
| Bypass/un-bypass the tune logic. | |
| void | CLOCK_OSC_EnableOscRc400MTuneLogic (bool enable) |
| Start/Stop the tune logic. | |
| void | CLOCK_OSC_FreezeOscRc400MTuneValue (bool enableFreeze) |
| Freeze/Unfreeze the tuning value. | |
| void | CLOCK_OSC_SetOscRc400MTuneValue (uint8_t tuneValue) |
| Set the 400MHz RC oscillator tune value when the tune logic is disabled. | |
| void | CLOCK_OSC_Set1MHzOutputBehavior (clock_1MHzOut_behavior_t behavior) |
| Set the behavior of the 1MHz output clock, such as disable the 1MHz clock output, enable the free-running 1MHz clock output, enable the locked 1MHz clock output. | |
| void | CLOCK_OSC_SetLocked1MHzCount (uint16_t count) |
| Set the count for the locked 1MHz clock out. | |
| bool | CLOCK_OSC_CheckLocked1MHzErrorFlag (void) |
| Check the error flag for locked 1MHz clock out. | |
| void | CLOCK_OSC_ClearLocked1MHzErrorFlag (void) |
| Clear the error flag for locked 1MHz clock out. | |
| uint16_t | CLOCK_OSC_GetCurrentOscRc400MFastClockCount (void) |
| Get current count for the fast clock during the tune process. | |
| uint8_t | CLOCK_OSC_GetCurrentOscRc400MTuneValue (void) |
| Get current tune value used by oscillator during tune process. | |
| void | CLOCK_OSC_SetOsc16MConfig (clock_16MOsc_source_t source, bool enablePowerSave, bool enableClockOut) |
| Configure the 16MHz oscillator. | |
| status_t | CLOCK_CalcArmPllFreq (clock_arm_pll_config_t *config, uint32_t freqInMhz) |
| Calculate corresponding config values per given frequency. | |
| status_t | CLOCK_InitArmPllWithFreq (uint32_t freqInMhz) |
| Initializes the Arm PLL with Specific Frequency (in Mhz). | |
| void | CLOCK_CalcPllSpreadSpectrum (uint32_t factor, uint32_t range, uint32_t mod, clock_pll_ss_config_t *ss) |
| Calculate spread spectrum step and stop. | |
| void | CLOCK_InitSysPll1 (const clock_sys_pll1_config_t *config) |
| Initialize the System PLL1. | |
| void | CLOCK_DeinitSysPll1 (void) |
| De-initialize the System PLL1. | |
| void | CLOCK_GPC_SetSysPll1OutputFreq (const clock_sys_pll1_gpc_config_t *config) |
| Set System PLL1 output frequency in GPC mode. | |
| void | CLOCK_InitSysPll2 (const clock_sys_pll2_config_t *config) |
| Initialize the System PLL2. | |
| void | CLOCK_DeinitSysPll2 (void) |
| De-initialize the System PLL2. | |
| bool | CLOCK_IsSysPll2PfdEnabled (clock_pfd_t pfd) |
| Check if Sys PLL2 PFD is enabled. | |
| void | CLOCK_InitSysPll3 (void) |
| Initialize the System PLL3. | |
| void | CLOCK_DeinitSysPll3 (void) |
| De-initialize the System PLL3. | |
| bool | CLOCK_IsSysPll3PfdEnabled (clock_pfd_t pfd) |
| Check if Sys PLL3 PFD is enabled. | |
| void | CLOCK_SetPllBypass (clock_pll_t pll, bool bypass) |
| PLL bypass setting. | |
| status_t | CLOCK_CalcAvPllFreq (clock_av_pll_config_t *config, uint32_t freqInMhz) |
| status_t | CLOCK_InitAudioPllWithFreq (uint32_t freqInMhz, bool ssEnable, uint32_t ssRange, uint32_t ssMod) |
| Initializes the Audio PLL with Specific Frequency (in Mhz). | |
| void | CLOCK_GPC_SetAudioPllOutputFreq (const clock_audio_pll_gpc_config_t *config) |
| Set Audio PLL output frequency in GPC mode. | |
| status_t | CLOCK_InitVideoPllWithFreq (uint32_t freqInMhz, bool ssEnable, uint32_t ssRange, uint32_t ssMod) |
| Initializes the Video PLL with Specific Frequency (in Mhz). | |
| void | CLOCK_GPC_SetVideoPllOutputFreq (const clock_video_pll_gpc_config_t *config) |
| Set Video PLL output frequency in GPC mode. | |
| void | CLOCK_InitPfd (clock_pll_t pll, clock_pfd_t pfd, uint8_t frac) |
| Initialize PLL PFD. | |
| void | CLOCK_DeinitPfd (clock_pll_t pll, clock_pfd_t pfd) |
| De-initialize selected PLL PFD. | |
| uint32_t | CLOCK_GetPfdFreq (clock_pll_t pll, clock_pfd_t pfd) |
| Get current PFD output frequency. | |
| uint32_t | CLOCK_GetFreqFromObs (uint32_t obsSigIndex, uint32_t obsIndex) |
| void | CLOCK_OSCPLL_ControlBySetPointMode (clock_name_t name, uint16_t spValue, uint16_t stbyValue) |
| Set this clock works in SetPoint control Mode. | |
| void | CLOCK_OSCPLL_ControlByCpuLowPowerMode (clock_name_t name, uint8_t domainId, clock_level_t level0, clock_level_t level1) |
| Set this clock works in CPU Low Power Mode. | |
| void | CLOCK_ROOT_ControlBySetPointMode (clock_root_t name, const clock_root_setpoint_config_t *spTable) |
| Set this clock works in SetPoint controlled Mode. | |
| void | CLOCK_LPCG_ControlBySetPointMode (clock_lpcg_t name, uint16_t spValue, uint16_t stbyValue) |
| void | CLOCK_LPCG_ControlByCpuLowPowerMode (clock_lpcg_t name, uint8_t domainId, clock_level_t level0, clock_level_t level1) |
| #define ADC_CLOCKS |
| #define ADC_ETC_CLOCKS |
Clock gate name array for ADC.
| #define AOI_CLOCKS |
Clock ip name array for AOI.
Clock gate name array for AOI.
| #define ASRC_CLOCKS |
Clock ip name array for ASRC.
| #define BEE_CLOCKS |
| #define CAAM_CLOCKS |
Clock ip name array for CAAM.
| #define CCM_ANALOG_TUPLE | ( | reg, | |
| shift ) |
CCM ANALOG tuple macros to map corresponding registers and bit fields.
| shift ) |
| #define CCM_ANALOG_TUPLE_REG | ( | base, | |
| tuple ) |
| tuple ) |
| #define CCM_ANALOG_TUPLE_REG_OFF | ( | base, | |
| tuple, | |||
| off ) |
| tuple, | |||
| off ) |
| #define CCM_ANALOG_TUPLE_SHIFT | ( | tuple | ) |
| #define CCM_TUPLE | ( | reg, | |
| shift, | |||
| mask, | |||
| busyShift ) |
| shift, | |||
| mask, | |||
| busyShift ) |
| #define CCM_TUPLE_BUSY_SHIFT | ( | tuple | ) |
| #define CCM_TUPLE_MASK | ( | tuple | ) |
| #define CCM_TUPLE_REG | ( | base, | |
| tuple ) |
| tuple ) |
| #define CCM_TUPLE_SHIFT | ( | tuple | ) |
| #define CDOG_CLOCKS |
Clock ip name array for CDOG.
| #define CLOCK_GetCoreSysClkFreq CLOCK_GetCpuClkFreq |
For compatible with other platforms without CCM.
| #define CLOCK_GetCpuClkFreq | ( | void | ) |
| #define CLOCK_ROOT_DIV_TUPLE |
| #define CLOCK_ROOT_MUX_TUPLE |
| #define CMP_CLOCKS |
Clock ip name array for CMP.
| #define CSI_CLOCKS |
Clock ip name array for CSI.
| #define DAC_CLOCKS |
Clock ip name array for DAC.
| #define DCDC_CLOCKS |
Clock ip name array for DCDC.
Clock gate name array for DCDC.
| #define DCIC_CLOCKS |
Clock ip name array for DCIC.
| #define DCP_CLOCKS |
| #define DMAMUX_CLOCKS |
Clock ip name array for DMAMUX_CLOCKS.
| #define EDMA_CLOCKS |
Clock gate name array for EDMA.
| #define EMVSIM_CLOCKS |
Clock ip name array for EMVSIM.
| #define ENC_CLOCKS |
Clock ip name array for ENC.
| #define ENET_CLOCKS |
Clock ip name array for ENET.
| #define EWM_CLOCKS |
Clock ip name array for EWM.
Clock gate name array for EWM.
| #define FLEXCAN_CLOCKS |
Clock ip name array for FLEXCAN.
| #define FLEXCAN_PERIPH_CLOCKS |
| #define FLEXIO_CLOCKS |
Clock ip name array for FLEXIO.
| #define FLEXRAM_CLOCKS |
Clock ip name array for FLEXRAM.
Clock gate name array for FLEXRAM.
| #define FLEXSPI_CLOCKS |
Clock ip name array for FLEXSPI.
Clock gate name array for FLEXSPI.
| #define FLEXSPI_EXSC_CLOCKS |
| #define FSL_CLOCK_DRIVER_VERSION (MAKE_VERSION(2, 5, 1)) |
CLOCK driver version 2.5.1.
CLOCK driver version.
| #define FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL 0 |
When set to 0, peripheral drivers will enable clock in initialize function and disable clock in de-initialize function. When set to 1, peripheral driver will not control the clock, application could control the clock out of the driver.
| #define GPC_CLOCKS |
Clock gate name array for GPC.
| #define GPIO_CLOCKS |
Clock ip name array for GPIO.
| #define GPT_CLOCKS |
Clock ip name array for GPT.
| #define GPU2D_CLOCKS |
Clock ip name array for GPU2d.
| #define IEE_CLOCKS |
Clock ip name array for IEE.
| #define IOMUXC_CLOCKS |
Clock ip name array for IOMUXC.
| #define kCLOCK_CoreSysClk kCLOCK_CpuClk |
| #define KEYMANAGER_CLOCKS |
Clock ip name array for KEY_MANAGER.
| #define KPP_CLOCKS |
Clock ip name array for KPP.
| #define LCDIF_CLOCKS |
Clock ip name array for LCDIF.
| #define LCDIF_PERIPH_CLOCKS |
| #define LCDIFV2_CLOCKS |
Clock ip name array for LCDIFV2.
| #define LMEM_CLOCKS |
Clock gate name array for LMEM.
| #define LPADC_CLOCKS |
| #define LPI2C_CLOCKS |
Clock ip name array for LPI2C.
| #define LPSPI_CLOCKS |
Clock ip name array for LPSPI.
| #define LPUART_CLOCKS |
Clock ip name array for LPUART.
| #define MIPI_CSI2RX_CLOCKS |
Clock ip name array for MIPI_CSI.
| #define MIPI_DSI_HOST_CLOCKS |
Clock ip name array for MIPI_DSI.
| #define MQS_CLOCKS |
Clock ip name array for MQS.
| #define MU_CLOCKS |
Clock gate name array for MU.
| #define OCOTP_CLOCKS |
Clock ip name array for OCOTP.
| #define OCRAM_EXSC_CLOCKS |
| #define PDM_CLOCKS |
Clock ip name array for PDM.
| #define PIT_CLOCKS |
Clock ip name array for PIT.
| #define PUF_CLOCKS |
Clock ip name array for PUF.
| #define PWM_CLOCKS |
Clock ip name array for PWM.
| #define PXP_CLOCKS |
Clock ip name array for PXP.
| #define RDC_CLOCKS |
Clock gate name array for RDC.
| #define RTWDOG_CLOCKS |
| #define SAI_CLOCKS |
Clock ip name array for SAI.
| #define SEMA_CLOCKS |
Clock gate name array for Sema.
| #define SEMC_CLOCKS |
Clock ip name array for SEMC.
| #define SEMC_EXSC_CLOCKS |
| #define SPDIF_CLOCKS |
Clock ip name array for SPDIF.
| #define SRC_CLOCKS |
Clock gate name array for SRC.
| #define SSARC_CLOCKS |
Clock gate name array for SSARC.
| #define TMR_CLOCKS |
Clock ip name array for QTIMER.
| #define TRNG_CLOCKS |
| #define TSC_CLOCKS |
| #define USB_CLOCKS |
Clock ip name array for USB.
| #define USDHC_CLOCKS |
Clock ip name array for USDHC.
| #define WDOG_CLOCKS |
Clock ip name array for WDOG.
Clock gate name array for WDOG.
| #define XBAR_CLOCKS |
Clock ip name array for XBAR.
| #define XBARA_CLOCKS |
Clock ip name array for XBARA.
| #define XBARB_CLOCKS |
Clock ip name array for XBARB.
| #define XECC_CLOCKS |
Clock ip name array for XECC.
| typedef struct _clock_arm_pll_config clock_arm_pll_config_t |
The output clock frequency is:
Fout=Fin*loopDivider /(2 * postDivider).
Fin is always 24MHz.
| typedef enum _clock_div clock_div_t |
These constants define div control names for clock div setting.
| typedef enum _clock_mux clock_mux_t |
These constants define the mux control names for clock mux setting.
| enum _clock_16MOsc_source |
The enumeration of 1MHz output clock behavior, including disabling 1MHz output, enabling locked 1MHz clock output, and enabling free-running 1MHz clock output.
| enum _clock_24MOsc_mode |
| enum _clock_control_mode |
| enum _clock_div |
| enum _clock_group |
| enum _clock_level |
| enum _clock_lpcg |
Clock LPCG index.
| enum _clock_mux |
| enum _clock_name |
| enum _clock_name |
Clock name.
| enum _clock_osc |
| enum _clock_osc |
| enum _clock_pfd |
| enum _clock_pfd |
| enum _clock_pll |
| enum _clock_pll |
PLL name.
| enum _clock_pll_clk_src |
| enum _clock_pll_post_div |
| enum _clock_root |
| enum _clock_root |
Root clock index.
The enumerator of clock roots' clock source mux value.
| status_t CLOCK_CalcArmPllFreq | ( | clock_arm_pll_config_t * | config, |
| uint32_t | freqInMhz ) |
This function calculates config valudes per given frequency for Arm PLL
| config | pll config structure |
| freqInMhz | target frequency |
| status_t CLOCK_CalcAvPllFreq | ( | clock_av_pll_config_t * | config, |
This function calculates config valudes per given frequency for Audio/Video PLL.
| void CLOCK_CalcPllSpreadSpectrum | ( | uint32_t | factor, |
| uint32_t | range, | ||
| uint32_t | mod, | ||
| clock_pll_ss_config_t * | ss ) |
This function calculate spread spectrum step and stop according to given parameters. For integer PLL (syspll2) the factor is mfd, while for other fractional PLLs (audio/video/syspll1), the factor is denominator.
| factor | factor to calculate step/stop |
| range | spread spectrum range |
| mod | spread spectrum modulation frequency |
| ss | calculated spread spectrum values |
| void CLOCK_DeinitArmPll | ( | void | ) |
brief De-initialize the ARM PLL.
| void CLOCK_DeinitAudioPll | ( | void | ) |
brief De-initialize the Audio PLL.
| void CLOCK_DeinitEnetPll | ( | void | ) |
This function disables the ENET PLL.
brief Deinitialize the ENET PLL.
| void CLOCK_DeinitExternalClk | ( | void | ) |
This function disables the external 24MHz clock.
After this function, please call CLOCK_SetXtal0Freq to set external clock frequency to 0.
brief Deinitialize the external 24MHz clock.
After this function, please call ref CLOCK_SetXtal0Freq to set external clock frequency to 0.
| void CLOCK_DeinitPfd | ( | clock_pll_t | pll, |
| clock_pfd_t | pfd ) |
| pll | Which PLL of targeting PFD to be operated. |
| pfd | Which PFD clock to enable. |
brief De-initialize selected PLL PFD.
param pll Which PLL of targeting PFD to be operated. param pfd Which PFD clock to enable.
| void CLOCK_DeinitRcOsc24M | ( | void | ) |
brief Power down the RCOSC 24M clock.
| void CLOCK_DeinitSysPfd | ( | clock_pfd_t | pfd | ) |
This function disables the System PLL PFD.
| pfd | Which PFD clock to disable. |
brief De-initialize the System PLL PFD.
param pfd Which PFD clock to disable.
| void CLOCK_DeinitSysPll | ( | void | ) |
brief De-initialize the System PLL.
| void CLOCK_DeinitUsb1Pfd | ( | clock_pfd_t | pfd | ) |
This function disables the USB1 PLL PFD.
brief De-initialize the USB1 PLL PFD.
| void CLOCK_DeinitUsb1Pll | ( | void | ) |
brief Deinitialize the USB1 PLL.
| void CLOCK_DeinitUsb2Pll | ( | void | ) |
brief Deinitialize the USB2 PLL.
| void CLOCK_DeinitVideoPll | ( | void | ) |
brief De-initialize the Video PLL.
| void CLOCK_DisableUsbhs0PhyPllClock | ( | void | ) |
This function disables USB HS PHY PLL clock.
brief Disable USB HS PHY PLL clock.
| void CLOCK_DisableUsbhs1PhyPllClock | ( | void | ) |
| bool CLOCK_EnableUsbhs0Clock | ( | clock_usb_src_t | src, |
| uint32_t | freq ) |
This function only enables the access to USB HS prepheral, upper layer should first call the CLOCK_EnableUsbhs0PhyPllClock to enable the PHY clock to use USB HS.
| src | USB HS does not care about the clock source, here must be kCLOCK_UsbSrcUnused. |
| freq | USB HS does not care about the clock source, so this parameter is ignored. |
| true | The clock is set successfully. |
| false | The clock source is invalid to get proper USB HS clock. |
brief Enable USB HS clock.
This function only enables the access to USB HS prepheral, upper layer should first call the ref CLOCK_EnableUsbhs0PhyPllClock to enable the PHY clock to use USB HS.
param src USB HS does not care about the clock source, here must be ref kCLOCK_UsbSrcUnused. param freq USB HS does not care about the clock source, so this parameter is ignored. retval true The clock is set successfully. retval false The clock source is invalid to get proper USB HS clock.
| bool CLOCK_EnableUsbhs0PhyPllClock | ( | clock_usb_phy_src_t | src, |
| uint32_t | freq ) |
This function enables the internal 480MHz USB PHY PLL clock.
| src | USB HS PHY PLL clock source. |
| freq | The frequency specified by src. |
brief Enable USB HS PHY PLL clock.
param src USB HS PHY PLL clock source. param freq The frequency specified by src. retval true The clock is set successfully. retval false The clock source is invalid to get proper USB HS clock.
| bool CLOCK_EnableUsbhs1Clock | ( | clock_usb_src_t | src, |
| uint32_t | freq ) |
| bool CLOCK_EnableUsbhs1PhyPllClock | ( | clock_usb_phy_src_t | src, |
| uint32_t | freq ) |
| uint32_t CLOCK_GetAhbFreq | ( | void | ) |
brief Gets the AHB clock frequency.
return The AHB clock frequency value in hertz.
| uint32_t CLOCK_GetClockOutCLKO1Freq | ( | void | ) |
brief Get the frequency of clock output1 clock signal.
return The frequency of clock output1 clock signal.
| uint32_t CLOCK_GetClockOutClkO2Freq | ( | void | ) |
brief Get the frequency of clock output2 clock signal.
return The frequency of clock output2 clock signal.
| uint32_t CLOCK_GetClockRootFreq | ( | clock_root_t | clockRoot | ) |
| clockRoot | The clock root used to get the frequency, please refer to clock_root_t. |
brief Gets the frequency of selected clock root.
param clockRoot The clock root used to get the frequency, please refer to clock_root_t. return The frequency of selected clock root.
| uint32_t CLOCK_GetFreq | ( | clock_name_t | name | ) |
This function checks the current clock configurations and then calculates the clock frequency for a specific clock name defined in clock_name_t.
| name | Clock names defined in clock_name_t |
brief Gets the clock frequency for a specific clock name.
param clockName Clock names defined in clock_name_t return Clock frequency value in hertz
| uint32_t CLOCK_GetIpgFreq | ( | void | ) |
brief Gets the IPG clock frequency.
return The IPG clock frequency value in hertz.
| uint32_t CLOCK_GetPerClkFreq | ( | void | ) |
brief Gets the PER clock frequency.
return The PER clock frequency value in hertz.
| uint32_t CLOCK_GetPfdFreq | ( | clock_pll_t | pll, |
This function get current output frequency of specific System PLL PFD
| pfd | pfd name to get frequency. |
| uint32_t CLOCK_GetPllFreq | ( | clock_pll_t | pll | ) |
This function get current output frequency of specific PLL
| pll | pll name to get frequency. |
brief Get current PLL output frequency.
param pll pll name to get frequency. return The PLL output frequency in hertz.
| uint32_t CLOCK_GetSemcFreq | ( | void | ) |
brief Gets the SEMC clock frequency.
return The SEMC clock frequency value in hertz.
| uint32_t CLOCK_GetSysPfdFreq | ( | clock_pfd_t | pfd | ) |
brief Get current System PLL PFD output frequency.
param pfd pfd name to get frequency. return The PFD output frequency in hertz.
| uint32_t CLOCK_GetUsb1PfdFreq | ( | clock_pfd_t | pfd | ) |
This function get current output frequency of specific USB1 PLL PFD
brief Get current USB1 PLL PFD output frequency.
| void CLOCK_GPC_SetAudioPllOutputFreq | ( | const clock_audio_pll_gpc_config_t * | config | ) |
| config | Pointer to clock_audio_pll_gpc_config_t structure. |
| void CLOCK_GPC_SetSysPll1OutputFreq | ( | const clock_sys_pll1_gpc_config_t * | config | ) |
| config | Pointer to clock_sys_pll1_gpc_config_t. |
| void CLOCK_GPC_SetVideoPllOutputFreq | ( | const clock_video_pll_gpc_config_t * | config | ) |
| void CLOCK_InitArmPll | ( | const clock_arm_pll_config_t * | config | ) |
This function initialize the ARM PLL with specific settings
| config | configuration to set to PLL. |
brief Initialize the ARM PLL.
param config configuration to set to PLL.
| status_t CLOCK_InitArmPllWithFreq | ( | uint32_t | freqInMhz | ) |
This function initializes the Arm PLL with specific frequency
| void CLOCK_InitAudioPll | ( | const clock_audio_pll_config_t * | config | ) |
This function initializes the Audio PLL with specific settings
| config | Configuration to set to PLL. |
brief Initializes the Audio PLL.
param config Configuration to set to PLL.
| status_t CLOCK_InitAudioPllWithFreq | ( | uint32_t | freqInMhz, |
| bool | ssEnable, | ||
| uint32_t | ssRange, | ||
| uint32_t | ssMod ) |
This function initializes the Audio PLL with specific frequency
| ssEnable | enable spread spectrum or not |
| ssRange | range spread spectrum range |
| ssMod | spread spectrum modulation frequency |
| void CLOCK_InitEnetPll | ( | const clock_enet_pll_config_t * | config | ) |
This function initializes the ENET PLL with specific settings.
brief Initialize the ENET PLL.
| void CLOCK_InitExternalClk | ( | bool | bypassXtalOsc | ) |
This function supports two modes:
After this function, please call CLOCK_SetXtal0Freq to inform clock driver the external clock frequency.
| bypassXtalOsc | Pass in true to bypass the external crystal oscillator. |
brief Initialize the external 24MHz clock.
After this function, please call ref CLOCK_SetXtal0Freq to inform clock driver the external clock frequency.
param bypassXtalOsc Pass in true to bypass the external crystal oscillator. note This device does not support bypass external crystal oscillator, so the input parameter should always be false.
| void CLOCK_InitPfd | ( | clock_pll_t | pll, |
| clock_pfd_t | pfd, | ||
| uint8_t | frac ) |
Initialize PLL PFD.
This function initializes the System PLL PFD. During new value setting, the clock output is disabled to prevent glitch.
| frac | The PFD FRAC value. |
| void CLOCK_InitRcOsc24M | ( | void | ) |
brief Initialize the RC oscillator 24MHz clock.
| void CLOCK_InitSysPfd | ( | clock_pfd_t | pfd, |
| uint8_t | pfdFrac ) |
| pfdFrac | The PFD FRAC value. |
brief Initialize the System PLL PFD.
param pfd Which PFD clock to enable. param pfdFrac The PFD FRAC value. note It is recommended that PFD settings are kept between 12-35.
| void CLOCK_InitSysPll | ( | const clock_sys_pll_config_t * | config | ) |
This function initializes the System PLL with specific settings
brief Initialize the System PLL.
| void CLOCK_InitSysPll1 | ( | const clock_sys_pll1_config_t * | config | ) |
This function initializes the System PLL1 with specific settings
| config | Configuration to set to PLL1. |
| void CLOCK_InitSysPll2 | ( | const clock_sys_pll2_config_t * | config | ) |
This function initializes the System PLL2 with specific settings
| config | Configuration to configure spread spectrum. This parameter can be NULL, if no need to enabled spread spectrum |
| void CLOCK_InitSysPll3 | ( | void | ) |
This function initializes the System PLL3 with specific settings
| void CLOCK_InitUsb1Pfd | ( | clock_pfd_t | pfd, |
This function initializes the USB1 PLL PFD. During new value setting, the clock output is disabled to prevent glitch.
brief Initialize the USB1 PLL PFD.
| void CLOCK_InitUsb1Pll | ( | const clock_usb_pll_config_t * | config | ) |
This function initializes the USB1 PLL with specific settings
brief Initialize the USB1 PLL.
| void CLOCK_InitUsb2Pll | ( | const clock_usb_pll_config_t * | config | ) |
This function initializes the USB2 PLL with specific settings
brief Initialize the USB2 PLL.
| void CLOCK_InitVideoPll | ( | const clock_video_pll_config_t * | config | ) |
This function configures the Video PLL with specific settings
brief Initialize the video PLL.
| status_t CLOCK_InitVideoPllWithFreq | ( | uint32_t | freqInMhz, |
This function initializes the Video PLL with specific frequency
| bool CLOCK_IsSysPfdEnabled | ( | clock_pfd_t | pfd | ) |
| pfd | PFD control name |
brief Check if Sys PFD is enabled
param pfd PFD control name return PFD bypass status.
| bool CLOCK_IsSysPll2PfdEnabled | ( | clock_pfd_t | pfd | ) |
brief Check if Sys PLL2 PFD is enabled
| bool CLOCK_IsSysPll3PfdEnabled | ( | clock_pfd_t | pfd | ) |
brief Check if Sys PLL3 PFD is enabled
| bool CLOCK_IsUsb1PfdEnabled | ( | clock_pfd_t | pfd | ) |
| pfd | PFD control name. |
brief Check if Usb1 PFD is enabled
param pfd PFD control name. return PFD bypass status.
| void CLOCK_LPCG_ControlByCpuLowPowerMode | ( | clock_lpcg_t | name, |
| uint8_t | domainId, | ||
| clock_level_t | level0, | ||
| clock_level_t | level1 ) |
| name | Clock gate name, see clock_lpcg_t. |
| domainId | Domains that on the whitelist can change this clock. |
| level0,level1 | Depend level of this clock. |
| void CLOCK_LPCG_ControlBySetPointMode | ( | clock_lpcg_t | name, |
| uint16_t | spValue, | ||
| uint16_t | stbyValue ) |
| spValue | Bit0~Bit15 hold value for Setpoint 0~16 respectively. A bitfield value of 0 implies clock will be shutdown in this Setpoint. A bitfield value of 1 implies clock will be turn on in this Setpoint. |
| stbyValue | Bit0~Bit15 hold value for Setpoint 0~16 standby. A bitfield value of 0 implies clock will be shutdown during standby. A bitfield value of 1 represent clock will keep Setpoint setting during standby. |
| void CLOCK_OSC_BypassOscRc400MTuneLogic | ( | bool | enableBypass | ) |
| enableBypass | Used to control whether to bypass the turn logic.
brief Bypass/un-bypass the tune logic
param enableBypass Used to control whether to bypass the turn logic.
| bool CLOCK_OSC_CheckLocked1MHzErrorFlag | ( | void | ) |
brief Check the error flag for locked 1MHz clock out.
return The error flag for locked 1MHz clock out.
| void CLOCK_OSC_ClearLocked1MHzErrorFlag | ( | void | ) |
brief Clear the error flag for locked 1MHz clock out.
| void CLOCK_OSC_EnableOsc24M | ( | void | ) |
Enable OSC 24Mhz.
This function enables OSC 24Mhz.
| void CLOCK_OSC_EnableOscRc400M | ( | void | ) |
This function enables OSC RC 400Mhz.
| void CLOCK_OSC_EnableOscRc400MTuneLogic | ( | bool | enable | ) |
| enable | Used to start or stop the tune logic.
brief Start/Stop the tune logic.
param enable Used to start or stop the tune logic.
| void CLOCK_OSC_FreezeOscRc400MTuneValue | ( | bool | enableFreeze | ) |
| enableFreeze | Used to control whether to freeze the tune value.
brief Freeze/Unfreeze the tuning value.
param enableFreeze Used to control whether to freeze the tune value.
| uint16_t CLOCK_OSC_GetCurrentOscRc400MFastClockCount | ( | void | ) |
brief Get current count for the fast clock during the tune process.
return The current count for the fast clock.
| uint8_t CLOCK_OSC_GetCurrentOscRc400MTuneValue | ( | void | ) |
brief Get current tune value used by oscillator during tune process.
return The current tune value.
| void CLOCK_OSC_Set1MHzOutputBehavior | ( | clock_1MHzOut_behavior_t | behavior | ) |
| behavior | The behavior of 1MHz output clock, please refer to clock_1MHzOut_behavior_t for details. |
brief Set the behavior of the 1MHz output clock, such as disable the 1MHz clock output, enable the free-running 1MHz clock output, enable the locked 1MHz clock output.
note The 1MHz clock is divided from 400M RC Oscillator.
param behavior The behavior of 1MHz output clock, please refer to clock_1MHzOut_behavior_t for details.
| void CLOCK_OSC_SetLocked1MHzCount | ( | uint16_t | count | ) |
| count | Used to set the desired target for the locked 1MHz clock out, the value in number of clock cycles of the fast clock per divided ref_clk. |
brief Set the count for the locked 1MHz clock out.
param count Used to set the desired target for the locked 1MHz clock out, the value in number of clock cycles of the osc_out_400M per divided ref_clk.
| void CLOCK_OSC_SetOsc16MConfig | ( | clock_16MOsc_source_t | source, |
| bool | enablePowerSave, | ||
| bool | enableClockOut ) |
| source | Used to select the source for 16MHz RC oscillator, please refer to clock_16MOsc_source_t. |
| enablePowerSave | Enable/disable power save mode function at 16MHz OSC.
| enableClockOut | Enable/Disable clock output for 16MHz RCOSC.
brief Configure the 16MHz oscillator.
param source Used to select the source for 16MHz RC oscillator, please refer to clock_16MOsc_source_t. param enablePowerSave Enable/disable power save mode function at 16MHz OSC.
| void CLOCK_OSC_SetOsc24MWorkMode | ( | clock_24MOsc_mode_t | workMode | ) |
| workMode | The work mode of 24MHz crystal oscillator, please refer to clock_24MOsc_mode_t for details. |
brief Set the work mode of 24MHz crystal oscillator, the available modes are high gian mode, low power mode, and bypass mode.
param workMode The work mode of 24MHz crystal oscillator, please refer to clock_24MOsc_mode_t for details.
| void CLOCK_OSC_SetOscRc400MFastClkCount | ( | uint16_t | targetCount | ) |
| targetCount | The desired target for the fast clock, should be the number of clock cycles of the fast_clk per divided ref_clk. |
brief Set the target count for the fast clock.
param targetCount The desired target for the fast clock, should be the number of clock cycles of the fast_clk per divided ref_clk.
| void CLOCK_OSC_SetOscRc400MHysteresisValue | ( | uint8_t | negHysteresis, |
| uint8_t | posHysteresis ) |
| negHysteresis | The negative hysteresis value for the turned clock, this value in number of clock cycles of the fast clock |
| posHysteresis | The positive hysteresis value for the turned clock, this value in number of clock cycles of the fast clock |
brief Set the negative and positive hysteresis value for the tuned clock.
note The hysteresis value should be set after the clock is tuned.
param negHysteresis The negative hysteresis value for the turned clock, this value in number of clock cycles of the fast clock param posHysteresis The positive hysteresis value for the turned clock, this value in number of clock cycles of the fast clock
| void CLOCK_OSC_SetOscRc400MRefClkDiv | ( | uint8_t | divValue | ) |
| divValue | The divide value to be set, the available range is 0~63. |
brief Set the divide value for ref_clk to generate slow clock.
note slow_clk = ref_clk / (divValue + 1), and the recommand divide value is 24.
param divValue The divide value to be set, the available range is 0~63.
| void CLOCK_OSC_SetOscRc400MTuneValue | ( | uint8_t | tuneValue | ) |
| tuneValue | The tune value to determine the frequency of Oscillator. |
| void CLOCK_OSC_TrimOscRc400M | ( | bool | enable, |
| bool | bypass, | ||
| uint16_t | trim ) |
| enable | Used to enable trim function. |
| bypass | Bypass the trim function. |
| trim | Trim value. |
| void CLOCK_OSCPLL_ControlByCpuLowPowerMode | ( | clock_name_t | name, |
| name | Clock source name, see clock_name_t. |
| void CLOCK_OSCPLL_ControlBySetPointMode | ( | clock_name_t | name, |
| void CLOCK_ROOT_ControlBySetPointMode | ( | clock_root_t | name, |
| const clock_root_setpoint_config_t * | spTable ) |
| name | Clock root name, see clock_root_t. |
| spTable | Point to the array that stores clock root settings for each setpoint. Note that the pointed array must have 16 elements. |
| void CLOCK_SetClockOutput1 | ( | clock_output1_selection_t | selection, |
| clock_output_divider_t | divider ) |
| selection | The clock source to be output, please refer to clock_output1_selection_t. |
| divider | The divider of the output clock signal, please refer to clock_output_divider_t. |
brief Set the clock source and the divider of the clock output1.
param selection The clock source to be output, please refer to clock_output1_selection_t. param divider The divider of the output clock signal, please refer to clock_output_divider_t.
| void CLOCK_SetClockOutput2 | ( | clock_output2_selection_t | selection, |
| selection | The clock source to be output, please refer to clock_output2_selection_t. |
brief Set the clock source and the divider of the clock output2.
param selection The clock source to be output, please refer to clock_output2_selection_t. param divider The divider of the output clock signal, please refer to clock_output_divider_t.
| void CLOCK_SetGroupConfig | ( | clock_group_t | group, |
| const clock_group_config_t * | config ) |
Set the clock group configuration.
| group | Which group to configure, see clock_group_t. |
| config | Configuration to set. |
| void CLOCK_SetPllBypass | ( | clock_pll_t | pll, |
| bool | bypass ) |
PLL bypass setting.
| pll | PLL control name (see clock_pll_t enumeration) |
| bypass | Bypass the PLL.
| void CLOCK_SwitchOsc | ( | clock_osc_t | osc | ) |
Switch the OSC.
This function switches the OSC source for SoC.
| osc | OSC source to switch to. |
brief Switch the OSC.
param osc OSC source to switch to.
| bool _clock_group_config::clockOff |
Turn off the clock.
| uint32_t _clock_audio_pll_config::denominator |
30 bit denominator of fractional loop divider
| uint32_t _clock_audio_pll_gpc_config::denominator |
| uint8_t _clock_root_config_t::div |
it's the actual divider
| uint8_t _clock_root_setpoint_config_t::div |
| uint8_t _clock_group_config::div0 |
Divide root clock by div0 + 1, valid range: 0 ~ 15.
| bool _clock_enet_pll_config::enableClkOutput |
Power on and enable PLL clock output for ENET0 (ref_enetpll0).
| bool _clock_enet_pll_config::enableClkOutput1 |
Power on and enable PLL clock output for ENET1 (ref_enetpll1).
| bool _clock_enet_pll_config::enableClkOutput25M |
Power on and enable PLL clock output for ENET2 (ref_enetpll2).
extern |
The RTC XTAL (32K OSC) clock frequency in Hz, when the clock is setup, use the function CLOCK_SetRtcXtalFreq to set the value in to clock driver.
extern |
The XTAL (24M OSC/SYSOSC) clock frequency in Hz, when the clock is setup, use the function CLOCK_SetXtalFreq to set the value in to clock driver. For example, if XTAL is 24MHz,
| uint8_t _clock_root_setpoint_config_t::grade |
Indicate speed grade for each SetPoint
| uint32_t _clock_arm_pll_config::loopDivider |
PLL loop divider. Valid range for divider value: 54-108. Fout=Fin*loopDivider/2.
PLL loop divider. Valid range: 104-208.
| uint8_t _clock_audio_pll_config::loopDivider |
PLL loop divider. Valid range for DIV_SELECT divider value: 27~54.
| uint8_t _clock_audio_pll_gpc_config::loopDivider |
PLL loop divider.
| uint8_t _clock_enet_pll_config::loopDivider |
Controls the frequency of the ENET0 reference clock. b00 25MHz b01 50MHz b10 100MHz (not 50% duty cycle) b11 125MHz
| uint8_t _clock_usb_pll_config::loopDivider |
PLL loop divider. 0 - Fout=Fref*20; 1 - Fout=Fref*22
| uint8_t _clock_enet_pll_config::loopDivider1 |
Controls the frequency of the ENET1 reference clock. b00 25MHz b01 50MHz b10 100MHz (not 50% duty cycle) b11 125MHz
| uint32_t _clock_sys_pll2_config::mfd |
Denominator of spread spectrum
| uint8_t _clock_root_config_t::mux |
See clock_root_mux_source_t for details.
| uint8_t _clock_root_setpoint_config_t::mux |
| uint32_t _clock_audio_pll_config::numerator |
30 bit numerator of fractional loop divider.
| uint32_t _clock_audio_pll_gpc_config::numerator |
| bool _clock_sys_pll1_config::pllDiv2En |
Enable Sys Pll1 divide-by-2 clock or not.
| bool _clock_sys_pll1_config::pllDiv5En |
Enable Sys Pll1 divide-by-5 clock or not.
| clock_pll_post_div_t _clock_arm_pll_config::postDivider |
Post divider.
| uint8_t _clock_audio_pll_config::postDivider |
Divider after the PLL, should only be 1, 2, 4, 8, 16.
Divider after the PLL, 0x0=divided by 1, 0x1=divided by 2, 0x2=divided by 4, 0x3=divided by 8, 0x4=divided by 16, 0x5=divided by 32.
| uint16_t _clock_group_config::resetDiv |
resetDiv + 1 should be common multiple of all dividers, valid range 0 ~ 255.
| uint8_t _clock_enet_pll_config::src |
Pll clock source, reference _clock_pll_clk_src
| uint8_t _clock_usb_pll_config::src |
| clock_pll_ss_config_t* _clock_audio_pll_config::ss |
Spread spectrum parameter, it can be NULL, if ssEnable is set to false
| clock_pll_ss_config_t* _clock_audio_pll_gpc_config::ss |
| clock_pll_ss_config_t* _clock_sys_pll1_config::ss |
| clock_pll_ss_config_t* _clock_sys_pll2_config::ss |
| bool _clock_audio_pll_config::ssEnable |
Enable spread spectrum flag
| bool _clock_audio_pll_gpc_config::ssEnable |
| bool _clock_sys_pll1_config::ssEnable |
| bool _clock_sys_pll2_config::ssEnable |
| uint16_t _clock_pll_ss_config::step |
Spread spectrum step value to get frequency change step.
| uint16_t _clock_pll_ss_config::stop |
Spread spectrum stop value to get frequency change.
