RTEMS 6.3
spec:/testsuites/validation-smp-only-0
This test suite for SMP-only test cases provides enough resources to run basic tests for all specified managers and functions. More...
Topics
 spec:/acfg/val/scheduler-edf-smp
 Tests the effect of application configuration options.
 spec:/rtems/intr/val/intr-smp-only
 Tests some Interrupt Manager directives.
 spec:/rtems/scheduler/val/smp-only
 This test case collection provides validation test cases for SMP-only requirements of the Scheduler Manager.
 spec:/rtems/sem/req/mrsp-obtain
 spec:/rtems/sem/val/smp
 Tests SMP-specific semaphore behaviour.
 spec:/rtems/task/val/smp
 This test case collection provides SMP-specific validation test cases for requirements of the Task Manager.
 spec:/score/sched/smp/edf/req/set-affinity
 spec:/score/sched/smp/edf/val/edf
 Tests for operations of the EDF SMP scheduler.
 spec:/score/sched/smp/val/smp
 Tests SMP-specific scheduler behaviour.
 spec:/score/smp/val/per-cpu-jobs
 Tests the processing order of per-processor jobs.
 spec:/score/thread/val/smp
 Tests SMP-specific thread behaviour.
 spec:/score/tq/val/smp
 Tests SMP-specific thread queue behaviour.
file  testsuites/validation/ts-validation-smp-only-0.c
#define CONFIGURE_MAXIMUM_PROCESSORS   5
const char rtems_test_name [] = "TestsuitesValidationSmpOnly0"
 Each test must define a test name string.
Up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
