RTEMS 6.3
Tests the effect of application configuration options. More...
file  testsuites/validation/tc-acfg-scheduler-edf-smp.c
void __real__Scheduler_EDF_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
void __wrap__Scheduler_EDF_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 T_TEST_CASE (AcfgValSchedulerEdfSmp)
This test case performs the following actions:
  • Check the effect of application configuration options.
    • Check that the Earliest Deadline First SMP Scheduler which was configured by the CONFIGURE_SCHEDULER_EDF_SMP application configuration in the test suite.
