RTEMS 6.3
This validation test suite uses an application configuration which triggers a fatal error during system initialization. More...
Topics | |
| spec:/score/smp/val/fatal-scheduler-requires-exactly-one-processor | |
| Tests a fatal error. | |
Files | |
| file | testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c |
| #define | FATAL_SYSINIT_RUN ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Run |
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| #define | CONFIGURE_MAXIMUM_PROCESSORS 2 |
| #define | CONFIGURE_SCHEDULER_PRIORITY |
| #define | CONFIGURE_SCHEDULER_TABLE_ENTRIES RTEMS_SCHEDULER_TABLE_PRIORITY( a, TEST_SCHEDULER_A_NAME ) |
| #define | CONFIGURE_SCHEDULER_ASSIGNMENTS |
| RTEMS_SCHEDULER_PRIORITY (a, 256) | |
| const char | rtems_test_name [] = "TestsuitesFatalSchedulerRequiresExactlyOneProcessor" |
| Each test must define a test name string. | |
| #define CONFIGURE_SCHEDULER_ASSIGNMENTS |
