RTEMS 6.3
spec:/score/smp/val/fatal-scheduler-requires-exactly-one-processor
Tests a fatal error. More...
file  testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.c
file  testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.h
struct  ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Context
 Test context for spec:/score/smp/val/fatal-scheduler-requires-exactly-one-processor test case. More...
void ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case.
This test case performs the following actions:
  • The test action is carried out by the application configuration of the test suite.
    • Check that the expected fatal source is present.
    • Check that the expected fatal code is present.
◆ ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Run()
void ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Run ( rtems_fatal_source source,
rtems_fatal_code code )
Parameters
sourceis fatal source.
codeis fatal code.
