RTEMS 6.3
This group contains the GRSPW2 interfaces. More...
Topics
 Clock divisor (CLKDIV)
 This group contains register bit definitions.
 Control (CTRL)
 Default address (DEFADDR)
 Destination key (DKEY)
 GRSPW2 DMA
 This group contains the GRSPW2 DMA interfaces.
 Interrupt distribution INT / ACK timer reload (IATIMER)
 Interrupt distribution ISR (ISR)
 Interrupt distribution ISR extended (ISREXT)
 Interrupt distribution ISR timer reload (ISRTIMER)
 Interrupt distribution change timer reload (ICTIMER)
 Interrupt distribution configuration (INTCFG)
 Interrupt distribution control (INTCTRL)
 Interrupt distribution prescaler reload (PRESCALER)
 Interrupt tick-out mask (TICKMASK)
 Interrupt timeout (INTTO)
 Interrupt timeout extended (INTTOEXT)
 Interrupt-code auto acknowledge mask / interrupt tick-out mask extended (AUTOACK_TICKMASKEXT)
 Interrupt-code receive (INTRX)
 SpaceWire Plug-and-Play - Device ID (PNPDEVID)
 SpaceWire Plug-and-Play - Device Vendor and Product ID (PNPVEND)
 SpaceWire Plug-and-Play - Owner Address 0 (PNPOA0)
 SpaceWire Plug-and-Play - Owner Address 1 (PNPOA1)
 SpaceWire Plug-and-Play - Owner Address 2 (PNPOA2)
 SpaceWire Plug-and-Play - Unit Serial Number (PNPUSN)
 SpaceWire Plug-and-Play - Unit Vendor and Product ID (PNPUVEND)
 Status (STS)
 Time-code (TC)
file  bsps/include/grlib/grspw2-regs.h
 This header file defines the GRSPW2 register block interface.
struct  grspw2
 This structure defines the GRSPW2 register block memory map. More...
typedef struct grspw2 grspw2
