#define | BSP_FEATURE_IRQ_EXTENSION |
#define | BSP_SHARED_HANDLER_SUPPORT 1 |
#define | REVISION_REGISTER_ADDRESS 0x1fc00010 |
#define | PRORV_MASK 0x0000000f |
#define | PROID_MASK 0x000000f0 |
#define | CORRV_MASK 0x00000300 |
#define | CORID_MASK 0x0000fc00 |
#define | FPGRV_MASK 0x00ff0000 |
#define | BSP_8259_BASE_ADDRESS (0x18000000UL | 0xa0000000UL) |
#define | BSP_PCI_BASE_ADDRESS (0x1be00000UL | 0xa0000000UL) |
#define | BSP_NIC_IO_BASE (0x10000000UL | 0xa0000000UL) |
#define | PCI0_IO_BASE (0x18000000UL | 0xa0000000UL) |
#define | BSP_NIC_MEM_BASE (0x00000000UL | 0xa0000000UL) |
| #define | WRITE_PROTECTED_UINT8(_addr, _value) |
| #define | WRITE_PROTECTED_UINT16(_addr, _value) |
| #define | WRITE_PROTECTED_UINT32(_addr, _value) |
| #define | READ_PROTECTED_UINT8(_addr, _value) |
| #define | READ_PROTECTED_UINT16(_addr, _value) |
| #define | READ_PROTECTED_UINT32(_addr, _value) |
| #define | READ_UINT8(_register_, _value_) |
| #define | WRITE_UINT8(_register_, _value_) |
| #define | READ_UINT16(_register_, _value_) |
| #define | WRITE_UINT16(_register_, _value_) |
void | simple_out_32 (uint32_t base, uint32_t addr, uint32_t val) |
void | simple_out_le32 (uint32_t base, uint32_t addr, uint32_t val) |
uint8_t | simple_in_8 (uint32_t base, uint32_t addr) |
void | simple_out_8 (uint32_t base, uint32_t addr, uint8_t val) |
int16_t | simple_in_le16 (uint32_t base, uint32_t addr) |
int16_t | simple_in_16 (uint32_t base, uint32_t addr) |
uint32_t | simple_in_le32 (uint32_t base, uint32_t addr) |
uint32_t | simple_in_32 (uint32_t base, uint32_t addr) |
void | simple_out_le16 (uint32_t base, uint32_t addr, uint16_t val) |
void | simple_out_16 (uint32_t base, uint32_t addr, uint16_t val) |
void | init_tlb (void) |
void | resettlb (int i) |
Malta Board Support Package.
