RTEMS 6.3
Global BSP definitions. More...
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | BSP_SHARED_HANDLER_SUPPORT 1 |
| #define | REVISION_REGISTER_ADDRESS 0x1fc00010 |
| #define | PRORV_MASK 0x0000000f |
| #define | PROID_MASK 0x000000f0 |
| #define | CORRV_MASK 0x00000300 |
| #define | CORID_MASK 0x0000fc00 |
| #define | FPGRV_MASK 0x00ff0000 |
| #define | BSP_8259_BASE_ADDRESS (0x18000000UL | 0xa0000000UL) |
| #define | BSP_PCI_BASE_ADDRESS (0x1be00000UL | 0xa0000000UL) |
| #define | BSP_NIC_IO_BASE (0x10000000UL | 0xa0000000UL) |
| #define | PCI0_IO_BASE (0x18000000UL | 0xa0000000UL) |
| #define | BSP_NIC_MEM_BASE (0x00000000UL | 0xa0000000UL) |
| #define | WRITE_PROTECTED_UINT8(_addr, _value) |
| #define | WRITE_PROTECTED_UINT16(_addr, _value) |
| #define | WRITE_PROTECTED_UINT32(_addr, _value) |
| #define | READ_PROTECTED_UINT8(_addr, _value) |
| #define | READ_PROTECTED_UINT16(_addr, _value) |
| #define | READ_PROTECTED_UINT32(_addr, _value) |
| #define | READ_UINT8(_register_, _value_) |
| #define | WRITE_UINT8(_register_, _value_) |
| #define | READ_UINT16(_register_, _value_) |
| #define | WRITE_UINT16(_register_, _value_) |
