RTEMS 6.3
PLL new configuration register (PLLNEWCFG)
This group contains register bit definitions. More...
#define GR740_IOPLL_PLLNEWCFG_SWTAG_SHIFT   27
#define GR740_IOPLL_PLLNEWCFG_SWTAG_MASK   0x18000000U
#define GR740_IOPLL_PLLNEWCFG_SWTAG_GET(_reg)
#define GR740_IOPLL_PLLNEWCFG_SWTAG_SET(_reg, _val)
#define GR740_IOPLL_PLLNEWCFG_SWTAG(_val)
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_SHIFT   18
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_MASK   0x7fc0000U
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG(_val)
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_SHIFT   9
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_MASK   0x3fe00U
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG(_val)
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_SHIFT   0
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_MASK   0x1ffU
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG(_val)
◆ GR740_IOPLL_PLLNEWCFG_MEMPLLCFG
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_SHIFT ) & \
GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_MASK )
◆ GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_GET
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_MASK ) >> \
◆ GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_SET
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_MASK ) | \
GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_MASK ) )
◆ GR740_IOPLL_PLLNEWCFG_SPWPLLCFG
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_SHIFT ) & \
GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_MASK )
◆ GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_GET
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_MASK ) >> \
◆ GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_SET
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_MASK ) | \
GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_MASK ) )
◆ GR740_IOPLL_PLLNEWCFG_SWTAG
#define GR740_IOPLL_PLLNEWCFG_SWTAG ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_PLLNEWCFG_SWTAG_SHIFT ) & \
GR740_IOPLL_PLLNEWCFG_SWTAG_MASK )
◆ GR740_IOPLL_PLLNEWCFG_SWTAG_GET
#define GR740_IOPLL_PLLNEWCFG_SWTAG_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_PLLNEWCFG_SWTAG_MASK ) >> \
◆ GR740_IOPLL_PLLNEWCFG_SWTAG_SET
#define GR740_IOPLL_PLLNEWCFG_SWTAG_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_PLLNEWCFG_SWTAG_MASK ) | \
GR740_IOPLL_PLLNEWCFG_SWTAG_MASK ) )
◆ GR740_IOPLL_PLLNEWCFG_SYSPLLCFG
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_SHIFT ) & \
GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_MASK )
◆ GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_GET
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_MASK ) >> \
◆ GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_SET
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_MASK ) | \
GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_MASK ) )
