RTEMS 6.3
Configuration lockdown register (LOCKDOWN)
This group contains register bit definitions. More...
#define GR740_IOPLL_LOCKDOWN_PERMANENT_SHIFT   16
#define GR740_IOPLL_LOCKDOWN_PERMANENT_MASK   0xff0000U
#define GR740_IOPLL_LOCKDOWN_PERMANENT_GET(_reg)
#define GR740_IOPLL_LOCKDOWN_PERMANENT_SET(_reg, _val)
#define GR740_IOPLL_LOCKDOWN_PERMANENT(_val)
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_SHIFT   0
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_MASK   0xffU
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_GET(_reg)
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_SET(_reg, _val)
#define GR740_IOPLL_LOCKDOWN_REVOCABLE(_val)
◆ GR740_IOPLL_LOCKDOWN_PERMANENT
#define GR740_IOPLL_LOCKDOWN_PERMANENT ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_LOCKDOWN_PERMANENT_SHIFT ) & \
GR740_IOPLL_LOCKDOWN_PERMANENT_MASK )
◆ GR740_IOPLL_LOCKDOWN_PERMANENT_GET
#define GR740_IOPLL_LOCKDOWN_PERMANENT_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_LOCKDOWN_PERMANENT_MASK ) >> \
◆ GR740_IOPLL_LOCKDOWN_PERMANENT_SET
#define GR740_IOPLL_LOCKDOWN_PERMANENT_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_LOCKDOWN_PERMANENT_MASK ) | \
GR740_IOPLL_LOCKDOWN_PERMANENT_MASK ) )
◆ GR740_IOPLL_LOCKDOWN_REVOCABLE
#define GR740_IOPLL_LOCKDOWN_REVOCABLE ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_LOCKDOWN_REVOCABLE_SHIFT ) & \
GR740_IOPLL_LOCKDOWN_REVOCABLE_MASK )
◆ GR740_IOPLL_LOCKDOWN_REVOCABLE_GET
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_LOCKDOWN_REVOCABLE_MASK ) >> \
◆ GR740_IOPLL_LOCKDOWN_REVOCABLE_SET
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_LOCKDOWN_REVOCABLE_MASK ) | \
GR740_IOPLL_LOCKDOWN_REVOCABLE_MASK ) )
