RTEMS 6.3
Drive strength configuration register 1 (DRVSTR1)
This group contains register bit definitions. More...
#define GR740_IOPLL_DRVSTR1_S9_SHIFT   18
#define GR740_IOPLL_DRVSTR1_S9_MASK   0xc0000U
#define GR740_IOPLL_DRVSTR1_S9_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S9_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S9(_val)
#define GR740_IOPLL_DRVSTR1_S8_SHIFT   16
#define GR740_IOPLL_DRVSTR1_S8_MASK   0x30000U
#define GR740_IOPLL_DRVSTR1_S8_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S8_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S8(_val)
#define GR740_IOPLL_DRVSTR1_S7_SHIFT   14
#define GR740_IOPLL_DRVSTR1_S7_MASK   0xc000U
#define GR740_IOPLL_DRVSTR1_S7_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S7_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S7(_val)
#define GR740_IOPLL_DRVSTR1_S6_SHIFT   12
#define GR740_IOPLL_DRVSTR1_S6_MASK   0x3000U
#define GR740_IOPLL_DRVSTR1_S6_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S6_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S6(_val)
#define GR740_IOPLL_DRVSTR1_S5_SHIFT   10
#define GR740_IOPLL_DRVSTR1_S5_MASK   0xc00U
#define GR740_IOPLL_DRVSTR1_S5_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S5_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S5(_val)
#define GR740_IOPLL_DRVSTR1_S4_SHIFT   8
#define GR740_IOPLL_DRVSTR1_S4_MASK   0x300U
#define GR740_IOPLL_DRVSTR1_S4_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S4_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S4(_val)
#define GR740_IOPLL_DRVSTR1_S3_SHIFT   6
#define GR740_IOPLL_DRVSTR1_S3_MASK   0xc0U
#define GR740_IOPLL_DRVSTR1_S3_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S3_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S3(_val)
#define GR740_IOPLL_DRVSTR1_S2_SHIFT   4
#define GR740_IOPLL_DRVSTR1_S2_MASK   0x30U
#define GR740_IOPLL_DRVSTR1_S2_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S2_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S2(_val)
#define GR740_IOPLL_DRVSTR1_S1_SHIFT   2
#define GR740_IOPLL_DRVSTR1_S1_MASK   0xcU
#define GR740_IOPLL_DRVSTR1_S1_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S1_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S1(_val)
#define GR740_IOPLL_DRVSTR1_S0_SHIFT   0
#define GR740_IOPLL_DRVSTR1_S0_MASK   0x3U
#define GR740_IOPLL_DRVSTR1_S0_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S0_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S0(_val)
◆ GR740_IOPLL_DRVSTR1_S0
#define GR740_IOPLL_DRVSTR1_S0 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S0_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S0_MASK )
◆ GR740_IOPLL_DRVSTR1_S0_GET
#define GR740_IOPLL_DRVSTR1_S0_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S0_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S0_SET
#define GR740_IOPLL_DRVSTR1_S0_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S0_MASK ) | \
GR740_IOPLL_DRVSTR1_S0_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S1
#define GR740_IOPLL_DRVSTR1_S1 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S1_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S1_MASK )
◆ GR740_IOPLL_DRVSTR1_S1_GET
#define GR740_IOPLL_DRVSTR1_S1_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S1_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S1_SET
#define GR740_IOPLL_DRVSTR1_S1_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S1_MASK ) | \
GR740_IOPLL_DRVSTR1_S1_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S2
#define GR740_IOPLL_DRVSTR1_S2 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S2_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S2_MASK )
◆ GR740_IOPLL_DRVSTR1_S2_GET
#define GR740_IOPLL_DRVSTR1_S2_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S2_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S2_SET
#define GR740_IOPLL_DRVSTR1_S2_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S2_MASK ) | \
GR740_IOPLL_DRVSTR1_S2_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S3
#define GR740_IOPLL_DRVSTR1_S3 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S3_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S3_MASK )
◆ GR740_IOPLL_DRVSTR1_S3_GET
#define GR740_IOPLL_DRVSTR1_S3_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S3_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S3_SET
#define GR740_IOPLL_DRVSTR1_S3_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S3_MASK ) | \
GR740_IOPLL_DRVSTR1_S3_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S4
#define GR740_IOPLL_DRVSTR1_S4 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S4_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S4_MASK )
◆ GR740_IOPLL_DRVSTR1_S4_GET
#define GR740_IOPLL_DRVSTR1_S4_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S4_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S4_SET
#define GR740_IOPLL_DRVSTR1_S4_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S4_MASK ) | \
GR740_IOPLL_DRVSTR1_S4_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S5
#define GR740_IOPLL_DRVSTR1_S5 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S5_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S5_MASK )
◆ GR740_IOPLL_DRVSTR1_S5_GET
#define GR740_IOPLL_DRVSTR1_S5_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S5_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S5_SET
#define GR740_IOPLL_DRVSTR1_S5_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S5_MASK ) | \
GR740_IOPLL_DRVSTR1_S5_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S6
#define GR740_IOPLL_DRVSTR1_S6 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S6_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S6_MASK )
◆ GR740_IOPLL_DRVSTR1_S6_GET
#define GR740_IOPLL_DRVSTR1_S6_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S6_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S6_SET
#define GR740_IOPLL_DRVSTR1_S6_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S6_MASK ) | \
GR740_IOPLL_DRVSTR1_S6_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S7
#define GR740_IOPLL_DRVSTR1_S7 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S7_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S7_MASK )
◆ GR740_IOPLL_DRVSTR1_S7_GET
#define GR740_IOPLL_DRVSTR1_S7_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S7_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S7_SET
#define GR740_IOPLL_DRVSTR1_S7_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S7_MASK ) | \
GR740_IOPLL_DRVSTR1_S7_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S8
#define GR740_IOPLL_DRVSTR1_S8 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S8_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S8_MASK )
◆ GR740_IOPLL_DRVSTR1_S8_GET
#define GR740_IOPLL_DRVSTR1_S8_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S8_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S8_SET
#define GR740_IOPLL_DRVSTR1_S8_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S8_MASK ) | \
GR740_IOPLL_DRVSTR1_S8_MASK ) )
◆ GR740_IOPLL_DRVSTR1_S9
#define GR740_IOPLL_DRVSTR1_S9 ( _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR1_S9_SHIFT ) & \
GR740_IOPLL_DRVSTR1_S9_MASK )
◆ GR740_IOPLL_DRVSTR1_S9_GET
#define GR740_IOPLL_DRVSTR1_S9_GET ( _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR1_S9_MASK ) >> \
◆ GR740_IOPLL_DRVSTR1_S9_SET
#define GR740_IOPLL_DRVSTR1_S9_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR1_S9_MASK ) | \
GR740_IOPLL_DRVSTR1_S9_MASK ) )
