RTEMS 6.3
Console driver for Termios devices. More...
| struct | console_device |
| Console device information. More... | |
Typedefs | |
| typedef bool(*) | console_device_probe(rtems_termios_device_context *context) |
| Console device probe function type. | |
| bool | console_device_probe_default (rtems_termios_device_context *context) |
| Returns true and does nothing else. | |
| const char * | console_device::device_file |
| The device file path. | |
| console_device_probe | console_device::probe |
| The device probe function. | |
| const rtems_termios_device_handler * | console_device::handler |
| The Termios device handler. | |
| const rtems_termios_device_flow * | console_device::flow |
| The Termios device flow control handler. | |
| rtems_termios_device_context * | console_device::context |
| The Termios device context. | |
| const console_device | console_device_table [] |
| Table for console devices installed via console_initialize() during system initialization. | |
| const size_t | console_device_count |
| Count of entries in the console_device_table. | |
In order to use this driver add the following lines to the Makefile.am of the BSP:
Define the console_device_table and console_device_count in the console-config.c file of the BSP.
| typedef bool(*) console_device_probe(rtems_termios_device_context *context) |
| [in] | context | The Termios device context. |
| true | Install this device. |
| false | Otherwise. |
extern |
It must be provided by the BSP.
extern |
| const char* console_device::device_file |
The "/dev/console" device will be automatically installed as the first device of console_device_table with a successful probe.
