RTEMS
6.3
Toggle main menu visibility
bsps
or1k
generic_or1k
include
bsp
generic_or1k.h
1
8
9
10
* COPYRIGHT (c) 2014-2015 Hesham ALMatary <heshamelmatary@gmail.com>
11
12
* The license and distribution terms for this file may be
13
* found in the file LICENSE in this distribution or at
14
* http://www.rtems.org/license/LICENSE
15
16
17
#ifndef LIBBSP_GENERIC_OR1K_H
18
#define LIBBSP_GENERIC_OR1K_H
19
20
#include <stdint.h>
21
31
37
38
#define OR1K_REG(x) (*((volatile unsigned char *) (x)))
39
#define OR1K_BIT(n) (1 << (n))
40
42
48
#define OR1K_BSP_CLOCK_FREQ 50000000UL
49
#define OR1K_BSP_UART_BASE 0x90000000
50
51
#define OR1K_BSP_UART_REG_TX (OR1K_BSP_UART_BASE+0)
52
#define OR1K_BSP_UART_REG_RX (OR1K_BSP_UART_BASE+0)
53
#define OR1K_BSP_UART_REG_DEV_LATCH_LOW (OR1K_BSP_UART_BASE+0)
54
#define OR1K_BSP_UART_REG_DEV_LATCH_HIGH (OR1K_BSP_UART_BASE+1)
55
#define OR1K_BSP_UART_REG_INT_ENABLE (OR1K_BSP_UART_BASE+1)
56
#define OR1K_BSP_UART_REG_INT_ID (OR1K_BSP_UART_BASE+2)
57
#define OR1K_BSP_UART_REG_FIFO_CTRL (OR1K_BSP_UART_BASE+2)
58
#define OR1K_BSP_UART_REG_LINE_CTRL (OR1K_BSP_UART_BASE+3)
59
#define OR1K_BSP_UART_REG_MODEM_CTRL (OR1K_BSP_UART_BASE+4)
60
#define OR1K_BSP_UART_REG_LINE_STATUS (OR1K_BSP_UART_BASE+5)
61
#define OR1K_BSP_UART_REG_MODEM_STATUS (OR1K_BSP_UART_BASE+6)
62
#define OR1K_BSP_UART_REG_SCRATCH (OR1K_BSP_UART_BASE+7)
63
64
/* FIFO Control Register */
65
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_1 (0x00)
66
#define OR1K_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO (0x01)
67
#define OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR (0x02)
68
#define OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT (0x03)
69
#define OR1K_BSP_UART_REG_FIFO_CTRL_DMA_SELECT (0x08)
70
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_4 (0x40)
71
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_8 (0x80)
72
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_14 (0xC0)
73
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_MASK (0xC0)
74
75
/* Line Control Register */
76
#define OR1K_BSP_UART_REG_LINE_CTRL_WLEN5 (0x00)
77
#define OR1K_BSP_UART_REG_LINE_CTRL_WLEN6 (0x01)
78
#define OR1K_BSP_UART_REG_LINE_CTRL_WLEN7 (0x02)
79
#define OR1K_BSP_UART_REG_LINE_CTRL_WLEN8 (0x03)
80
#define OR1K_BSP_UART_REG_LINE_CTRL_STOP (0x04)
81
#define OR1K_BSP_UART_REG_LINE_CTRL_PARITY (0x08)
82
#define OR1K_BSP_UART_REG_LINE_CTRL_EPAR (0x10)
83
#define OR1K_BSP_UART_REG_LINE_CTRL_SPAR (0x20)
84
#define OR1K_BSP_UART_REG_LINE_CTRL_SBC (0x40)
85
#define OR1K_BSP_UART_REG_LINE_CTRL_DLAB (0x80)
86
87
/* Line Status Register */
88
#define OR1K_BSP_UART_REG_LINE_STATUS_DR (0x01)
89
#define OR1K_BSP_UART_REG_LINE_STATUS_OE (0x02)
90
#define OR1K_BSP_UART_REG_LINE_STATUS_PE (0x04)
91
#define OR1K_BSP_UART_REG_LINE_STATUS_FE (0x08)
92
#define OR1K_BSP_UART_REG_LINE_STATUS_BI (0x10)
93
#define OR1K_BSP_UART_REG_LINE_STATUS_THRE (0x20)
94
#define OR1K_BSP_UART_REG_LINE_STATUS_TEMT (0x40)
95
96
/* Modem Control Register */
97
#define OR1K_BSP_UART_REG_MODEM_CTRL_DTR (0x01)
98
#define OR1K_BSP_UART_REG_MODEM_CTRL_RTS (0x02)
99
#define OR1K_BSP_UART_REG_MODEM_CTRL_OUT1 (0x04)
100
#define OR1K_BSP_UART_REG_MODEM_CTRL_OUT2 (0x08)
101
#define OR1K_BSP_UART_REG_MODEM_CTRL_LOOP (0x10)
102
103
/* Modem Status Register */
104
#define OR1K_BSP_UART_REG_MODEM_STATUS_DCTS (0x01)
105
#define OR1K_BSP_UART_REG_MODEM_STATUS_DDSR (0x02)
106
#define OR1K_BSP_UART_REG_MODEM_STATUS_TERI (0x04)
107
#define OR1K_BSP_UART_REG_MODEM_STATUS_DDCD (0x08)
108
#define OR1K_BSP_UART_REG_MODEM_STATUS_CTS (0x10)
109
#define OR1K_BSP_UART_REG_MODEM_STATUS_DSR (0x20)
110
#define OR1K_BSP_UART_REG_MODEM_STATUS_RI (0x40)
111
#define OR1K_BSP_UART_REG_MODEM_STATUS_DCD (0x80)
112
#define OR1K_BSP_UART_REG_MODEM_STATUS_ANY_DELTA (0x0F)
113
115
117
118
#endif
/* LIBBSP_GENERIC_OR1K_H */
